Official STS Lockpick Thread - Page 13
Page 13 of 38 FirstFirst ... 34567891011121314151617181920212223 ... LastLast
Results 181 to 195 of 567
Like Tree8Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Official STS Lockpick Thread in Past Cadillac Vehicle Discussion; Hi Tomm, I ordered a lockpick from you over a year and a half ago for my 05. It has ...
  1. #181
    TobyJohnson11 is offline Cadillac Owners Fanatic
    Automobile(s): 2014 XTS V-Sport Platinum, 14 Ram Longhorn
    Jan 2008
    Tennessee
    228
    Re: Official STS Lockpick Thread
    Hi Tomm,
    I ordered a lockpick from you over a year and a half ago for my 05. It has worked great with no problems. (Thanks again)
    Now my XM radio is not working. It says no signal. I can’t even get the preview channel. I called XM and they did a test and said it was defiantly something in the car radio.
    I took it to my dealer (who knows about the lockpick and does not have a problem with it) and he wanted me to remove the lockpick prior to them looking at the radio.
    I am not real happy with having to remove the lockpic, when I don’t think it has anything at all to do with the problem. Anyway if I do have to remove it, since it was one of the first ones you produced, I was just wondering if there was anything new or updated out since I purchased this one. I would just as soon have a new one in case I damage this one taking it out.
    Please Advise
    Thanks
    TJ
  2. #182
    glider is offline Cadillac Owners Member
    Automobile(s): Cadillac deville dts 2001
    Oct 2007
    new jersey
    1
    Lockpick was delivered 9/7 and just got around to installing it on 2008 sts 9/10 Works as stated and easy job after seeing video Thanks alot for great product and fast shipping.The only trouble was with the wires and that was because I didn't want to back into the house to find a flashlight After 3 tries and then getting light, positioning wires, was easy to insert unit into place
    Thanks
  3. #183
    tomm's Avatar
    tomm is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Cadillac CTS VSport
    Feb 2005
    New Jersey
    67
    2,318
    Quote Originally Posted by TobyJohnson11 View Post
    Hi Tomm,
    Please Advise
    Thanks
    TJ
    Sorry for the delay (Not sure my my subscriptions are not sending emails) But in any case the original STS Lockpicks were different but the methods are the same. We just from doing so many over time modified the harness slightly, used different relays and smaller relay housing. There should be no issue removing the unit and re-installing it.
  5. #184
    tomm's Avatar
    Feb 2005
    New Jersey
    67
    2,318
    Quote Originally Posted by mosssa View Post
    Dear Tomm,
    I really don't know if there is such solution? but I have been wondering? Why a hardware solution? Why there isn't a software solution?
    I am wailing to pay for any available Software solution to unlock TV, DVD, Radio and Navigation functions while driving for my STS-V 07.
    Thank you,
    Lockpicks work perfectly as designed and leave nothing behind to show you modified anything. Besides it being illegal to modify the firmware in these units you also would immediately void your warranty on the head unit and also your warranty could be voided on any device that connects to the GMLAN Databus. Many units are Bricked when getting the factory firmware legit updates, Using a hacked firmware which no one would support anyway would lead to many dead navigation units and they are extremely expensive to replace. You will never find anyone hacking the firmware when lockpicks are the easy and sensible solution.
  6. #185
    bamccoy is offline Cadillac Owners Member
    Automobile(s): 2008 sts
    Jul 2010
    4
    Hello Tom,
    Finally installed with the modified harness. Everything is working perfectly. Thanks again for the help.
    Bill
  7. #186
    AirForce81 is offline Cadillac Owners Member
    Automobile(s): STS
    Jun 2009
    36
    Tomm,
    I installed my lockpic on my 05 STS and I am having a bit of trouble with it. I click the override button and it will display the video for a few seconds and then go to the screen saying picture not availble while driving. It will bouce back and forth between this screen and the movie. Not sure whats going on. Do you have any ideas?
  8. #187
    Jul 2010
    4
    Quote Originally Posted by AirForce81 View Post
    Tomm,
    I have an 08 built in Nov of 07. Mine did the same thing in about 30 sec intervals. I’m now using the modified harness and all is well.
    Tom explained my Nav unit may have been an older one where the signal keeps telling the Nav the car is in motion so it then switches off the video and immediately the lock pick tells it to play again. For me, mine would be playing the movie, then the screen would flash and the movie would come back on with all the menu buttons. I’d have to touch the screen to clear the menu buttons each time.
  9. #188
    Automobile(s): STS
    Jun 2009
    36
    Yes...that is what mine is doing. Is there any fix for the problem? I have the lockpick with the override button.
  10. #189
    tomm's Avatar
    Feb 2005
    New Jersey
    67
    2,318
    On an 05 with the modified lockpick all Dip Switches need to be in the OFF position. If you followed the install video you probably set Dip 5 on but that is only for 2007+ units without the modified lockpick. If you have a modified unit and its causing this issue your dip settings must not be set correctly.
    You will need to disconnect the lockpick from the harness and make the changes and reconnect it.
  11. #190
    Automobile(s): STS
    Jun 2009
    36
    Quote Originally Posted by tomm View Post
    Thank you Tomm! I will try give this a try.
  12. #191
    tomm's Avatar
    Feb 2005
    New Jersey
    67
    2,318
    How did you make out? Want to make sure its working for you.
  13. #192
    Automobile(s): STS
    Jun 2009
    36
    Hey Tomm...I finally got to my lockpick this past weekend. Now I followed your instructions and after looking at the lockpick all dip switches were in the off position. So I disconnected and reconnected and I am getting the same problem. Its weird because if I adjust the volume or skip chapters it comes up with "picture not available while driving. Then if I dont mess with anything it will play, sometimes minutes at a time, and then just go to the Picture Not Avail" screen. Do you have anymore suggestions or is there something I could be doing wrong, or possible faulty unit?
  14. #193
    tomm's Avatar
    Feb 2005
    New Jersey
    67
    2,318
    AirForce81 please call me tomorrow anytime after 12 Noon EST. 1-888-229-7494 Extension 84, It will be easier to just troubleshoot with you over the phone than going back and forth in the forums.
  15. #194
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Hey Tomm, I'm about to install a upac STS with my lockpick. I believe they share one plug. Does it matter which order they are plugged in? Should the upac or the lockpick be plugged directly into the unit? Its an 05 STS with the modified lockpick obviously. Thanks!
  16. #195
    tomm's Avatar
    Feb 2005
    New Jersey
    67
    2,318
    Based on my quick glance on how the UPAC works my best guess is that it should not matter. My concern is the space behind the Navigation unit for another harness. It's going to be real hard getting the unit back in with two harnesses.
  17. Remove Advertisements
