STS Cabin Air Filter Change - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Like Tree2Likes
Cadillac STS Forum - 2005 through 2012 Discussion, STS Cabin Air Filter Change in Past Cadillac Vehicle Discussion; It helps if you follow the instructions in the factory service manual. It's a five minute job, at the most....
  1. #31
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,264
    Re: STS Cabin Air Filter Change
    Don't mess with Binky Bear!
  2. #32
    KRSTS Guest
    Quote Originally Posted by dkozloski View Post
    I would like to time you LOL
  3. #33
    cadillacmike68's Avatar
    cadillacmike68 is offline Cadillac Owners Connoisseur
    Automobile(s): 68 DVC, 96 FLTWD Brg, 09 STS N* Platinum, 11 CTS Premium
    Jan 2005
    Left the desert - Back in FL
    55
    1,300
    I wonder what Andy really feels WRT the newest American cars!
    But as one who currently owns a 1968, 1996, 2008 & 2009 Cadillacs and used to own 1969, 1970, 1973, 1995, 2000, & 2005 Cadillacs (& a 1966 Lincoln), I can sense some of his frustration. The 68, 69, 70, & 73 were much easier to work on, and even the 59 & 96 (both Fleetwoods) were not so bad. The 2000 (Eldorado) was a service nightmare, and while the 05, 08 & 09 are RWD (or AWD) the plethora of electronics and emission control jibberish in the engine compartment makes it a very daunting task to even locate something like the PCV valve or change the spark plugs.
    On the other hand these newest ones have a a host of creature comforts, they handle better, have excellent driver aids & better stereos, have more real Net power (maybe my 1968 overhauled 472 might have something to say about that!) AND they get better fuel economy.
    You'll notice that with the exception if the 1973 (my first cadillac when i was still in HS, and didn't know as much) I don't own anything from 1971 thru 1994 (although I'd buy a 1992 Brougham d'Elegance with the 5.7 if i could find one! ).
    Binky, where the hell do we get the service manuals for these cars (and the 2008 & later CTS)?? I have them for all my older Cadillacs, but not these two recent acquisitions.
  5. #34
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,264
    Quote Originally Posted by cadillacmike68 View Post
    www.helminc.com
    Quote Originally Posted by KRSTS View Post
    The first step is to pull the hood strut off and prop the hood straight up. I use an old broom handle. Using a DeWalt screwdriver you pull out the three screws holding the inlet screen. You work the latches and pull out the old filter. You replace the old filter with the new filter and reset the latches. Because the hood is out of the way it's duck soup. Replace the screen and the three screws. Remove the broom handle and push the hood strut back on the stud.
  6. #35
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,951
    That was my theory on making it easier too...getting the hood out of the way. I had not actually tried it yet, so thanks for confirming it!
  7. #36
    Cadjiek is offline Cadillac Owners Fanatic
    Automobile(s): 2015 xts Premium fwd 2009 CTS AWD
    Apr 2009
    468
    Well I finally found the filter. The mistake I made was I thought that after the inlet grill was removed the filter would be exposed. It's not. There is that plastic cover that snaps off. Pulled it out, cleaned it up and put it back. I only have 27,000 on the car so it was still pretty clean. Koz is correct. 5 minute job. No broom handles needed either. The hardest part is reaching for the end screw.
  8. #37
    LewisR is offline Cadillac Owners Member
    Automobile(s): '09 STS, '95 Eldorado, '68 Coupe de Ville convert
    Sep 2004
    Long Island, New York, USA
    20
    Thumbs upRe: STS Cabin Air Filter Change
    I let mine sit a bit longer than I wanted, and let it slide by a couple oil changes back (the original filter). Now, at 82K, my '09 was in pretty dire need of this. The car went in to the dealer for service (SHIFT TO PARK issue), and the dealer changed the shifter and the battery (which drained once at a garage with the dumb SHIFT TO PARK message beeping all day), and warned me that the engine air filter was dirty as was the cabin filter. While all of the warranty work was covered, they quoted me $79 for the engine air filter and $119 for the cabin filter... LOL! On Amazon, I got the cabin filter (AC Delco CF133) for $25.80 and the engine element (AC Delco A2944C) for $21.85. With Amazon Prime, I had no shipping, either. First time out for the cabin filter, as I say, and at 82K it was pretty nasty. To change both took me 15-20 minutes, and the biggest delay was figuring out that the cabin filter was so flexible. I agree that working on my '68 de Ville convertible is in general a good deal easier (and all of the parts, I think, are made in the USA, like my '63 Bonneville convert), but then, neither the '68 de Ville nor the '63 Bonneville has a cabin air filter, so it's kind of hard to compare that particular component replacement. The air cleaner, of course, is a much bigger pain on *all* of the newer cars, but surely nothing requiring an engineering degree. Thanks to the original poster for the excellent photo of the cabin filter location; that was worth a thousand words. Cheers, all.
  9. #38
    Hoosier24 is offline Cadillac Owners Member
    Automobile(s): 2009 STS
    Aug 2011
    57
    54
    Just want to say thanks for this post. I would never found it without the pix.
    ahmaduhhs likes this.
  10. Remove Advertisements
