Keyless FOB - Page 2
Results 16 to 30 of 44
Like Tree3Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Keyless FOB in Past Cadillac Vehicle Discussion; Originally Posted by Frikiton My current FOB is #2, do I require #1 ? I noticed w/ my #2 I ...
  1. #16
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,785
    Re: Keyless FOB
    Quote Originally Posted by Frikiton View Post
    My current FOB is #2, do I require #1 ? I noticed w/ my #2 I can't remote start even though I have remote start enabled on my personal settings in my car.
    You need to remember that the number printed on the fob may mean ABSOLUTELY NOTHING. This is a number GM prints on the case so the owners can differentiate which is which. The part numbers for #1 and #2 are different only because of the number printed on the case. GM doesn't produce a key fob with the number 3 or 4 despite the fact you can program up to four different fobs for the car. The electronics for both #1 and #2 are identical in function.
    This is easy...
    1. Get in your car.
    2. Start your car.
    3. Look at your Driver Information Centre.
    4. If you opened your car with a fob programmed as #1, it will display one of the following:
    Driver 1 -OR-
    1: Your driver 1 welcome message
    5. If you opened your car with a fob programmed as #2, it will display one of the following:
    Driver 2 -OR-
    2: Your driver 2 welcome message
    6. If you opened your car with a fob programmed as #3 or #4, the DIC will not display a message similar to the ones above.
    While your car is running, you can press the unlock button on each and watch the DIC. You will soon know which fob is #1 or #2. You will require a Tech2 scan tool to sort out whether undetermined fobs are #3 or #4. In any event, this should give you your answer. A fob that is not set-up as #1 or #2 will NOT remote start your car.
  2. #17
    Frikiton's Avatar
    Frikiton is offline Cadillac Owners Fanatic
    Nov 2010
    Manhattan, NYC (NY)
    30
    371
    Re: Keyless FOB
    Quote Originally Posted by EChas3 View Post
    If it's matched as #2 it should remote start. That makes me think it is matched as 3 or 4. Have you done a rigorous test to prove it really is recalling Driver 2 preferences?
    I pressed the wrong button, I read the manual and it said to press the lock button first and then remote start and it worked. I thought it would simply work by holding down the remote start though this way.
    When I go into personal settings it does shows as Driver 2 .. I am still trying to clear how to work that, I need to clear driver 1 and 2 settings .. or maybe leave driver 2 as it is since its what im using
  3. #18
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Keyless FOB
    No need to change anything until you get another fob. If you want a welcome message, just configure it for Driver 2.
    If/when you do get another fob, you'll have to rematch them both to get rid of the old #1. Leave both fobs far away when starting the reprogramming sequence. I think this is in a sticky,but I offered my 2cents somewhere, too!
  4. #19
    ddalder's Avatar
    Aug 2008
    Canada
    2,785
    Re: Keyless FOB
    My advice is to always check the owner's manual when something doesn't work as expected. If you're following the correct procedure, then start troubleshooting problems. It'll will sometimes save a little time and grief.
  5. #20
    Neoalex is offline Cadillac Owners Member
    Automobile(s): STS 3.6 RWD
    Aug 2011
    44
    3
    Re: Keyless FOB
    Hi guys. Can I program the fob to my 2006 using fob 2008+?
  6. #21
    nathanjax's Avatar
    nathanjax is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 esKONali
    May 2004
    Jax, FL
    36
    1,099
    Re: Keyless FOB
    Quote Originally Posted by Neoalex View Post
    Yes
    http://www.cadillacforums.com/forums...-question.html
  7. #22
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Keyless FOB
    I use a 2008-style Fob with my 2006. The stickey-thread at the top of the forum has a link to the matching procedure.
    Frikiton and Frikiton like this.
  8. #23
    tomm's Avatar
    tomm is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Cadillac CTS VSport
    Feb 2005
    New Jersey
    67
    2,318
    Re: Keyless FOB
    Quote Originally Posted by dmokry View Post
    Is there a way I can delete all Fobs and start over? I have two FOBS #1 and #3 are programed in #2 has been lost. I would like to program the #3 into the #2 spot. This is a 2005 STS sg
    Thanks,
    Moke
    Yes, You can easily do this. The instructions are on the site and just do a search for reprogramming the STS fobs on this forum and you will find it. Procedure takes around 30 minutes.
  9. #24
    Frikiton's Avatar
    Nov 2010
    Manhattan, NYC (NY)
    30
    371
    Re: Keyless FOB
    How about if I currently have fob #2 programmed as #2, and I buy a new one lets say model 08 for my 06 sts does it matter if I get a fob #1 or #2 or #3 (according to ebay) or I specifically need to buy one that says fob #1 to program into #1 ?
  10. #25
    nathanjax's Avatar
    May 2004
    Jax, FL
    36
    1,099
    Re: Keyless FOB
    You can program them to whatever number you want, don't need to buy a specific number
  11. #26
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Keyless FOB
    The only differences between fobs with a '1' or '2' is the #.
    OK, the GM Part Number & matching ID codes are different but it's all for appearances.
    I don't think there are all that many unique matching ID codes. Only a determined theif can steal your car (and a determined thief can steal ANY car).
  12. #27
    Frikiton's Avatar
    Nov 2010
    Manhattan, NYC (NY)
    30
    371
    Re: Keyless FOB
    Which 2008+ style you guys have bought on ebay to use on your 06 STS ?
  13. #28
    nathanjax's Avatar
    May 2004
    Jax, FL
    36
    1,099
    Re: Keyless FOB
    I posted a link to that thread post up from yours in post #21...
  14. #29
    FB001 is offline Cadillac Owners Member
    Automobile(s): 2014 SRX
    Jan 2011
    3
    Re: Keyless FOB
    Thanks for the excellent directions. They worked brilliantly, and I was able to program my FOBs. I bought my 2008 STS used and the remote start never worked. Now, after I reprogrammed my replacement and existing FOB, the remote start works. Thanks so much for the assistance.
  15. #30
    Dr. John is offline Cadillac Owners Member
    Automobile(s): 2005 STS
    Jul 2012
    13
    Re: Keyless FOB
    Thanks for the programming instructions. They worked beautifully!
  16. Remove Advertisements
