Official STS Lockpick Thread - Page 6
Page 6 of 38 FirstFirst 12345678910111213141516 ... LastLast
Results 76 to 90 of 567
Like Tree8Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Official STS Lockpick Thread in Past Cadillac Vehicle Discussion; Didn't mess with the dip switches, but.... I took it out this morning and noticed I hadn't reconnected the single ...
  1. #76
    ChrisHall is offline Cadillac Owners Member
    Automobile(s): 2008 STS AWD Platinum V8
    Sep 2009
    Ottawa, Ontario, Canada
    51
    84
    Re: Official STS Lockpick Thread
    I took it out this morning and noticed I hadn't reconnected the single wire pink plug. Once I plugged this in, right away the clock started working and within 5 minutes the GPS with a line through it disappeared.
    Problem solved.
    What through me off was that the Nav system while I was driving was moving. Just not showing me in the right location.
    Haven't had a chance to fully test unit yet, but I'm sure it's working properly.
    Cheers,
    Chris
  2. #77
    Joe Pagano's Avatar
    Joe Pagano is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS4 & 2005 STS4
    Feb 2007
    New Jersey
    174
    Welll even though you failed to connect the direct antenna connection the unit will still capture some amount of signal. And in navigation you need to aquire at least
    a few satellites to get a proper fix. Glad you solved it. I am waiting for my LockPick to be delivered. Wish it would have come yesterday before this trip we are on.
    Joe P
  3. #78
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Joe, I think you might not have considered the integration of the VSS into the Nav. If all he was missing was the GPS antenna, it got zero, zip, nada signal. It doesn't pull in the GPS all that great when all is perfect! I think the Nav was just registering the VSS.
    Chris, welcome to the happy community of Lockpick users.
  5. #79
    Joe Pagano's Avatar
    Feb 2007
    New Jersey
    174
    Chas, great point. I got back to town today and found my LockPick delivered. Did the install, and yes, tucking the wires was a pain. I also mounted the switch on the face of the trim panel. Tested the unit real quick and with the switch depressed I had full phone use, also had no time to test video. But, my line through GPS did not go away after 20 - 30 minutes. Was too busy tonight and we used the CTS. Made a quick call to Tomm and he assured me it will come back. Fingers crossed, test drive in AM and I will post.................... stay tuned................ thanks........... Joe P
  6. #80
    Joe Pagano's Avatar
    Feb 2007
    New Jersey
    174
    All is well, LockPick works just fine,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
    Next - chrome wheels !!!!!!!!!!
    Joe P
  7. #81
    Sep 2009
    51
    84
    Hi all,
    When I first start the car the DIC says "Stability Competitive Mode" and the "TC" light is lit. After a couple seconds the DIC switches to "Stability Sys Off". After 20 more seconds, the "TC" light turns off by it self, but the "Stablity SYS Off" remains on the DIC. I can turn on the "Stability Sys".
    My manual says if I install any aftermarket stuff in car things like this could maybe happen. This only started showing up after I installed my "Lock Pick". Could this "Lock Pick" be interferring with something in the computor?
    Please help,
    Chris
  8. #82
    tomm's Avatar
    tomm is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Cadillac CTS VSport
    Feb 2005
    New Jersey
    67
    2,318
    The lockpick does not do anything other that interrupt the GPS Signal and VSS (Vehicle Speed Sensor wire for the Nav) - The two have nothing to do with any TC or Stability Systems.
  9. #83
    BucShot is offline Cadillac Owners Member
    Apr 2005
    10
    Tomm,
    I got my unit today and had it install in abour an hour. Works PERFECTLY and just wanted to say THANK YOU!!!
    BucShot
  10. #84
    sts4ga is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS4 1SG 2005 CTS-V
    Aug 2009
    49
    225
    Tomm,
    I'm interested in a lockpick and a Blinder M47. I noticed that your site only lists the M45. Are you going to carry the 47 in the future?
    Thanks
  11. #85
    Sep 2009
    51
    84
    Hi Tomm,
    Is it possible the VSS interacts with the Tracsion Control? I removed Lock Pick and now the TC button works. I will leave Lock Pick out for a week and see if problem comes back. Then re-install Lock Pick.
    Chris
  12. #86
    tomm's Avatar
    Feb 2005
    New Jersey
    67
    2,318
    Quote Originally Posted by sts4ga View Post
    Tomm,
    Thanks
    Please PM me and I can get you a special price on the Blinder M47, They are in transit to us and we should have them in the next 1-2 days. Sorry for the late response but I was on vacation.
  13. #87
    tomm's Avatar
    Feb 2005
    New Jersey
    67
    2,318
    Quote Originally Posted by ChrisHall View Post
    Hi Tomm,
    Chris
    The lockpick device is directional, It only changes information in the GM Lan going to the navigation. Its probably just a coincidence that they happened almost at the same time.
  14. #88
    Joe Pagano's Avatar
    Feb 2007
    New Jersey
    174
    Hey Tomm,
    Did you ever get more info on the video output for the Nav screen to tap for external monitors? My headrest units will be delivered tomorrow and I would enjoy the cool factor of sending the dash display to those screens.
    And I thank you also for the LockPick and quick service.
    Joe P
  15. #89
    tomm's Avatar
    Feb 2005
    New Jersey
    67
    2,318
    Quote Originally Posted by Joe Pagano View Post
    Hey Tomm,
    Joe P
    There are no video outputs on the STS Navigation unit, It only has inputs. What I had to do in my STS was add an additional DVD player in my glove box which powers my rear headrests. I also have an output from the additional DVD player going to the AUX inputs on the navigation unit so the video can be seen on all three displays at the same time or just the rear.
  16. #90
    STE_6000's Avatar
    STE_6000 is offline Cadillac Owners Enthusiast
    Automobile(s): Cadillac STS 2005
    May 2009
    Baltimore, Maryland
    811
    I don't mean to go off topic here, but tomm i have to compliment you. you keep your product to this single post this whole time, instead of doing multiple postings. it actually makes it an enjoyment to come to this forum and not get a lot of commercial topic flooding. and surprisingly, i always seem to read this cause its all in one posting. ty for keeping it all in one topic
  17. Remove Advertisements
