New brake pads
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Cadillac STS Forum - 2005 through 2012 Discussion, New brake pads in Past Cadillac Vehicle Discussion; Hi I did some research in this forum about brake pads but did not find an exact opinion or answer. ...
    Totti808 is offline Cadillac Owners Member
    Automobile(s): STS
    Oct 2009
    33
    New brake pads
    Hi
    I want to buy new brake pads for 2006 Cadillac sts. My brake pads have 'JE5' code - performance brakes.
    After searching in tirerack, I found that hawk only makes front brake pads for JE5. So I decided to install Hawk brake pads for the front brakes, and Akebono for rear brakes. Can I do this mixture or will it cause me problems?
    My choices are :
    Akebono ProACT Ceramic Pads (Rear brake pads)
    Hawk Performance Ceramic Pads (Front brake pads)
    So what do you think? Should I go wit ceramic brake pads? or should I choose composite like "Hawk HPS Street brake pads"?
    My main concern is more stopping power and lower dust.
    Greg00coupe is offline Cadillac Owners Enthusiast
    Automobile(s): 05 STS
    Jan 2005
    Canton, Oh
    64
    512
    Re: New brake pads
    I've not researched STS brakes because I am not their yet, don't need them. But I have a Corvette and have researched all the options for it. I also have a friend who ownes a wholesale parts business and I considered his input too. Bottom line for the Corvette I went with stock brake pads and rotors. I think the advantages of ceramic are overblown. GM puts out some quality brake parts.
    LAC_STS is offline Cadillac Owners Enthusiast
    Automobile(s): STS
    Nov 2009
    786
    Re: New brake pads
    My service adviser told me that they have a lot of people who come in complaining of light squeaking sounds from theyre brakes. He said that the GM pads always make some kind of noise and they usually put better pads on it and it will go away. My STS does it too I am just waiting until the pads wear down some more before replacing them.
    AllGoNShow is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Cadillac STS V6
    Aug 2008
    28
    546
    Re: New brake pads
    Since neither of those guys actually answered your question I will help you out.
    Your current combo is ok, there will be slight differences in the compounds they use from company to company but since you are probably not tracking your beast, you will never notice the difference.
    Hawk HPS is what I have on my STS right now, sometimes the HPS can be a little noisey but I'd rather know my vehicle is coming to a stop then worry about how much noise it is making while doing that. I personally recommend the HPS over the Ceramic, if you are ever in need to come to a hault REALLY fast, the HPS is going to do better than the Ceramics, especially if you already have some heat built into them. The HPS is a really great pad to use and I suggest it for anyones vehicle that enjoys driving their car, coming to a stop and some spirited driving. Track is a different story but these can even be used lightly on the track. HPS is a low dust pad, WAY better then GM's junk. No pad is DUSTLESS despite what they say.
    Regulator is offline Cadillac Owners Fanatic
    Jul 2008
    180
    Re: New brake pads
    I did Akebono ceramic's on both the front and rear of my JE5 package. They work very well for my commuting purposes. Why can't you locate the Akebono's for the front? I believe I had to go to elsewhere besides tirerack to get them.
    Very low dust.
    Do a search to locate the correct model pad...I think I got mine from rockauto
    pgw85706 is offline Cadillac Owners Member
    Automobile(s): Cadillac '05 STS V6
    Jul 2007
    42
    Re: New brake pads
    I have Akebono's all the way around also on my '05 V6 and am pleased with the braking and low dust. I especially notice the absence of staining on the chrome rims as compared to the OEM pads. I buy my brake parts at www.placeforbrakes.com
    coati's Avatar
    coati is offline Cadillac Owners Fanatic
    Mar 2007
    The SF Bay Area
    185
    Re: New brake pads
    I just installed EBC Red Stuff ceramic brake pads (front & rear) on my '06 STS w/Northstar (1SG) along with Disc Italia drilled & slotted rotors.
    Decided to finally paint the calipers red with G2 Epoxy caliper paint.
    Thus far am very happy with the stopping ability of the pads and look of the rotors & calipers.
    Pretty low dusting once "broken-in".
    I like them better than the Akebonos (good pads, durable & low dust) which I had up front before the brake pad change.
    Also did a tire change and went from Goodyear ResponseEdge to Goodyear F1 Asymmetric (255/45/18) all the way around.
    They are a great tire.
    Much better than the OEM Michelins and Goodyear ResponseEdge in ride, braking and wet/dry weather traction.
    Automobile(s): STS
    Oct 2009
    33
    Re: New brake pads
    Thank you guys for your contributions.
    I think I will go with Hawk HPS for front.
    I am still not sure abour rear pads but might go with akebono ceramic .
    But EBC Red Stuff looks interesting too.
    Might do more research before ordering tomorrow.
    M.A.C's Avatar
    M.A.C is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS-V8
    May 2004
    New Jersey
    349
    Re: New brake pads
    As far as aftermarket, NAPA brake pads and rotors are also good. I put their Adaptive One brakes and Ultra Premium rotors on the front of my '94 Eldorado and they worked very well. If you research their rotors you will find a lot of good reviews. The rotors have a lifetime guarantee for warping.
    rnkath08's Avatar
    rnkath08 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS4 v8
    Apr 2009
    upstate ny
    48
    163
    Re: New brake pads
    I went with Hawk HPS on the fronts and Street Performance on the rears, actually had a good chat with Mike at Raceshopper which is only an hour from my house and he recommended the pair up saying the rears would be a very close composite and perfomance to the Hawks. I have not been disappointed in the least. I can't say they're dust free, but damn close and I can stop on a dime. Love them. Someone says they hear a noise with their Hawks, but I can't say I've heard anything, then again maybe the Corsa masks it? Either way, I wouldn't change pads for anything.
    Good luck!
    Automobile(s): STS
    Oct 2009
    33
    Re: New brake pads
    I just have one more question, what is the difference between JE5 and JL9 brake pads? Because most of the rear brake pads are made for JL9 !
    coati's Avatar
    Mar 2007
    The SF Bay Area
    185
    Re: New brake pads
    Quote Originally Posted by Totti808 View Post
    More than likely the JE5 pads are a bit larger than the JL9 and won't be interchangeable.
    My '06 STS uses JE5 pads but the online auto parts company mistakenly sent STS V-Series front pads which are larger and won't fit.
    The STS's use either STS-V, JE5 or JL9 pads (highest performance, high performance & regular).
    Automobile(s): STS
    Oct 2009
    33
    Re: New brake pads
    I ordered Hawk HPS for the front brakes.
    Thanks for the info.
    Quote Originally Posted by rnkath08 View Post
    Is Street Performance a brand name? or do you mean Hawk Street Performance?
    I am still looking for rear brake pads to go with the Hawk HPS on the front. Any suggestion for a good combination?
    I just wonder why Hawk only makes front brakes pads for JE5 and not for the rears!!!
  16. #14
    rnkath08's Avatar
    Apr 2009
    upstate ny
    48
    163
    Re: New brake pads
    Yes I think Street Performance is the brand on the rears, just dug thru my file, only to find the receipt of what I paid, not the item #s, but why not just call them? Ask for Mike, he was great when I spoke to him. It's Raceshopper/Best Brake in Syracuse, NY
    I know I found the phone number on this forum somewhere at the time, but I'm sure 411 can get it as well.
    Good luck!
  17. #15
    R1chard is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS4 V8 1SG (GONE!)
    Mar 2009
    136
    Re: New brake pads
    Good luck!
    http://www.raceshopper.com/
    1-800-733-8380 - Order Line
    8am-7pm EST
    315-295-0417 - Tech Line
  18. Remove Advertisements
