removal of shifter knob
Results 1 to 14 of 14
Cadillac STS Forum - 2005 through 2012 Discussion, removal of shifter knob in Past Cadillac Vehicle Discussion; how the heck? tired of bringing back to dealer for loose handle......
    BMBSALES's Avatar
    BMBSALES is offline Cadillac Owners Enthusiast
    Automobile(s): 10 CTS-V, 13 ESCALADE, 06 C6, YAM R1
    Mar 2006
    NC
    574
    BMBSALES's Avatar
    Mar 2006
    NC
    574
    Re: removal of shifter knob
    No One Has Removed The Sts Shift Knob?
    Onalaska's Avatar
    Onalaska is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS 1SF, 1990 Allante, 2006 XLR-V
    Oct 2006
    Coldspring, Texas
    65
    270
    Accroding to the factory service manual:
    Note: The picture shows the screwdriver blade placed right between the bottom of the knob and a small trim piece just below the knob. Blade facing towards the front of the car.
    1. Insert a flat bladed tool (screwdriver) between the shift knob and the shift knob trim ring.
    2. Rotate the flat bladed tool to release the shift knob trim ring from the shift knob.
    3. Tighten the shift knob retaining screw to 2 N-m (18 lb in).
    BMBSALES's Avatar
    Mar 2006
    NC
    574
    thank-you very much. for those that are interested, since alot of these knobs are loose in the v...
    the flat bladed tool goes in the rear (closest to back seat) in between the bottom chrome trim ring on the knob, and the woodgrain trim piece, right where you can see it, in park, sitting in the drivers seat. hence the screwdriver facing the front of the car as onalaska stated.
    once you pop the chrom trim ring down off, you can see the torx bolt right there.
    i took mine all the way off, and ran electrical tape once around the shaft, slipped it back on and tightened it.
    TOOK ALL THE KNOB WIGGLE OUT OF IT...and didn't have to take it back to the dealer again.
    tonyzee is offline Cadillac Owners Member
    Automobile(s): 2006 STS Prem Navi
    Feb 2010
    60
    5
    By the way, thanks for the info - I'd like to add it was a #15 torx.
    jerrylsantos is offline Cadillac Owners Member
    Automobile(s): 2006 STS-V
    Jan 2011
    Sacramento, CA
    33
    84
    Bringing this post back from the dead...
    I tried using a screwdriver at the points indicated and just ended up with a dented bottom chrome peice
    Anyone who had success popping it off (down) suggest any certain tool or method?
    Roll on Mr. Spaceman is offline Cadillac Owners Member
    Automobile(s): STS-V
    Aug 2009
    40
    Just saw this thread. This happened to me also.
    "I tried using a screwdriver at the points indicated and just ended up with a dented bottom chrome piece"
    Any hints would be appreciated.
    Thank you.
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,870
    Because I do a lot of work on my vehicles, I invested in a set of non-marring trim removal tools. These are made of plastic and tend to be very gentle on trim parts. Very important when working on the instrument panel, console, shifter, etc. The plastic chrome trim ring does snap into place quite firmly and may be more difficult to pop the first time.
    Aug 2009
    40
    Thank you ddalder.
    Have you ever tried to tighten the shifter knob?
    ddalder's Avatar
    Aug 2008
    Canada
    2,870
    I took mine off when I removed my dash but I've never had a problem with it staying tight since. If you believe it's a case of the set screw loosening (versus a groove developing in the shaft), I'd apply a very small amount of Lock-Tite. Be sure to use the weakest strength (purple if I'm not mistaken - but you best confirm). If you use the wrong type, or apply too much, you will have a heck of a time if it ever has to come off later.
    Jan 2011
    Sacramento, CA
    33
    84
    I ended up using a thin flathead (about a quarter inch wide) to pry it down. If i remember correctly, the "clips" are on the right and left sides, not the front and rear. You wont hear them click out of place or anything; for me it was a slow pry.
    oldcaddybuyer's Avatar
    oldcaddybuyer is offline Cadillac Owners Fanatic
    Automobile(s): 2011 STS | 2013 ATS (03 STS, 96 FWB)
    Jun 2012
    Frederick, Maryland
    377
    Did a search of threads and this is the most recent/relevant. The shift knob in my STS is vibrating and making a noise while idling in gear. Is this the fix to stop the noise?
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,722
    Quote Originally Posted by oldcaddybuyer View Post
    Hello oldcaddybuyer,
    If this is a concern you would like to discuss with your dealer, please let me know. I can be contacted via private message and am more than happy to explore options towards a resolution with you.
    Sincerely,
    Laura M.
    Cadillac Customer Care
  16. #14
    blackcrow64 is offline Cadillac Owners Member
    Automobile(s): 2006 STS4
    Sep 2013
    32
    1
    I just did this today with my STS. It had been loose and rattling since I bought it and it was driving me nuts. Used a nylon pry bar on the backside of the chrome ring and it snapped down but took a surprising amount of force before it released. Tighten up the set screw and voila! Not loose or rattling anymore!
  17. Remove Advertisements
