Oil Change Questions - STS V8 NorthStar
Results 1 to 4 of 4
Cadillac STS Forum - 2005 through 2012 Discussion, Oil Change Questions - STS V8 NorthStar in Past Cadillac Vehicle Discussion; I am getting ready to do my first oil change on my 06 STS V8 and can really use some ...
    ajmasala is offline Cadillac Owners Member
    Automobile(s): 2006 STS
    Aug 2007
    Seattle, WA
    50
    I am getting ready to do my first oil change on my 06 STS V8 and can really use some help with the following questions..
    1. I got the car up on ramps last night and took a picture of the underside. I wanted to make sure the bolt highlighted in the picture *is* the drain plug.
    2. It seems like the oil drain plug uses a 13mm socket. Is this correct ?
    3. Is there a washer under the drain plug that needs to be replaced during the oil change. My previous car (a Volvo) had an aluminium washer that needed replacement with the filter - that's the reason I ask.
    4. Does somebody know the torque spec for the oil drain bolt ?
    Thanks in advance.
    Regards..
    Benjamin Simon's Avatar
    Benjamin Simon is offline Cadillac Owners Enthusiast
    Automobile(s): 05 STS V8 1SG with ACC, 99 STS (Sold), 06 CL500 (Wifes)
    Jun 2005
    Middle GA
    34
    960
    Re: Oil Change Questions - STS V8 NorthStar
    Quote Originally Posted by ajmasala View Post
    Yes.
    Yes.
    No. There is a rubber washer on the bolt that does not need to be replaced.
    My spec is as tight as I can get it with 1 hand and no breaker bar.
    I recommend the AC Delco filter. It is like $3.50 at autozone. I fill the filter with oil before I screw it on.
    BirdJC is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS Luxury Performance
    Dec 2005
    111
    pretty sure thats it, if the drain plug is like most gm vehicles I've worked on the "washer" so to speak is really part of the drain plug. I will be all one piece so you shouldn't have to worry about replacing it.. Haven't changed mine myself yet but the days getting close....
    rb92gt's Avatar
    rb92gt is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS V8 Lux, 2011 Escalade EXT Prem
    Aug 2006
    Summerland Key, FL
    38
    283
    That's the plug. No washer to replace. Don't know torque specs. I've changed my oil twice myself and haven't had any leaks (from the plug, damn car leaks everywhere else, lol). I would also recommend the AC Delco filter, it is what came from the factory and it's cheap.
  7. Remove Advertisements
