2 qestions on the Nav modual in my 2008 STS
Results 1 to 7 of 7
Cadillac STS Forum - 2005 through 2012 Discussion, 2 qestions on the Nav modual in my 2008 STS in Past Cadillac Vehicle Discussion; Hi All, 1. When I first start the car, it sounds like it is rotating through all the cd's in ...
    ChrisHall is offline Cadillac Owners Member
    Automobile(s): 2008 STS AWD Platinum V8
    Sep 2009
    Ottawa, Ontario, Canada
    51
    84
    Hi All,
    1. When I first start the car, it sounds like it is rotating through all the cd's in the 6 disk changer. But there are NO disks in it. When there are disks in it, it does the same thing. Then on occasion, maybe every 2-3 minutes it sounds like it switches to a new cd, but only 1 switch. Not all 6 like initial start up. Is this normal?
    2. I was at a drive-in movie the other day. With car turned off and listening to sound with the Accessory, I can't figure out how to turn off the display screen on the Nav. Is there a way or do I have to cover it up with my jacket?
    Cheers,
    Chris
    caddyfat2 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS4 1SG w/ HUD-ACC
    Jul 2010
    TAMPA, FLORIDA
    462
    Re: 2 qestions on the Nav modual in my 2008 STS
    Chris , I can't help you with #1 but I can with #2. When in your navi screen push the CONFIG button and you will see icons on the left side of the screen. Push the icon that looks like a screen, it's the one on the bottom an it will take you to another screen and in the lower right hand side will say SCREEN OFF. Just push that icon and you're set. Now good luck and remember your STS manuals are your best friend.
    rzambrano's Avatar
    rzambrano is offline Banned
    Automobile(s): 2005 Cadillac STS
    Sep 2010
    Los Angeles, California
    26
    361
    Mine does the same, but I think it only does it with the nav disc drive.
    Sep 2009
    51
    84
    Solved the noise problem, Item #2.
    I bought a new Nav Disk, (Version 7 I believe), and vwala, noise went away. The old disk worked, but for some reason the player kept wanting to re-read itself over and over or something like that.
    Just thought I would let others know.
    Cheers,
    Chris
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Sounds like it wasn't the A/V disk changer at all. The Nav disk doesn't have any system software so it must have been the Nav drive making the noise.
    Has anyone found a way to kill the display at a drive-in?
    rzambrano's Avatar
    Sep 2010
    26
    361
    Quote Originally Posted by EChas3 View Post
    If I remember correctly, when I was playing my iPhone through the AUX inputs, I simply hit the center of the screen and the screen went black.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Quote Originally Posted by rzambrano View Post
    That makes sense when playing a Aux source with no video. At a Drive-In you want to play the radio on Accessory but blank the screen. I don't think there's a way other than to turn it off in Config. (Then it's tricky to turn back on!)
  10. Remove Advertisements
