Added nav to non nav sts! 100% confirmed vid and pics. Thank you polarbear05!!! - Page 7
Page 7 of 22 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
Results 91 to 105 of 318
Like Tree3Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Added nav to non nav sts! 100% confirmed vid and pics. Thank you polarbear05!!! in Past Cadillac Vehicle Discussion; I think i'll do that, and attach it to the dash or the lowest part of the center of the ...
  1. #91
    STE_6000's Avatar
    STE_6000 is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac STS 2005
    May 2009
    Baltimore, Maryland
    811
    Re: Added nav to non nav sts! 100% confirmed vid and pics. Thank you polarbear05!!!
    I think i'll do that, and attach it to the dash or the lowest part of the center of the window.
  2. #92
    STE_6000's Avatar
    May 2009
    Baltimore, Maryland
    811
    slightly off topic. I am at work, so i cant read my manual, but how do you delete presets on the navi? or do you just have to over right them?
  3. #93
    LAC_STS is offline Cadillac Owners Enthusiast
    Automobile(s): STS
    Nov 2009
    786
    Preset what? With the radio or with the actual navigation part?
    If you enter the NAV diagnostic screen there is a reset in there for the whole NAV. You'll have to search here in the STS part if the forum for NAV diagnostic screen or NAV diagnostic instructions.
    The thread tells you how to get into it.
  5. #94
    STE_6000's Avatar
    May 2009
    Baltimore, Maryland
    811
    Quote Originally Posted by LAC_STS View Post
    ahh, sorry, i meant the radio presets.
  6. #95
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    You save right over them.
    If you have the update done the preset configuration is slighly different (I have I cannot remember exactly what the change was but I do remember a slight change not in the way you save them but in how the presets are presented)
  7. #96
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Don't forget your audio settings (bass, mid & treble) save by preset.
  8. #97
    STE_6000's Avatar
    May 2009
    Baltimore, Maryland
    811
    Welp the pioneer antenna didnt work at all. The radio didnt even know something was plugged in. Question is, is there a gps disable through the tech 2? or is it possible the cadillac gps antenna is more special then just a pink connector? someone have a pic of the cadillac antenna and wire and plug?
  9. #98
    Automobile(s): STS
    Nov 2009
    786
    I don't think there is a GPS off with the Tech II.
    That's what I was talking about that the OEM antenna has it's own diagram of it's insides so there may be something special about it.
    If your antenna is not hooked up for a while it can take a good while for it to recognize it. Alldata has a TSB that says it could take up to 50 miles with 25 left and right turns for it to be recognized.
    There was also a thread a little whole ago where it took the OP a long time for the NAV to recognize the antenna.
    And that's the OEM antenna so it might take even longer for an aftermarket one.
    Also, if the connector is not ALL the way in it will not work. The OEM connector feels like it's in sometimes but it's actually hitting the metal casing of the NAV. You have to turn it a little one way and it will go in more.
    I'm pretty sure you can go into the diagnostic menu and see if it's connected.
  10. #99
    STE_6000's Avatar
    May 2009
    Baltimore, Maryland
    811
    i'll try driving with it and see what happens. thanks for the input.
  11. #100
    Automobile(s): STS
    Nov 2009
    786
    Search for te thread called "NAV diagnostic screen" or something like that.
    I know you can see all the hardware hooked up to the NAV. It tells you the gyro reading and everything. It should tell you if it is getting signal from the antenna.
  12. #101
    2005blacksts is offline Cadillac Owners Member
    Automobile(s): 2005 sts
    Jan 2009
    47
    10
    Will a 2010 nav fit in an 05? Should right?
  13. #102
    STE_6000's Avatar
    May 2009
    Baltimore, Maryland
    811
    from what i heard, that is a no.
  14. #103
    Jan 2009
    47
    10
    O wow. Ok. Well good to know. Thank u for prompt reply.
  15. #104
    STE_6000's Avatar
    May 2009
    Baltimore, Maryland
    811
    from what i heard, the years are 2005-2007 and then 2008-2010 and probably beyond.
  16. #105
    next2pool is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 CTS Luxury 3.6 and 2015 Luxury ATS
    Apr 2009
    Phoenix suburb
    1,620
    Quote Originally Posted by STE_6000 View Post
    I'm running an o8 in my o6 with no problems. I've never heard that an 2010 wouldn't work--but that doesn't mean anything
  17. Remove Advertisements
