help, front doors won't open - Page 7
Page 7 of 7 FirstFirst 1234567
Results 91 to 105 of 105
Like Tree15Likes
Cadillac STS Forum - 2005 through 2012 Discussion, help, front doors won't open in Past Cadillac Vehicle Discussion; ABQDon, I did the same thing, sprayed contack cleaner in to the driver door handle untill it ran out bottom ...
  1. #91
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    Re: help, front doors won't open
    ABQDon, I did the same thing, sprayed contack cleaner in to the driver door handle untill it ran out bottom of the door. Worked for a few days. Then nothing, more spray. Called Rippy Cadillac order the switch assembly. $88. includes discount (Cadillac form member) & shipping. I printed off how to replaced the mirco switches. I never did this before but only taken 2 hr. Later I played with the old switch and found out only one micro switch was bad, the orange & blue wire. You can test this with a volt meter. I also popped the switch apart to see what gone wrong. Clean inside, just not making contack. Hope this help. Danny
    aung03, My 06 STS was doing the same thing. Replaced the driver door micro switches. The door lock actuator should be good. I live in columbus Ohio, Maybe you can stop by and we can installed it. Danny
  2. #92
    ~Nightcrawler~ is offline Cadillac Owners Member
    Automobile(s): Looking at an 2008 + STS 4
    Nov 2012
    Wandering HWY 60 in Ontario
    1
    Wow, after skimming through this topic, I wonder WHO at Cadillac thought this was a useful feature?!?
  3. #93
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,055
    Quote Originally Posted by ~Nightcrawler~
    immensely useful, I love not having to ever touch my keys
  5. #94
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,537
    Quote Originally Posted by curtc View Post
    I agree completely.
    sub613 and Rubbertoe87 like this.
  6. #95
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    This car has spoiled me. I never want to lock rentals.
  7. #96
    truckinman is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac STS 3.6
    Apr 2012
    Columbus OH
    32
    1,219
    Quote Originally Posted by EChas3
    Lol. I feel the same when I drive Chrissys Ion. Lol. My parents Avalon is keyless too but you've still gotta push a button on the door handle with your thumb to lock it. Lol. Not ours. Locks all by itself. Lol. Very nice for when you've gotta arm full of groceries!
    Rubbertoe87 likes this.
  8. #97
    Dyates is offline Cadillac Owners Member
    Automobile(s): 06 sts 3.6L
    May 2013
    1
    Does anyone have a part # for the driver door base micro switches?
    Does anyone have a part # for the driver door handle base micro?
  9. #98
    Mar 2012
    columbus ohio
    382
    dyates, On my 06 STS V-6, I only needed the driver door micro switch. The parts # is 19120306 housing k 10.527. Order it from Rippy's auto parts. $88.24 shipped. Most of the time it's the micro switch. Danny
  10. #99
    raypersia is offline Cadillac Owners Member
    Nov 2014
    Hi everyone, that has a problem with Cadillac STS door handles not opening from the outside, here is your solution, and it's a easy fix... my mechanic just fixed it for me for cool $10.00 that's right ten dollars.... he plugged in his scanner to my car, and reset the computer, less than a minute, the doors were working 100%. so please don't get succored by mechanics that going to tell you it will cost over $1,000 to fix it..and you have to replace the modulator. so good Luck.. I am very happy about spending $10.00 and I want it to share this experience with other cadillac owner that have the same problem..
  11. #100
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,537
    Well considering there's about 27 different "computers" in the STS and I've spent a lot of time playing around with the GM Tech 2 on my car and I've never seen any sort of option to fix the door handles on it.
  12. #101
    black05sts is offline Cadillac Owners Member
    Automobile(s): sts
    Dec 2012
    Dear ABQDon,
    First I would like to let you know you are a Genius! After reading all the previous ramblings regarding replacing 350$ handlebases and wifi door antennas and other bullshi# you have managed to break down this apparent complex problem to its simplest form.......... effin corrosion from winter time and road salts etc... GM evindently does not protect the micro switches that activate the door latch when the handle is pulled. so by spraying some WD40 (I put that shi# on everything!!!!) on the handle slide actuator and in the hole under the rubber stopper it found its way to the corroded micro switches rendering the door perfectly and immediately operable. Again sir thank you you are a Genius!!!!!!
  13. #102
    mIAn is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS
    Jun 2014
    Saudi Arabia
    119
    Quote Originally Posted by raypersia View Post
    Again m surprised how a faulty antenna or micro switch starts working after computer reset?
    I think different problems have different solutions.
  14. #103
    Rubbertoe87 is offline Cadillac Owners Member
    Automobile(s): STS 2006
    Dec 2012
    29
    19
    ditto
    Hi guys! Im having a similar problem with my STS 2006, with the front passenger side door, sometimes the door opens, but sometimes dont, what could be causing this
    situation?
    thanks!
  15. #104
    Lisa Cooper is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac Deville DTS, 2004 Cadillac Deville DHS
    Jul 2014
    Sharon, PA
    1
    2006 STS4 Front doors work when they feel like it. Help
  16. #105
    Dec 2012
    29
    19
    Quote Originally Posted by ABQDon
    After reading all of the posts, I decided to try the cheapest option first. I ran down to the Auto Parts Store and got an $8 can of electrical contact cleaner. Similar to a can of WD40 with the hose you attach to the nozzle. I put a little squirt into two places (the gap when you pull on the door handle toward the rear of the car and removed the rubber cap in the door frame at about the same height as the handle). Problem solved. Now works every time. One other note, when it wasn't working, I could hear a "beep" inside the car, so I knew the switch was being sensed.
    This option worked for me! thanks!
  17. Remove Advertisements
