Timing belt broke on 2006 sts with 53,000 miles! - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 69
Like Tree1Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Timing belt broke on 2006 sts with 53,000 miles! in Past Cadillac Vehicle Discussion; You know--the more I think about this the more pissed off I get. These cars have both a low oil ...
  1. #16
    next2pool is online now Cadillac Owners Connoisseur
    Automobile(s): 2016 CTS Luxury 3.6 and 2015 Luxury ATS
    Apr 2009
    Phoenix suburb
    1,712
    Re: Timing belt broke on 2006 sts with 53,000 miles!
    You know--the more I think about this the more pissed off I get. These cars have both a low oil pressure warning and a low oil level warning. Whether they work or not is not your problem. If indeed your crankcase level was low, you should have had a warning (why are those systems there and explained in the owners manual). Also, if indeed the engine starved for oil, many other systems would have failed long before the chain failed. I personally think you need to go on the offensive and put your dealer on the defensive. I'm sure they will give you the normal crap about checking oil level, but ask them why the vehicle has indicator lights and why as a customer you shouldn't count on them. Also, what was your oil life indicator when this happened. If it still shows a fair amount of oil life remaining, you can challenge them on excessive consumption even though you had lots of oil life left. I know that this stuff is difficult for a lot of folks, but there's a lot of money involved here. Again, as an engineer, i don't think that a timing chain failure is the first failure to ocurr due to low oil pressure. Ask them about the 2007 failures that were attributed to vendor quality and how do they know your's may be different.
  2. #17
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    Some 2005 and 2006 3.6s have had timing chain problems. Local dealer told me that if you have a warranty, you are ok. If not warranty, big trouble. (You are on your own.) Repair is a real headache too.
  3. #18
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    Sep 2003
    DETROIT
    35
    22,380
    This is the first I've heard of a timing chain issue. Good to know.
  5. #19
    bass_sts is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2008
    32
    on the 2005 v8s when does the chain need to be serviced normally?
    How about the v6s?
  6. #20
    Apr 2009
    Phoenix suburb
    1,712
    I don't think there is any service to be done on chains--they should normally last for life--whatever that may be.
  7. #21
    papaisrollin is offline Cadillac Owners Member
    Automobile(s): 06 sts....
    Oct 2004
    minnesota
    48
    36
    AngryRe: Timing belt broke on 2006 sts with 53,000 miles!
    Thanks for the info next2pool. I am calling the dealer right now and will post their response.
  8. #22
    Oct 2004
    minnesota
    48
    36
    oh and my engine oil life was at 30% left.
  9. #23
    AllWheelEric is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS4 1SG
    Jan 2006
    400
    It was a vastly different car, but when some Quickie Lube grease monkeys started my 1980 Mustang with no oil in it (in order to flush the radiator), it only took 2-3 minutes till the timing belt snapped.
  10. #24
    Apr 2009
    Phoenix suburb
    1,712
    Probably seized the cam bearings
  11. #25
    WillySTS is offline Cadillac Owners Enthusiast
    Automobile(s): none
    Feb 2006
    Los Angeles
    64
    627
    Quote Originally Posted by bass_sts View Post
    How about the v6s?
    There is no service interval for timing chains. The tensioners and variable cam timing actuators are hydraulicly operated so it just needs the proper level of oil at all times and also is part of the reason synthetic oil is specified for these engines.
  12. #26
    Automobile(s): none
    Feb 2006
    Los Angeles
    64
    627
    Quote Originally Posted by papaisrollin View Post
    The oil life monitor does not monitor oil level, you can be low in oil and the reading will not change because of that.
  13. #27
    Greg00coupe is offline Cadillac Owners Enthusiast
    Automobile(s): 05 STS
    Jan 2005
    Canton, Oh
    64
    512
    Don't know about this generation of STS but my 2000 used oil about a quart between changes. When it got down below 1 qt a warning came on. So I had 7 qts left and just needed to add a quart. My 05 V8 uses no oil, not sure this is good or bad. But I would expect there is a warning in the DIC when oil levels drop.
  14. #28
    Apr 2009
    Phoenix suburb
    1,712
    Quote Originally Posted by WillySTS View Post
    The reason I asked about oil life remaining was to get an idea how long it had been since his last oil change and the potential oil that may have been used since his last change.
  15. #29
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    What's the real story? Did it really just up and die at 53k? If that's true, a good dealer would back you with GM. The end of the warranty period isn't a cartoon car explosion.
  16. #30
    Oct 2004
    minnesota
    48
    36
    This IS THE REAL STORY. No reason to lie just left the dealership. The service manager just told me he knows nothing of timing chain problems with 05 ans 06 but the 08 and 09 cars have had timing chain problems. I will be contacting cadillac,they are about to lose a long time customer This is at the morries cadillac in golden valley mn.
  17. Remove Advertisements
