Official STS Lockpick Thread - Page 23
Page 23 of 38 FirstFirst ... 131415161718192021222324252627282930313233 ... LastLast
Results 331 to 345 of 567
Like Tree8Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Official STS Lockpick Thread in Past Cadillac Vehicle Discussion; Originally Posted by targetSTS Hi Tomm, I have just installed lockpick: it has 2 connectors+gps antenna connector+red button at my ...
  1. #331
    eatyoursandwich is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS N*
    Jan 2012
    Austin, TX
    31
    265
    Re: Official STS Lockpick Thread
    Quote Originally Posted by targetSTS View Post
    Hi Tomm,
    I have just installed lockpick: it has 2 connectors+gps antenna connector+red button at my 2005 sts w\o mute button.
    The problem is: when I turn the lockpick on -it works, but gps antenna turns off. Is it normally how it works or I miss smth?
    The lockpick is designed to work that way.
    When you activate the lockpick, it interrupts the signal between the GPS, VSS, (vehicle speed sensor), and the car. There is no way to utilize the lockpick and the GPS at the same time.
    If you want a GPS signal, switch off the lock pick.
    When the lockpick is on, the GPS signal is interrupted.
    No way to use both at once.
  2. #332
    tomm's Avatar
    tomm is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Cadillac CTS VSport
    Feb 2005
    New Jersey
    67
    2,318
    Quote Originally Posted by eatyoursandwich View Post
    Exactly correct. This is mentioned numerous times throughout this thread.
  3. #333
    targetSTS is online now Cadillac Owners Fanatic
    Automobile(s): 2005 cadillac STS AWD 1SG
    Mar 2011
    34
    410
    ok, thanks a lot.
  5. #334
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Sheesh! Does everybody want to save their cake and eat it, too?
    Thanks again, Tomm. Hope all is well with you & yours... Gift us a new pic sometime.
  6. #335
    tomm's Avatar
    Feb 2005
    New Jersey
    67
    2,318
    Quote Originally Posted by EChas3 View Post
    HA! All is good. I should change my Avatar - My son in that picture is now 9! Wow time certainly does fly by.
  7. #336
    Neko98 is offline Cadillac Owners Member
    Automobile(s): 2006 sts
    Sep 2012
    42
    32
    Hey Tomm. Looking to be buying your lockpick for a 06, I have the link which is believe is the right one. It's $299 for the 06 model correct? Once I get my map disk hopefully this week and make sure the nav fully works, ill be placing the order, thanks. Kenny.
  8. #337
    tomm's Avatar
    Feb 2005
    New Jersey
    67
    2,318
    Yes, You need the $299 modified lockpick. Its the same unit for all 2005-2007's.
  9. #338
    bmireles is offline Cadillac Owners Member
    Automobile(s): 2006 STS-V
    Dec 2011
    just installed on 2006 Sts V. unit received from Tomm fast and easy install. works great. Lockpic was installed in 10 mins or less. but it took me about 1 hr to figure out how to fix that pesky ashtray locking itself issue I've had since owning the car. now both are working great. thanks
  10. #339
    carter's_sts is online now Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    2,031
    Same here. Installed this weekend. Awesome. Now both my regular and V have them. Would hate to not have them.
  11. #340
    Jun 2009
    2,031
    Did take me longer than 10 minutes though :-)
  12. #341
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Since I also have an uPAC-STS, my most difficult step was to position all the wiring & connectors while refitting the Nav. I finally used a lightweight string looped through the harness & dash. Once the Nav was reinstalled, a couple yanks and the string was removed.
  13. #342
    Scotty454 is offline Cadillac Owners Member
    Automobile(s): 2007 Black Raven STS-V
    Nashville, TN
    35
    Tomm, I bought one of your lock picks for my 2005 STS and it worked great. I now have a 2007 STS-V and want to get one for it. I know you have said several times that the 2007s need the modified pick. I do have the mute and source buttons on my wheel and just wanted to check that I still need the modified pick before placing my order.
    Thanks for making a great product.
  14. #343
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,559
    Quote Originally Posted by Shar55on View Post
    Installation is relatively the same in all STS's with the following exception.
    Your pictures don't seem to work
  15. #344
    Jan 2012
    Austin, TX
    31
    265
    Quote Originally Posted by Scotty454 View Post
    You would still need the 2007 version.
    The wheel where you would not need the modified version looks like this: 2008+
  16. #345
    tomm's Avatar
    Feb 2005
    New Jersey
    67
    2,318
    Sorry for the late response. Being in NJ we were hit with the Hurricane and we have been without power for a week. Yes, Even with the mute button on the 2007's you still need the modified Lockpick. Only the newer Style 2008+ with the new Steering wheel's do not need the modified units.
  17. Remove Advertisements
