Found A STS - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 32
Cadillac STS Forum - 2005 through 2012 Discussion, Found A STS in Past Cadillac Vehicle Discussion; compnine dot com link to the vin decoder is at the bottom of the page....
  1. #16
    peetee is offline Cadillac Owners Member
    Automobile(s): NONE
    Feb 2011
    4
    Re: Found A STS
    compnine dot com
  2. #17
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Found A STS
    skexius - If I may offer...
    Your feedback will be much more effective if you break it into paragraphs. Unformated text is likely to be seen as a wall of rant. It's too hard to read and gets ignored.
    You do make a few good points. Members do us all a service when their posts are accurate.
  3. #18
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,959
    Re: Found A STS
    Okay...a quick update...I flew down to Phoenix on Sunday night and picked up the car Monday morning. I headed out about 11am and finally got home Tuesday evening about 630pm. What an AWESOME highway car this is!! And the ACC/HUD makes it even more so. The icing on the cake was the XM radio. This was the best 1500 mile drive I have ever undertaken. I only had one issue the whole way...shortly after starting out at a rest area I was getting random DIC alerts...hood ajar, service security system...I checked the battery volts and it read 12.9. I drove away thinking the battery just needed charging, and never had another problem. Well, I took a big rock in the windshield and will have to get it replaced, but no other mechanical issues. Over all I am very happy with my purchase.
  5. #19
    Neutrocuted's Avatar
    Neutrocuted is offline Cadillac Owners Fanatic
    May 2010
    460
    Re: Found A STS
    Quote Originally Posted by onlyuscars View Post
    Where are you guys running the VIN?
    I search compnine.com > Research > VIN Decoder/RPO Finder and CarFax.
    Also here: http://www.cadillacfaq.com/rpo/index.php
  6. #20
    turnerbend is offline Cadillac Owners Fanatic
    Automobile(s): STS
    Oct 2007
    Georgia
    320
    Re: Found A STS
    That is a lot of real good info.. Thanks
  7. #21
    May 2010
    460
    Re: Found A STS
    Congrats!!! Sorry to hear about the windshield. I believe that they are special for the HUD. I read somewhere that they make sure there is no waviness and /or a coating so that it appears better.
    Right after I got mine I took it from Chicago to northern Arkansas, down all the back road twisties, with my MRC on the "Performance" setting... what a riot!
  8. #22
    chazglenn3's Avatar
    Sep 2004
    Tacoma, WA
    54
    1,959
    Re: Found A STS
    Thanks! I was just wondering if the HUD windshield is different. I'll give my local stealer a call and see what they say.
    ***EDIT*** The dealer parts guy says there is a difference if the car has either Rainsense or HUD. I'll call my favorite glass shop and make sure they can get the correct glass.
    On another note, I can't believe how much more powerful this car is compared to my 2000 STS. The difference is incredible and much more than I expected. I'm glad I decided on the RWD over the AWD car.
  9. #23
    KRSTS Guest
    Re: Found A STS
    Why not have the dealer do it. You insurance should pay for it less your comprehensive deductible and you'll be sure they use the correct glass.
  10. #24
    chazglenn3's Avatar
    Sep 2004
    Tacoma, WA
    54
    1,959
    Re: Found A STS
    The dealer said they subcontract glass work to a glass shop.
  11. #25
    AllWheelEric is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS4 1SG
    Jan 2006
    402
    Re: Found A STS
    A tip on the hood ajar message: There is a TSB on this, but Cadillac probably won't fix it for you for free. Early 2005s had a hood latch that was subject to failure. There is a redesigned part. I ordered one for about $100 and replaced it myself. It's only three bolts. Avoid dropping them into the inside of the beast, and you'll be done in 20 minutes. This could be related to your security system messages -- the car thinks the hood is open. The car can suddenly change its belief about hood status without provocation. i.e., car is parked for hours and suddenly it senses hood open. Well, then it will sound the alarm. So you might want to fix this before it happens in the middle of the night. Ask me how I know.
  12. #26
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Found A STS
    Did the rock crack or just chip your windshield? Is repair an option? The HUD calls for a special windshield. A regular one would probably work but not as good as OEM.
  13. #27
    chazglenn3's Avatar
    Sep 2004
    Tacoma, WA
    54
    1,959
    Re: Found A STS
    Thanks for the hood latch tip. Do they go bad after all this time?
    As for the crack, it made a bullseye with some rays from the center. Total size about the same as a quarter. I'm going to take it and see if it can be fixed, it might be a little too big though.
  14. #28
    KRSTS Guest
    Re: Found A STS
    Sounds like it may be repairable. If it can be, most insurance will pay and waive any deductible.
  15. #29
    Jan 2006
    402
    Re: Found A STS
    Quote Originally Posted by chazglenn3 View Post
    Yup. Mine was fine for ~5 years and acted up a couple months ago.
  16. #30
    Automobile(s): NONE
    Feb 2011
    4
    Re: Found A STS
    Glad that car went to a good home. It must be the one I test drove over the weekend.
    Just a note, the front tires were cupped on the inside tread and had considerable wear when compared to the outside tread. Hopefull they replaced the tires, but I would suggest getting the alignment/front suspension checked out.
    Other than that, the car was a blast to drive!
  17. Remove Advertisements
