The COMPLETE, CORRECT, STS Interior/Exterior Light Bulb Application Guide - Page 5
Page 5 of 8 FirstFirst 12345678 LastLast
Results 61 to 75 of 118
Like Tree9Likes
Cadillac STS Forum - 2005 through 2012 Discussion, The COMPLETE, CORRECT, STS Interior/Exterior Light Bulb Application Guide in Past Cadillac Vehicle Discussion; Originally Posted by muzariaz the front turn signal bulb is a 3757, will 3157 work cuz i cant seem to ...
  1. #61
    DarkMingBlueSTS's Avatar
    DarkMingBlueSTS is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS 6 CYL
    May 2012
    497
    Quote Originally Posted by muzariaz
    the front turn signal bulb is a 3757, will 3157 work cuz i cant seem to find any LED 3757's!!!
    Yup 3157 will be fine
  2. #62
    DeviledSTS-V is offline Cadillac Owners Member
    Automobile(s): 2006 STS-V
    Aug 2012
    Fort Worth, TX
    35
    Re: The COMPLETE, CORRECT, STS Interior/Exterior Light Bulb Application Guide
    Can someone verify the size of the front quarter panel turn signal bulbs? Are they 194's?
  3. #63
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    The fender bulbs? Yea 194
  5. #64
    Aug 2012
    Fort Worth, TX
    35
    Yes the fender bulbs. Also how do you take off the cover? Dont want to break it either.
  6. #65
    May 2012
    497
    Quote Originally Posted by DeviledSTS-V View Post
    Pull back the wheel well liner, and then you can reach it from the inside and push it out...you may have to turn the wheels also
  7. #66
    Aug 2012
    Fort Worth, TX
    35
    One last question, for the license plate lights, any special methods or tricks to replace those? Havent tried taking off the covers to replace those.
  8. #67
    May 2012
    497
    Remove the the carpet liner on the trunk lid...i built shiney housings for mine to give them a brighter look...i used "tin foil tape" (ac tape) to build them
  9. #68
    Northridge is offline Cadillac Owners Member
    Automobile(s): 08 STS
    Apr 2013
    Greenville, SC
    72
    5
    Can anyone tell me where I can find instructions for replacing the passenger side "bullet" lamp in the headlight assembly on my 08 STS ? Apparently it's a rather daunting task.
    Thanks, Rob
  10. #69
    May 2012
    497
    Quote Originally Posted by Northridge
    Thanks, Rob
    You have to take all of the steps needed to replace the headlight lamps
  11. #70
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    There's an ongoing debate among members. The 'by the book' crowd say remove the bumper cover. The 'shortcut' crowd say it's not necessary.
    As usual, they both have their points.
  12. #71
    06WhiteDiamond is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS-V
    Jan 2012
    28
    320
    Hmm i read through the entire thread and it seems that nobody mentions the bulb type for the trunk light, can anyone chime in?
  13. #72
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    Need help on removing the light bulb from under the shifter. It was easy to remove the trim to see the bulb. The little blue bulb won't come out. Tried to pull & twist, no luck. What part number is this bulb. Is this a dealer item. Thanks, Danny
  14. #73
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,870
    Quote Originally Posted by dannyquest View Post
    The part number (for my 2008) is 89027003. You don't show what year your STS is so I'm assuming 2005+ in which case I believe it's the same part number. When I bought one for my car, US retail on this item is $32.48. Chris at Rippy will likely be able to do much better but this is an expensive bulb.
  15. #74
    Mar 2012
    columbus ohio
    382
    ddalder, Thanks for the info. My STS is an 06. With the price of this bulb it might stay dark. Is there a trick on removing the bulb.. Danny
  16. #75
    ddalder's Avatar
    Aug 2008
    Canada
    2,870
    I haven't actually replaced mine yet. The backlight seemed a little dimmer on one side versus the other so I bought a bulb thinking I may have one out but this wasn't the case. As far as I knew, it was just a twist and remove. I'd have to get back into the console to look closer to be offer better advice.
    coogs55 likes this.
  17. Remove Advertisements
