Results 1 to 11 of 11
Thread: 8500 X50 Hardwire
    BlackedouT STS is offline Cadillac Owners Member
    Automobile(s): 2005 STS V8 (1SF JE5), Corsa, JL, 22" Lexanis
    Mar 2008
    South Carolina
    34
    53
    8500 X50 Hardwire
    I am going to hardwire my Escort 8500 X50. Does anyone know how to remove the front overhead console? Thanks!
    Mar 2008
    South Carolina
    34
    53
    Re: 8500 X50 Hardwire
    I figured it out, but for future reference the front and rear overhead light consoles just pull down. they are held in place with metal clips. For wiring there are two options. 1. catch power off of the rear view mirror. The switched power in the mirror is the pink wire (pin #15) and the ground is the black wire. 2. You can tape into the dome light wires. The green with a white stripe is power and the ground is black. The dome light wires keep power for ten minutes after the car is shut off then regain power when a door is opened or the car is running.
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    Sep 2003
    DETROIT
    35
    22,381
    Thanks! I'll add this to the FAQ.
  5. #4
    tigers2007's Avatar
    tigers2007 is offline Cadillac Owners Member
    Automobile(s): '06 STS AWD V6, '99 Deville
    Mar 2009
    68
    I hate to wake up a sleeping bear but does anyone have any idea how much juice I can pull through that little pink wire? I'm assuming it powers everything up there but I need to have 2AMPS for an accessory that I'm mounting up there.
  6. #5
    doowap57 Guest
    Thumbs up Re: 8500 X50 Hardwire
    I did the same thing, with the same results, I used a Rocky Mountain
    Radar /with a built in Scrambler the model 450 that talks, so you don't have
    to take your eyes OFF the road, and it does power down after a while.
    as far as the 2 amps , just do it, I don't think it will blow a fuse, and the
    wiring is definitley big enough, the worst case is to put a larger fuse,
    3 or 4 amp to compensate for your added option.
    Oh Yeah , to mount the detector, I just used Suction cups, with silicone
    to the windshield, let it dry, the wire goes out the front of the console,
    cut a little hole in front, for the wire, NOT SEEN,Yes the sun shades will not go forward
    and the detector hides behind the black out on the windshield, NOT SEEN, SO STEALTH.
    LOw enough, for the Prism to pick up rear threats, RIght NEXT to the mirror,left side of course.
    I powered mine OFF the dome lights,with ALL the things the mirror does, Leave them alone.
  7. #6
    WillySTS is offline Cadillac Owners Enthusiast
    Automobile(s): none
    Feb 2006
    Los Angeles
    65
    627
    Quote Originally Posted by doowap57 View Post
    Is it mounted low enough on the glass to get a GPS signal?
    I thought about hard wiring mine but, It needs a clear view of the sky to get a GPS signal so that it knows where it is to remember traps and blocked signals.
  8. #7
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    My Bel hides behind the visor when down but otherwise visible, just below the heavy window tint. The mirror provides switched power.
    I first tried that location because the RADAR detector display reflection disabled the Intellibeam. Now I like it better!
  9. #8
    KARL DAHLEN is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac 2008 STSV6 RWD
    Sep 2008
    Virginia
    74
    266
    Smile Re: 8500 X50 Hardwire
    Quote Originally Posted by BlackedouT STS View Post
    What is the best way to get to the wires in the RV mirror without screwing it up? Thanks.
  10. #9
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I used self-sealing telco wire taps, compress to lock. Tomm's site sells power taps that have tabs that insert into the OEM connector.
  11. #10
    Sep 2008
    Virginia
    74
    266
    Quote Originally Posted by EChas3 View Post
    How do I find Tomm's site?
  12. #11
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
  • You may not post replies
