Official STS Lockpick Thread - Page 5
Page 5 of 38 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 61 to 75 of 558
Like Tree8Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Official STS Lockpick Thread in Past Cadillac Vehicle Discussion; With a modified lockpick video will always play out of park and in drive but the video will cut off ...
  1. #61
    tomm's Avatar
    tomm is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Cadillac CTS VSport
    Feb 2005
    New Jersey
    67
    2,318
    Re: Official STS Lockpick Thread
    With a modified lockpick video will always play out of park and in drive but the video will cut off after 8MPH. This means that it is working as it should be because the lockpick is bypassing the GM LAN command that you are you have shifted out of park. The next thing the GPS unit does is it check the VSS and GPS signal to see if you are moving and once you hit 8 MPH these backup locks kick in.
    On the modifed lockpick the video will continue to work after the 8 MPH and will continue to work until the switch is turned off.
    The GPS Signal however can take as little as one minute to re-calibrate you and I have seen mine take as long as 15 minutes depending on the signal to re-calibrate you. The unit requires signal from 3 different satellites to do this.
    If after driving you do not see the GPS Signal come back and the lockpick button is in the off position (Button Out) you need to check the pink GPS connectors to make sure they are connected properly and inserted all the way in and locked into place. Also check to make sure the center pin on the gps connectors is straight in the center. We have seen some bend when inserted on an angle.
    ________________
    Need a radar detector... Visit us at http://www.BestRadarDetectors.net, we have all the latest models from Escort, Beltronics, Whistler & Cobra.
  2. #62
    gdbradberry is offline Cadillac Owners Member
    Automobile(s): 2006 STS4
    Jun 2009
    48
    8
    Quote Originally Posted by tomm View Post
    Got it. It all appears to be working perfectly, now. GPS came back online about 1/2 way to work this morning.
    Thanks!!!!
  3. #63
    notso1951 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2008
    22
    I'm a new 06 STS owner and have been following the on going discussion about lock picks. Here's my question----what does the lock pick do? From what I can figure out by reading alot of threads it allows you to play DVD and have full use of navigation while driving. Is this correct? If so and if I order one who could I get to install this in my car being the electronic dummy that I am! In advance thanks for anyone that will offer the info I request.--Dave
  5. #64
    ssstealth's Avatar
    ssstealth is offline Cadillac Owners Enthusiast
    Automobile(s): 06 STS-V, 94 Fleetwood TS
    Jan 2003
    Winston Salem, NC
    52
    755
    Take note when you are driving. Any button that "grays out" once you start moving will be available after the lockpick is installed.
  6. #65
    ChrisHall is offline Cadillac Owners Member
    Automobile(s): 2008 STS AWD Platinum V8
    Sep 2009
    Ottawa, Ontario, Canada
    51
    84
    How does one view the MP4 installation instructions on sheet 1 of this forum?
    Cheers,
    Chris
  7. #66
    MacMuse is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS N* 1SE
    Feb 2009
    Chicagoland
    54
    2,399
    http://www.apple.com/quicktime/download/
    clear the checkmarked boxes, and you don't need the Pro version. The free version will be fine.
  8. #67
    trackbait is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS - Grey/Black Northstar NAV
    Apr 2009
    DFW area
    198
    Quote Originally Posted by notso1951 View Post
    Righty tighty, lefty loosey with a 10 mm socket. You can do that. If you can plug in a light to a wall socket, you can do this install. There is nothing difficult about the "electornics" - it's all plug and play - you can't hook it up wrong unless you are blind. All are color matched.
    The hardest part (if you want to call it hard) is fitting all the extra wire back behind the unit so it will go back in flush. A fifteen minute job, max!
    The most 'sensitive' part you will encounter is the GPS antenna connection and wire. It's obvious which one it is.
  9. #68
    Joe Pagano's Avatar
    Joe Pagano is offline Cadillac Owners Fanatic
    Automobile(s): 2010 CTS4 & 2005 STS4
    Feb 2007
    New Jersey
    174
    So if I put one in my 05 I would keep the switch off until I needed to access the "grayed out" features. And once I do that I would loose my satellite signal, correct? Then my GPS would re initilize once I put the switch back to off?
    Now, the site tells me that they are out of stock. When can we make a purchase?
    Thank you for the very informative information and this most welcomed mod............................. Joe
  10. #69
    tomm's Avatar
    Feb 2005
    New Jersey
    67
    2,318
    Quote Originally Posted by Joe Pagano View Post
    Yes, You are correct in how it operates. We have the parts in stock and if ordered today or tomorrow it would ship on Monday. We have corrected the backorder issue on the website.
  11. #70
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    XM Radio will continue to work just fine. With the Lockpick engaged, your Nav will get lost but just disengage the Lockpick and it will find itself in a bit. It's a fine trade-off and Tom's a quality guy.
  12. #71
    Joe Pagano's Avatar
    Feb 2007
    New Jersey
    174
    Tomm,
    Just ordered my LockPick (05 STS) on your site. Looking forward to the upgrade. But a quick question. That switch I need, can you post a close up of it? I want to prepare the install and decide where I will mount that switch and if I need to find one other than the one supplied based on the location I plan to place it.
    Thanks very much.................................... Joe P
  13. #72
    tomm's Avatar
    Feb 2005
    New Jersey
    67
    2,318
    Tomm,
    Great, Just note it has to be built and we will have it made and shipped within 2-3 business days. You will have it before the weekend.
    Take a look at post 23 for a detailed picture of the activation switch and our recommended location:
    http://www.cadillacforums.com/forums...-thread-2.html
  14. #73
    Joe Pagano's Avatar
    Feb 2007
    New Jersey
    174
    So is it that round rocker type mounted in the power port or the small red push type tucked in the crevace of the console tower and rug?
    And thanks again.................. Joe
  15. #74
    Sep 2009
    51
    84
    Just installed my lock pick.
    Couple problems.
    GPS thinks I'm about 20 miles east of my actual position and clock is not displaying time at all. GPS symbol after 1.5 hours still has a line through it.
    Cheers,
    Chris
  16. #75
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Did you mess with the switches? Tomm generally sends them out ready to go.
  17. Remove Advertisements
