Added nav to non nav sts! 100% confirmed vid and pics. Thank you polarbear05!!! - Page 21
Page 21 of 22 FirstFirst ... 11 12 13 14 15 16 17 18 19 20 21 22 LastLast
Results 301 to 315 of 318
Like Tree3Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Added nav to non nav sts! 100% confirmed vid and pics. Thank you polarbear05!!! in Past Cadillac Vehicle Discussion; Can someone help me? I have an 08 Cts 4 with non nav and i want to replace it with ...
  1. #301
    rdade is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac cts 4
    Apr 2013
    15
    Re: Added nav to non nav sts! 100% confirmed vid and pics. Thank you polarbear05!!!
    I have an 08 Cts 4 with non nav and i want to replace it with a 2011 cts V navigation system faceplate and center console and all. Is this possible? I contact the dealership and they said that it's not possible to swap the nav system because of the wiring. Obviously the don't know so i turn to my fellow cadillac users in this form for correct answer or advice. Can anyone tell that this is possible? Greatly appreciate it.
  2. #302
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    CTS forum has a whole thread for this.
  3. #303
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    GM does not have an upgrade path for this so any dealer is going to tell you 'no'
    as 1Bad said, there is a thread on this ... it can be done with enough time, money, and skill
    i don't recommend it though ... you'd be better off trading up for a 2011 w/ nav in the long run
  5. #304
    DBB
    DBB is offline Cadillac Owners Member
    Automobile(s): 2005 STS V6
    May 2013
    44
    56
    i just purchased a 2005 STS non nab with bose. I want to add Nav and Iphone/Ipod connectivity. I spoke with an experienced installer and her mentioned that I would mainly need this harness : http://www.installer.com/cars/by_car.php?carid=6883 which
    "Allows installation of an aftermarket radio using the existing factory wiring and connectors
    The GMOS-13 is designed to be used on 06-09 Cadillac STS equipped with OnStar and amplified system. It will retain the warning chimes that are lost when the factory radio is removed. The GMOS-13 also provides a 12-volt switched parking accessory output along with mute, parking brake, speed sense (VSS), and reverse outputs for the installation of an aftermarket navigation radio
    Has anyone had any luck with this harness. Also do you think it will retain the personalized settings of the original radio? What are your thoughts?
  6. #305
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    DBB - I recommend you start a new thread. This one is about adding an OEM Nav to a non-nav STS. I think members have done things like you want but they may not notice this.
  7. #306
    DBB
    May 2013
    44
    56
    Quote Originally Posted by EChas3 View Post
    Thanks for the advice! Will do.
  8. #307
    RandallLee is offline Cadillac Owners Member
    Automobile(s): STS
    Apr 2013
    3
    Can you elaborate on hooking up the VSS wire (2006 Cadillac STS)? You mentioned wiring to the wrong side of the relay??? I just received my factory navigation and antenna. Getting ready to order a Lockpick if it will help with the VSS wire connection. I've seen the photos on this thread of the connection point behind the glovebox and it lookls fairly easy. How do you know which side of the connector brown wire to spice into?!
    Thanks a bunch!
  9. #308
    ArturoHG is offline Cadillac Owners Member
    Automobile(s): Cadiilac STS ´05 Base With NAV
    Jul 2014
    Quote Originally Posted by tomm View Post
    Glad it worked for you. BTW we are not Coastal Tech and I know you got the lockpick from us.
    In any case to get a full working navigation unit you still have your work cut out for you. I can attach the wiring diagrams to show all the wires you are missing and they are mostly for voice commands, center channel, subwoofer outputs etc. I am assuming since you are missing the additional connectors you dont have the 15 speaker bose option?
    Hello Can you help me with the wiring diagram please. Thanks
  10. #309
    mikpsychos is offline Cadillac Owners Member
    Automobile(s): '05 STS V8, 176K, pre-owned,PRAY FOR ME!!!
    Jun 2014
    I know this has been answered in about 20 different ways, but here I go...I already have my nav system, ready to go in my non-nav 05 STS. I know I need a GPS antenna. What else do I need exactly, and what steps do I take, and what else do I need, to make this all work CORRECTLY, Bluetooth and all. Also, I know I need an external microphone for the Bluetooth to work properly. Is there a mic available which is plug and play? I only want to do this ONCE - I don't want to have to keep taking out the nav unit to perform another step. I also don't want my car "spinning" on the screen - please explain the whole VSS connection also. I was hoping this conversion would be plug and play, but reading all the posts, it seems that everyone has conflicting information. Please help me! I am just about ready to put MY nav unit back on eBay, if this is going to be more trouble than its worth. Thanks!
  11. #310
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I can't recall any member posting 100% success because of the difficulty in getting the call to play back. Playing the Nav turn-by-turn is only a little easier as I recall. The rest is all in the thread except for Ludasrcvp's HUD upgrade (no small job, but one of the better features of the car.)
    IMHO, I'd go aftermarket and run that new head-end line-level output into the stock base system XM input. Otherwise, there are other ways to keep the OEM setup essentially intact.
  12. #311
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    I believe the MICROPHONE is on the center bottom of the rear view mirror, Did the "Pre NAV"install
    have ONSTAR, I believe so, therefore the mic is there already.Somehow it changes "JOBS" to do both.
    ddalder has a post on here about that.with antennas/how and why/hookups, etc.
    Happy Motoring
  13. #312
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    ^^^I concur.
  14. #313
    PontiacV8's Avatar
    PontiacV8 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Camaro 2SS, Sold: 2006 STS (EXP) 1997 Seville STS (EXP)
    Dec 2006
    Germany / Nordhorn
    423
    ...btw...what about the little microphone in the "overhead console" ?
  15. #314
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,800
    The microphone on the bottom of the mirror is connected to the OnStar module. It is shared with the navigation voice control system as well by way of (what I believe) is a pass-through strategy when necessary. There is a second microphone though which is located in the roof center console. This is for sensing ambient noise levels which the audio system uses to make some adjustments to volume level. This works in addition to the built-in stereo function of Speed Compensated Volume.
    Many of the factors that present challenges to having this work 100% correctly have already been addressed throughout this thread.
  16. #315
    PontiacV8's Avatar
    Dec 2006
    Germany / Nordhorn
    423
    Quote Originally Posted by ddalder View Post
    ...there must be another connection or some kind of pass-through for the navigation voice control system, cause exports don't have OnStar (and so no OnStar module...there is also no antenna on the roof )
    ...there is a microphone in/at the bottom of the (export-specs) mirror on export STS's...
  17. Remove Advertisements
