STS Battery Replacement - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 57
Cadillac STS Forum - 2005 through 2012 Discussion, STS Battery Replacement in Past Cadillac Vehicle Discussion; Originally Posted by jedhead I replaced my battery with a Optima Red Top 78 for $120 Bob Recently? The Optimas ...
  1. #31
    BaTu is offline Cadillac Owners Enthusiast
    Automobile(s): '05 STS4
    May 2008
    668
    Re: STS Battery Replacement
    Quote Originally Posted by jedhead View Post
    Bob
    Recently? The Optimas seem to have gone way up lately.... Last year I bought Yellow Tops for my truck for that. I'd like to find a Red 78 for my '05 and they look like I'd be lucky to find one under $150 (Advanced with a coupon)
    Costco used to be like $130 but, haven't seem them there for a year or more.
  2. #32
    jedhead is offline Cadillac Owners Enthusiast
    Automobile(s): STS-V
    Aug 2009
    Orange County, California
    58
    801
    Quote Originally Posted by BaTu View Post
    When I inquired about the RedTop, the store manager quoted me $120 after looking at the shelf behind the counter. When he pulled the battery off the shelf and scanned it, the battery rang up $149. He gave me the shelf price of $120.
    Bob
  3. #33
    CADDYBLACK99 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-4 1999 Deville Concours
    Oct 2003
    NEW ENGLAND
    57
    1,486
    I will suggest the Sears Gold series DieHard size 78. There is a minor fit issue but it will be greatly reduced if you cut the sliding battery handle off the new battery. The cover fits fine after that and no hood clearance issues that I can see. Just under $100 installed. Alternator and starter are 100% ok, battery was shot (original batt born 5/2005) I feel that a 6 yr old battery in this power thirsty high tech STS was remarkable!
  5. #34
    PzNuts is offline Cadillac Owners Member
    Automobile(s): STS
    Jan 2012
    33
    Great suggestion. The Die Hard 78 fits just fine!
  6. #35
    1harleyman is offline Cadillac Owners Member
    Automobile(s): '98 sts / '06 sts
    Jul 2012
    ohio
    56
    50
    Question, does your '05 have a push button start, and did you have to have the fob reprogramed when you replaced the battery? just wondering about replacing mine in my '06
  7. #36
    JGarten is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac STS V8 1SF
    Nov 2008
    Tennessee
    55
    82
    I have this very battery in my '05 w/push-button start (don't all 2005+ have it?). Replaced it myself. No reprogramming of anything required. You do have to remove the plastic carry handle. Easy-peasy. No issues at all.
  8. #37
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I just installed an Optima 78 (special model with top posts deleted). Prior to doing so, I plugged in a little rechargable compressor so that I wouldn't set off the alarm or lose the express window settings. (Nothing else should be lost.)
    The STS keyless start is standard equipment.
  9. #38
    willysmooo is offline Cadillac Owners Member
    Automobile(s): 2007 STS V-8 AWD ISG, Tuscany seats, per. cooling etc
    Mar 2012
    42
    65
    I need to replace my battery...is it a pain the take the cover etc off? Anything I should know about? I'm just getting one from my local used parts place for 34 bucks. I'm not buying a new one with my miles
  10. #39
    aliskerov is offline Cadillac Owners Fanatic
    Sep 2011
    27
    125
    Just to add my 2 cents - I recently installed the 78 series Yellow Top Optima on my 2005 STS. The only issue I see some of you having is the stock hood - I had mine swapped for an STS-V one (with insulation removed). The two posts at the top of the battery could theoretically touch the aluminum hoods that are the stock STS hoods and short out, which would be pretty tragic, so DO IT AT YOUR OWN RISK. Since the STS-V hoods are fiberglass I don't have that issue. But, depending on the stock hood clearance you could potentially rock an optima 78 series. One member mentioned getting one with the top post removed. I couldn't find it, but sounds like they might be out there. Good luck, guys!
  11. #40
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    They make a 78-series w/o top posts in the Red Top. I haven't seen one for the Yellow.
  12. #41
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    I wanted to be able to remove the battery cover , without removing the cables.
    I got the cover off and slotted the area under the terminals, about 2" wide,
    all the way down to the bottom, NOW, i can pull the battery cover without,
    disconnecting the battery cables.
    Yes, you can do this, with razor a knife, and/or a sheet metal cutter, then
    trim it better, after you remove it !
    Happy motoring.
  13. #42
    Mar 2012
    42
    65
    I found out I could just slide the cover out of the way and change batteries. I buy used parts as much as possible(have a local salvage place that gets wrecked Cadillacs etc. all the time w/ basically no miles on them . So I swapped my AC delco with a battery from a wrecked car($45 bucks) vs $190 for a new one...this is a tad taller than the delco but it actually fits snugger and better with the cover(side posts) Than the AC delco. I must say. I am always amazed that when I disconnect my battery for anything I do, it always seems to reset all the systems and drive better...magnetic ride, steering...etc
  14. #43
    JulesW is offline Cadillac Owners Member
    Automobile(s): STS 2007
    Aug 2013
    62
    1
    While this thread was ultimately a lifesaver, I still took waaaay too long researching. The reason is because I simply could not figure out how a battery that is 7.25 inches wide was possibly going to fit into the less than 7 inch wide slot where the old one was.
    To further add to my skepticism, someone had asked Walmart if the 78N would fit their Caddy, and the answer given on their web page was absolutely no. The same information was on the Sears web site.
    Alas, for anyone who has the same question, I eventually read somewhere that the width measurement includes the terminal protrusions. Feeling more confident I therefore loaded my dead OEM battery on the back of my bicycle and made the trip to Walmart. My understanding is that their 78N not only has better specs but that it rated very highly by Consumer Reports. Combined with a far better price it is clearly the more sensible choice.
    When I arrived I verified that the width and length differ by imperceptible amounts, and sure enough it fit my Caddy like a glove. I did not cut off the carrying strap (just in case the battery had a problem) but still managed to fit the cover on, tucking it tightly under the cowling. With the terminals connected it is not going anywhere. Car started and all is right with the world.
    Bottom line...trust what is being said here. The 78s fit just fine.
  15. #44
    John Oakville is offline Cadillac Owners Member
    Nov 2013
    1
    Just got a new battery from Walmart for my 2008 STS V8. Equivalent stated by Walmart manufacture. $120 plus tax in Canada. EverStart Battery Maxx-H6. Same battery post positions (top), same physical dimensions +/- 5mm at a guess. Fits no problem.
  16. #45
    wake's Avatar
    wake is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 STS-V, 2007 Escalade, 2003 Escalade EXT
    Sep 2003
    Stafford, VA
    812
    Quote Originally Posted by JulesW View Post
    Not quite that simple, it all depends on the battery.
    I have put a group 78 in my STS temporarily and it did fit. I also use a group 78 (group 75 stock) in my Corvette and depending on which manufacturer it comes from it may or may not fit. Some appear to be just a hair taller than others. An Optima fit in my Vette while a Diehard AGM did not, just barely too tall by 1/4 to 3/8 of an inch.
    Group 78 is a standard size class but not necessarily exacting in dimensions and it works fine when you replace a stock battery size for stock battery size as they all have some gap around them for the slight differences in manufacturer sizing. When it comes time to replace the stock size in my STS I'll be taking a tape measure to the store to check the height of a replacement.
  17. Remove Advertisements
