Buzzing/Clicking sound on my 05 STS
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 55
Cadillac STS Forum - 2005 through 2012 Discussion, Buzzing/Clicking sound on my 05 STS in Past Cadillac Vehicle Discussion; Hey forum, I just bought my 05 STS V6 40k miles, under normal acceleration there is a buzzing sound coming ...
    05_STS is offline Cadillac Owners Member
    Automobile(s): 2005 STS
    Jan 2011
    Findlay, OH
    28
    48
    Hey forum, I just bought my 05 STS V6 40k miles, under normal acceleration there is a buzzing sound coming from the dash or under hood. It only seems to do it while driving and will be noticeable under normal acceleration but will go away instantly after giving it about half throttle.
    I can't reproduce the sound in park or in drive with my foot on the brake, any thoughts? I just wanted to get some input before taking it to the dealer... Thanks.
    -Nathan
    8323matt's Avatar
    8323matt is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS
    Nov 2010
    Fargo, ND
    182
    Re: Buzzing/Clicking sound on my 05 STS
    I have a sound to and it sounds like its coming from the drivers side of the engine. You can only hear it when your driving and speeding up.
    rzambrano's Avatar
    rzambrano is offline Banned
    Automobile(s): 2005 Cadillac STS
    Sep 2010
    Los Angeles, California
    26
    361
    Same here. I have mentioned it before, it sounds like a "mini supercharger".
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,800
    Have any of you noticed whether this sound disappears after the engine has warmed up?
    rzambrano's Avatar
    Sep 2010
    26
    361
    Quote Originally Posted by ddalder View Post
    For me it happens anytime I floor it.
    ddalder's Avatar
    Aug 2008
    Canada
    2,800
    It can be difficult to diagnose based only on the description. I've driven other vehicles with cracked exhaust manifolds and or bad exhaust manifold gaskets that made sounds similar to what is being described (frequently while under load). Much of the time the symptoms I'm familiar with will disappear once everything heats up.
    8323matt's Avatar
    Nov 2010
    Fargo, ND
    182
    It happens all the time warm or not, it only happens at the lower rmps while driving then goes away after a certain rpm. Its very faint you only can hear it with the fan and radio off. Its close to the firewall so maybe the brake booster valve.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,216
    Maybe loose guts in a CAT converter.
    Don't mess with Binky Bear!
    Jan 2011
    Findlay, OH
    28
    48
    wow, sounds like I'm not the only one with this sound. Yes, warm or hot it will always do it until it reaches a certain RPM and immediately goes away. Does anyone have resources to get more info on the following TSB:
    "TSB Number: 050605001 NHTSA Number: 10013478 TSB Date: January 1, 2005 Date Added to File: April 19, 2005
    Failing Component:Engine And Engine Cooling
    Summary:Buzz type noise inside vehicle.
    Jan 2011
    Findlay, OH
    28
    48
    there is also this TSB:
    "TSB Number: 3226 NHTSA Number: 10011620 TSB Date: n/a Date Added to File: January 27, 2005
    Summary:Exhaust buzz noise 2000-2200 rpm.
    rzambrano's Avatar
    Sep 2010
    26
    361
    Quote Originally Posted by 05_STS View Post
    I do. I have the GM service manual at home. I'll print out a PDF later and link it.
    8323matt's Avatar
    Nov 2010
    Fargo, ND
    182
    Wouldn't suprise me if the Catalytic converters were going bad, I would love to look in it and see how much oil deposits are in it
    rzambrano's Avatar
    Sep 2010
    26
    361
    Quote Originally Posted by 8323matt View Post
    How can I do this. My mechanic savvy stops at the the engine.
  16. #14
    Jan 2011
    Findlay, OH
    28
    48
    I just found out from the dealer today that there is an emissions warranty up to 80k miles and would cover the catalytic converters if that's what's causing the sound.
    I'm going to have it in next week for them to check it out...
  17. #15
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    A vibrating exhaust component noise can often be duplicated in Park. I know the OP said it only happened in gear but it's worth trying different throttle positions, etc.
    Is there any way to reproduce the noise when not in motion? If so, the old rubber hose trick might help. Get a short length of hose and put one end to your ear and try different locations with the other end while someone else does the trick that repeats the noise.
  18. Remove Advertisements
