Official STS Lockpick Thread - Page 26
Page 26 of 38 FirstFirst ... 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 ... LastLast
Results 376 to 390 of 556
Like Tree8Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Official STS Lockpick Thread in Past Cadillac Vehicle Discussion; Originally Posted by Wilsonj45 I ordered, received, and installed the NU-STS on my 2010 STS, very easy 10 minute installation ...
  1. #376
    tomm's Avatar
    tomm is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Cadillac CTS VSport
    Feb 2005
    New Jersey
    67
    2,318
    Re: Official STS Lockpick Thread
    Quote Originally Posted by Wilsonj45 View Post
    I ordered, received, and installed the NU-STS on my 2010 STS, very easy 10 minute installation and all appears to be working with one exception. When the NU-STS is activated I can enter an address in the navi, but when the route is selected the nav arrow on the screen acts as though the car is standing still. If I disable the NU-STS it acts as normal. If I reactivity the system, it freezes and acts if the car is still again. Wondering what may begging on.
    John
    This is normal as explained a few times in this thread. When you activate a lockpick it tricks the navigation system into thinking that you are not moving which is why it unlocks all the locked functions. The navigation system will automatically re-lock if it senses that you are moving therefore your VSS (Vehicle Speed Sensor) is disabled when the lockpick is activated. If you need to make changes to your trip in motion you need to activate the lockpick, makes the changes and then disable it and your navigation will re-calibrate you back on your trip.
  2. #377
    LewisR is offline Cadillac Owners Member
    Automobile(s): '09 STS, '95 Eldorado, '68 Coupe de Ville convert
    Sep 2004
    Long Island, New York, USA
    20
    QuestionRe: Official STS Lockpick Thread
    Steering wheel heater button issue:
    Got my LockPick a few weeks ago, and really enjoying it.
    We're in the midst of a cold snap in the northeast, so I don't recall whether I tested the steering wheel heater before today. I am getting no response from that side of the button. I haven't looked at the wiring diagram for the controls, but wanted to see whether this may have presented for someone else.
    TIA
  3. #378
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Nothing to do with it.
  4. #379
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    1,920
    Broken heated steering wheels are common and hard to fix because of a lack of parts (the steering wheel).
  5. #380
    KRSTS Guest
    The heating element inside the wheel commonly fails, requiring a wheel replacement. GM doesn't have a very large stock of the various model wheels and I'm told the source is TU so it is a crap shoot whether a dealer can find a replacement. If you are out of B2B warranty, the wheel is very pricy if one can be found. A wheel from a salvage yard will most likely also have a bad heater.
  6. #381
    zlgibby is offline Cadillac Owners Member
    Automobile(s): 01 Eldorado ETC
    Oct 2012
    Minnesota
    40
    So I order my lockpick for my 05 about a week and a half and haven't heard back from tomm, figured he's pretty busy I was just curious if he got enough people to do the group buy the last chance before he is done. Anyone else buying one ( a modified one)?
  7. #382
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I remember reading that GM had found another vendor for a short run of STS heated steering wheels. Availablity can be expected to be better, pricing even higher.
  8. #383
    Sep 2004
    20
    Quote Originally Posted by KRSTS View Post
    Thanks. This one was replaced once under warranty, when I first got the car. However, what prompts my question here is the timing of the issue relative to my installation of the Lockpick. I used the wheel heater all winter with no problems, and right after I do the install, the next time I use it, it doesn't come on. It's not just that the wheel doesn't heat; the light doesn't come on. This indicates to me not a bad element, but a grounded condition at the switch.
  9. #384
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,482
    maybe you have a faulty switch?
  10. #385
    Sep 2004
    20
    Quote Originally Posted by Ludacrisvp View Post
    If it weren't for the timing of this issue and the installation of the Lockpick, that would be my primary suspect. I doubt it's anything physically wrong with the switch, unless pressing the SRC side of it did something (I never use that button to change the radio source, preferring to use the control on the radio itself). I thought I'd check here first before tearing the wheel apart (and I'm not really prepared to do that with an airbag-equipped wheel).
    Thanks.
  11. #386
    ddgm is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS
    Jun 2009
    Hamilton, ON & Fort Myers, FL
    270
    I believe that the heated steering wheel is thermostat dependent. If it's not cold enough outside it won't come on. ddalder probably knows.
    Doug
  12. #387
    KRSTS Guest
    Quote Originally Posted by ddgm View Post
    Doug
    Mine works hot or cold.
  13. #388
    Jun 2009
    1,920
    Also, I've read other reports on here where they said the light wouldn't come on and the wheel still had to be replaced. I agree, you wouldn't think it would be a bad heating element in that case though.
  14. #389
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    It shouldn't.
    Lew - I'd hope for a fuse, but coincidences DO happen.
  15. #390
    tomm's Avatar
    Feb 2005
    New Jersey
    67
    2,318
    Sorry for the last of posting lately. Last batch of STS Lockpicks are being produced even though many people who originally committed never came through with payment. In any case we ordered all the parts and are building the harnesses right now. First few will ship next week and the balance the following week. There is a no chance that the lockpick would have any effect on the heated steering wheel especially since the modified lockpics do not even have any GM Communication to the steering wheel controls and they are operated 100% from the switch included on the harness.
  16. Remove Advertisements
