2005 Caddy STS Remote Start Issue
Results 1 to 11 of 11
Cadillac STS Forum - 2005 through 2012 Discussion, 2005 Caddy STS Remote Start Issue in Past Cadillac Vehicle Discussion; Please help! I work with a large car retailer here in Virginia, and I sold a gentleman a 2005 Cadillac ...
    Sharrrk is offline Cadillac Owners Member
    Automobile(s): NONE
    Mar 2010
    30
    1
    Please help!
    I work with a large car retailer here in Virginia, and I sold a gentleman a 2005 Cadillac STS recently. During the sale, we noticed that the factory remote start system was not working through the key faub. I read through the owner's manual, and even followed the prompts to turn on the remote start system through the personalization settings. When we tried again, we hit the lock button, then immediately pressed and held the remote start button until the parking lights blinked. According to the manual, at this point, the car should start. It does not. Does anyone have any additional advice. This gentleman would like to have his starter figured out by the summer. Thanks in advance!
    Greg00coupe is offline Cadillac Owners Enthusiast
    Automobile(s): 05 STS
    Jan 2005
    Canton, Oh
    64
    512
    Re: 2005 Caddy STS Remote Start Issue
    Only guess I could make is being a used car maybe the fob need resychronized. There is a section in the manual that covers this.
    STE_6000's Avatar
    STE_6000 is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac STS 2005
    May 2009
    Baltimore, Maryland
    811
    Quote Originally Posted by Sharrrk View Post
    Please help!
    Try holding the lock button down for 5 seconds even after it lights, then push and hold the start button a few seconds after the second light.
    R1chard is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS4 V8 1SG (GONE!)
    Mar 2009
    136
    Please help!
    Check to see if you have any codes on the car. I know my remote starter was automatically disabled after the car threw a code with a check engine light. The weird thing is the light went out on its own but the remote starter remained inactive. So maybe at some point there was a check engine light on?
    Furthermore when I called Onstar to check what the light meant, they made reference the code activated "limp mode" therefor disabling the remote starter to protect the car.
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    You have to press the lock button twice then the start button.
    Make sure your doing that, from your description it sounds like your pressing lock once then the start.
    turnerbend is offline Cadillac Owners Fanatic
    Automobile(s): STS
    Oct 2007
    Georgia
    320
    Quote Originally Posted by CadillacSTS42005 View Post
    You DO NOT have to press the lock button twice.
    Oct 2005
    15,987
    on my 05 ive always had to?
    Automobile(s): STS
    Oct 2007
    Georgia
    320
    Page 2-9 05 STS manual:
    /(Remote Start): To start the vehicle using the
    remote start feature, do the following:
    1. Aim the remote keyless access transmitter at
    the vehicle.
    2. Press the transmitter’s lock button, release it and
    then immediately press and hold the transmitter’s
    remote start button for at least two seconds or until
    the vehicle’s turn signal lamps flash. The vehicle’s
    doors will be locked.
    3. When the vehicle starts, the parking lamps will turn
    on and remain on while the vehicle is running.
    4. Repeat steps 1 and 2 while the engine is still
    running to add 10 minutes of engine running.
    AllGoNShow is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Cadillac STS V6
    Aug 2008
    28
    546
    I have an 05, can guarantee you only need to push lock once.
    In any event. If your lights come on but the car does not start check the following;
    Any check engine lights?
    Any wanrings lights?
    Any codes stored in ECU? (Will need code scanner to get in and check/clear)
    Valet mode switch in glove box on?
    Any doors/trunk open?
    Will also shut off or prevent remote start if low on gas.
    next2pool is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 CTS Luxury 3.6 and 2015 Luxury ATS
    Apr 2009
    Phoenix suburb
    1,807
    Make sure the fob is programmed as 1 or 2. If it is 3 or 4 it won't be able to activate remort start.
    Nightshadow is offline Cadillac Owners Member
    Automobile(s): 2006 White STS 3.6L V6 & 1995 V8 Red Eldorado ETC
    Dec 2008
    Midwest
    38
    46
    I came on here as mine stopped working just to see whats going on, sure enough, my check engine light came on like 2 days ago. P0300. At least now I know my remote starter isnt damaged or something, phew.
  14. Remove Advertisements
