Catalytic Converter Recall (2005 V8) - Page 2
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 64
Cadillac STS Forum - 2005 through 2012 Discussion, Catalytic Converter Recall (2005 V8) in Past Cadillac Vehicle Discussion; I had a cat replaced on my V6 at 40K something miles on the clock. Free of charge. My car ...
  1. #16
    LAC_STS is offline Cadillac Owners Enthusiast
    Automobile(s): STS
    Nov 2009
    786
    Re: Catalytic Converter Recall (2005 V8)
    My car just ran like crap one day and that was why.
  2. #17
    caddyfat2 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS4 1SG w/ HUD-ACC
    Jul 2010
    TAMPA, FLORIDA
    462
    Quote Originally Posted by lreddiablo View Post
    Guess it may be a seperate issue then. I was pulling several codes before but the code I have down is P0390. Just get same symtom, car seems to lose power then CIL comes on. Goes off a couple days later, then comes back again a few days after that
    Does anyone know what code P0390 is ?
  3. #18
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    14,013
    Quote Originally Posted by caddyfat2 View Post
    DTC P0365 or P0390
    Circuit Description
    The exhaust camshaft position (CMP) sensor is a hall integrated circuit (IC) type sensor that works in conjunction with a single tooth reluctor wheel used to determine the position of the exhaust camshaft. The engine control module (ECM) supplies a 12-volt pull up voltage on the CMP sensor signal circuit. As the tooth on the reluctor wheel passes the CMP sensor, it sends a digital signal which is an image of the reluctor wheel to the ECM. The ECM processes this information to determine the exact position of the camshafts, and to determine the optimum ignition and injection points of the engine. The CMP sensor wiring consists of a 12-volt reference circuit, a low reference circuit, and a signal circuit. If the ECM cannot see a change in the exhaust CMP sensor signal, DTC P0365 or P0390 will set.
    DTC Descriptors
    This diagnostic procedure supports the following DTCs:
    • DTC P0365 Exhaust Camshaft Position (CMP) Sensor Circuit Bank 1
    • DTC P0390 Exhaust Camshaft Position (CMP) Sensor Circuit Bank 2
    Conditions for Running the DTC
    • The engine is running.
    • DTC P0365 or P0390 runs continuously once the above condition is met.
    Conditions for Setting the DTC
    The ECM does not detect a signal from the exhaust CMP sensor for more than 1 second
  4. #19
    BaTu is offline Cadillac Owners Enthusiast
    Automobile(s): '05 STS4
    May 2008
    648
    I wonder if this has been the trouble I've been having, ever since about 30k miles I guess. I had a post earlier that my CIL would come on, but just before I would notice a decrease in power. The codes I got were talking about camshaft sensor 2 malfunction. got a 05 V8 STS4. Think I will take it back and show them this letter, last time they said they just reprogramed the comp
    Unplug each one of the four CPS sensors one at a time, apply some silicone grease, and then plug/unplug each one a few times to clean the contact surfaces.
    They're right out in the open, easy to get to, and will cure most intermittent CPS codes...
  5. #20
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    57
    7,553
    Quote Originally Posted by BaTu View Post
    I believe you mean dielectric grease. Silicon isn't bad but is not a conductor; dielectric grease is.
    (You can't keep Lucas electronics in British cars working right without it. It's the only grease that doesn't leak out of my Triumph!)
  6. #21
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    47
    11,052
    The sensors have one bolt that hold them on, move the sensor to another location (they are all the same) and if the code changes, you have your bad sensor.
    There are hundreds of things that can turn on the check engine light (MIL).
    The V6 cats are totally different than the V8 cats.
  7. #22
    May 2008
    648
    Quote Originally Posted by EChas3 View Post
    I'm not sure that's right......
    No grease is really a conductor, in fact, the term "dielectric" actually means it acts as an electrical insulator (as in dielectric unions for plumbing)
    I know what you mean though,,, it's counter intuitive to think about putting something between to conductors and Not having it interfere with the transfer The first time I used something like No-Ox dielectric grease on an aluminum wire to feed the whole house, or on my battery connections (and here I've used Any grease, petro, moly, synthetic) I too was concerned.
    I think the purpose of greasing a connection is simply to prevent the elements from causing corrosion, sealing the connection. I can only assume that what's left, in a tightened connector, has little effect on the connection.
    It doesn't seem right to me either though,,,,
  8. #23
    Sep 2007
    Wilmington, NC
    14,013
    it's Dielectric Silicone Grease GM#12345579
    I think the idea is to insulate the connection and protect against corrosion etc ...
    on the back of the tube it says this
    This product is designed to coat the inside of spark plug boots to prevent them from sticking to ceramic insulators. it also retards corrosion by improving boot seal.
    and of course there's more uses than for spark plug boots
  9. #24
    lreddiablo is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Apr 2007
    458
    Well I'm just gonna take it to the dealer, got a little warranty left. Tell them to make sure to actually check out the sensors this time and not just reflash the computer. BTW just got that catalytic converter letter
  10. #25
    turnne is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac STS
    Oct 2007
    Indianapolis Indiana
    51
    1,052
    I just received one of these letters today as well saying the warranty on the cat had been extended to 12 years or 200K miles
    It included a reimbursement form if I had had to pay for the repair out of my pocket in the past
    Interesting
    Warren
  11. #26
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    57
    7,553
    Given the cost of this repair, a 2005 in good condition could be a better deal than some newer ones. I wonder how long the cat's came from that supplier. The forum does contain more reports of bad cats than I would have expected. My '93 Roadmaster still ran fine on the original exhaust & cats (gotta love stainless) after 12 years and 225,000 miles.
    Hijack alert!
    Are the older STS's better?
    I'm not convinced the 6-speed trans is much of a performance improvement; mileage - yes, not sure otherwise. My 2006 downshifts less often than my wife's 2007 under similar driving (but also has lower gearing).
    I'm not prepared to say that the 5-speed is better but it is different. For example, it has a selection of '4' so that it never shifts up to 5th. With the 6-speed, you have to go to full manual control to get the same effect.
  12. #27
    Angus Young's Avatar
    Angus Young is offline Cadillac Owners Fanatic
    Automobile(s): 2 Cadillac STS 1SG W/NAV
    Sep 2008
    Central Florida
    158
    Had my cats replaced yesterday, no more CEL and got my remote start back. The dealer didnt know of this recall yet. Life is Good!!
  13. #28
    Oct 2007
    51
    1,052
    Hijack alert!
    To me a mileage improvement would be enough of a reason to have it
    Plus I guess there could see some added longevity...is the motor turning less RPM at 70?
    Warren
  14. #29
    brjndr is offline Cadillac Owners Member
    Dec 2005
    Tracy, CA
    37
    4
    This thread just saved me $2400 the dealer quoted to have my catalytic converters replaced. I called him with about the recall notice and now it's no charge. Thank you guys so much.
  15. #30
    Sep 2007
    Wilmington, NC
    14,013
    so.... a supporting membership is in your future?
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
