Page 5 of 5 FirstFirst 12345
Results 61 to 65 of 65
Thread: Catalytic Converter Recall (2005 V8)
  1. #61
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,548
    Re: Catalytic Converter Recall (2005 V8)
    Quote Originally Posted by curtc View Post
    Yeah, I've actually been thinking about that...Would have to get O2 sensor delete kits too...How difficult would it be to gut these things? MN doesn't have emissions inspections so I'm good there...
    I would imagine something like this:
    http://www.rx8club.com/series-i-do-y...8/#post1723995
    Gutting your cat.
    Get a foot and half to two feet long half 1/2" steel rod or something similar ( Home depot for about a buck ) and a hammer.
    Flip the pipe vertically with the front (triangular flange facing up)
    stick the rod inside the cat opening and using the hammer keep on whacking the internals until the rod breaks through.
    The is made of 2 parts, meaning that there are actually 2 elements inside that pipe, so when you break the first one, shake the pieces out, and continue whacking on it and shaking stuff out until there is nothing left.
    Use a light to see inside to make sure that it is empty. When everything is out, you'll see that the inside walls of that (now just resonator) are relatively clear and there is nothing left.
    P.S
    The dual structure of the cat is actually the reason the car looses power when the damn thing burns out. When the cat goes, the debris from the front part of the converter (which takes most of the abuse) completely clogs up the second portion of it, and blocks that exhaust flow.
    Your engine simply can't breathe and so it starts to loose power more and more, and if you continue on pushing it, the cat will eventually clog completely, causing the engine to just shut off.
  2. #62
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,059
    Sounds like a lot of fun given that the cats are part of the exhaust manifolds...
  3. #63
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,548
    Never said it would be easy or fun.
    Sent from AutoGuide.com Free App
  4. #64
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Madtuner can delete emissions codes.
  5. #65
    delonne is offline Cadillac Owners Member
    Dec 2010
    31
    34
    So awesome being on my second set of cats. I'm done with trying to hold on to this car. Should have dumped it 4 years ago.
  • You may not post replies
