Rear wheel hub replacement help.
Results 1 to 15 of 15
Cadillac STS Forum - 2005 through 2012 Discussion, Rear wheel hub replacement help. in Past Cadillac Vehicle Discussion; Hello all, Took my car to the dealership for a diagnostic check as to why my rear end was making ...
    cobra671 is offline Cadillac Owners Member
    Automobile(s): 05 STS
    Jun 2009
    25
    Hello all,
    Took my car to the dealership for a diagnostic check as to why my rear end was making a groaning noise that started around 30 mph and just got louder as I increased speed.
    Dealer told me I had a bad hub assembly and it would cost around $900 to replace. That's a bit much for me, so I would prefer to do it myself. What I'm looking for is the correct torque specs for the job. i.e. axle nut, hub mounting bolts.
    If any of you can point me to a source where I can find this info, I'd greatly appreciate it. A repair manual would be great in this instance too.
    Thanks in advance for any input.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Rear wheel hub replacement help.
    Bad bearing? I don't think a hub rebuild can be done without a press.
    Price the assembly direct (a forum supporting vendor?). If you're good with tools, subscribe to Alldata or get the shop manual. It can be counted on to pay for itself.
    Jun 2009
    25
    EChas3,
    Yeah, the bearing in the hub is toast. I'm going to replace the hub assembly as it is easier to locate over a bearing. Where would I find a shop manual? Forum supporter maybe?
    Thanks.
    Quote Originally Posted by EChas3 View Post
    Greg00coupe is offline Cadillac Owners Enthusiast
    Jan 2005
    Canton, Oh
    64
    512
    Back in the day when all cars were RRD we changed out these bearings on a regular basis. Can't think much has changed. A good wheel puller or we even would rig up a chain and use a sledge as a fulcrum and the axle popped out. Then over to NAPA who had the press to change out the bearing. Slide the axle back in engage the pumpkin gears and just torque on the wheel. But that OMgoodness 35 years ago?!?!?
    Jun 2009
    25
    I imagine that is still possible, but with my limited time, it'll be easier to get the hub first, then go to a self help place to get it put on. I don't have the convenience and shelter of a garage here at my apartment.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I know things have changed quite a bit from the old rear-end housings to indpendent suspension. I think the dealer warranty hub assembly was around $425. They did not have to do all that much more than pulling the wheel & caliper.
    Paper shop manuals are pricey (huge). A DVD is pretty reasonable. Alldata had a promotion a while back and some members help their buddies with access to all make & model cars, mfg TSB's and a lot of other goodies.
    Any 'fans' out there?
    Jun 2009
    25
    I purchased a 1 year subscription to Alldata and I think it looks good so far.
    If anyone is interested, the torque spec for the axle nut is 118 ft.lbs. and the hub mounting bolts are 92 ft.lbs. for the rear hub.
    If I remember to take my camera, I'll snap a few pictures.
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    I've done this repair before and it's a piece of cake. No press involved. The rear hub is a sealed assembly and bolts on to a knuckle just like the front. The axle nut is 36mm. Follow the manual and pay attention and you'll be fine.
    Jun 2009
    25
    Quote Originally Posted by TimmyC View Post
    TimmyC,
    Could you give me some insight to doing this? I tried it today, but got stuck on the shaft removal. The socket would not go onto the hub mounting bolts because the shaft wouldn't go out any further than what I could get it to go, with a puller/pusher tool. And the wire that holds the e-brake shoe was a PITA.
    I think if I were able to get that shaft to move just a half inch more, I would've been home free, but that wasn't the case, so I put everything back together and left. This was a bad day for me as far as getting my car fixed was concerned. I will give it a go again next week, when I get back from Boston.
    Any idea how to remove the e-brake cable from the brake cylinder hook? That was a PITA also.
    Thanks for any advice you can offer up.
    C
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I only mentioned a press when I thought someone was going to try to rebuild the assembly. I think I offered a discouraging word.
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    You obviously are not cussing enough. A few choice words always work. lol
    Jun 2009
    25
    Finally got it done!!! Really a piece of cake. Just takes some patients... okay, a bit more than some.. The bottom hub mounting bolt was what took the longest to get out.
    Axle nut: 35mm @ 118 ft. lb.
    Hub mounting bolts: 18mm @ 92 ft. lb.
    bisric99 is offline Cadillac Owners Member
    Automobile(s): 2001 DeVille
    May 2010
    49
    18
    Quote Originally Posted by cobra671 View Post
    I have tried my best and an I can't get a socket on the bolts holding the rear wheel hub...... Do I have to remove the upper control arm? Will that give the axle any play so I can get a bolt on? I tried without removing the upper control arm, because I didn't have the part necessary to remove. Does removing it give me any additional play to change the wheel hub? Please help..... I didn't think anything could be more challenging then my DeVille and DTS, but the STS has topped it!
    Thanks,
    Richard
  16. #14
    ssstealth's Avatar
    ssstealth is offline Cadillac Owners Enthusiast
    Automobile(s): 06 STS-V, 94 Fleetwood TS
    Jan 2003
    Winston Salem, NC
    52
    755
    The factory service manual does say that you must remove the upper ball joint to gain clearance to the hub bolts.
  17. #15
    nwjones18 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS V8
    Feb 2013
    Georgia
    30
    208
    EChas3,
    Thanks.
    I got a GM service manual off Ebay on CD for around 15 bucks, and turns out it has all info for everything 1980-2005 GM. I would highly recommend it.
  18. Remove Advertisements
