Cadillac STS Forum - 2005 through 2010 Forum for discussions regarding the new Sigma-based STS model. Not for Cadillac "Seville" discussions (2004 and older).
 | Cadillac Forums: AWD STS4 transmission software fix
11-06-06, 09:23 PM
| | Cadillac Owners Fanatic | | Join Date: Jan 2006 Location: Chicago | | | Re: AWD fix finally, for suffering STS4 owners! Went to the dealer today for something else and thought I'd ask them to look this up just for the heck of it. They couldn't find it under the TSB number or the "chuggle" search, but did find it under the document number. Seems it applies only to STS4's with a V-8 (mine's a V-6). It's not new software, just tweaks the current software to disengage the torque converter clutch after the tranny reaches normal operating temperature. So, no TC induced drag. The TSB says to look for the trouble with V-8's over 20,000 miles. |
11-09-06, 02:55 PM
| | Cadillac Owners Member | | Join Date: May 2005 Location: Beirut - Lebanon Age: 44 | | | Re: AWD fix finally, for suffering STS4 owners! just came back from my trip and called my dealer where i left the car for the last 4 days . he told me they have installed a new software for the tranny , the software was just released ( two or three weeks ago )
also they replaced the rack for the steering noise
i will test the car tommorow and give you the feed back |
11-11-06, 06:52 PM
| | Cadillac Owners Member | | Join Date: May 2005 Location: Beirut - Lebanon Age: 44 | | | Re: AWD fix finally, for suffering STS4 owners! Guys , this is magic
million thanks to Tedasaurus
now my Cadillac is shifting like it should
they simply installed a new software - I don't know what is the Number but it was newly released - if your dealer cannot find it simply print this forum and show it to him
thank you again Tedasaurus , you saved my Cadillac from giving it away
also they replaced the steering rack because there was a claim
also there is an update for the engine software , but I don't know what was it about , but I know that they installed a new software for the engine |
11-11-06, 08:59 PM
| | Cadillac Owners Member | | | | | Re: AWD fix finally, for suffering STS4 owners! Nasser, glad it worked for you as well. Yes it really is a huge difference. It seems that the common information that everyone is able to find is the document number. I don't know why the TSB is not working for some folks but the Doc#1866746 does. |
11-12-06, 04:22 AM
| | Cadillac Owners Fanatic Cadillac(s): STS4/SRX/98 STS/85 Cnv/82 Fleet/76 Cnv/69 Fleet/60Cnv | | Join Date: Jul 2004 Location: Dallas, TX | | | Re: AWD fix finally, for suffering STS4 owners! Quote:
also there is an update for the engine software , but I don't know what was it about , but I know that they installed a new software for the engine | Really glad to hear it worked for you as it did for me. BTW I now have the car at 7,500 ft and it still is doing great. |
12-04-06, 08:49 AM
| | Cadillac Owners Member Cadillac(s): 1997 Eldorado ETC (Z); 2006 STS V8 AWD (1SG) | | Join Date: Aug 2006 Location: Yonkers, New York | | | Re: AWD fix finally, for suffering STS4 owners! I had the fix applied by my dealer. I printed out this string and gave it to him prior to my appointment so that he could research it first if he needed to. Well, the fix was applied and I can't stress what a difference it makes in the driving experience. It feels like a new transmission. This car now drives as it should. Seamless, linear accelleration on inclines. No more sudden downshifts or lurching accelleration. I can't believe Cadillac releases these cars from the factory with the shift logic that my car was delivered with. There must be a reason though. Does anyone have any clue as to why the cars are delivered with this eratic shift logic programmed in? Hopefully, Cadillac corporate visits these websites and gleans some of this usefull information from the field. |
12-08-06, 12:32 PM
| | Cadillac Owners Member Cadillac(s): 2006 sts (awd) | | | | | Re: AWD fix finally, for suffering STS4 owners! I just got my '06 STS4 "fixed" with the application of (I think) this TSB. In my case, there was a vibration (chuggle?) in the driveline on light acceleration, and this fixed that! By reprogramming the torque converter clutch to engage at higher speeds, it also gives considerably smoother shifting compared to before the change. On my paperwork from the dealer, it referenced bulletin 06-07-30-030. If you do a Google search on that, you can read the (brief) description. I originally told them to use the 3456D TSB, and this is what I got. So maybe there is yet ANOTHER way to specify this fix. By the way, this is my first post on this site, and it's been very helpful. Thanks! |
12-13-06, 11:18 AM
|  | Super Moderator Cadillac(s): 4.9 STS and stuff. | | Join Date: Sep 2003 Location: St Louis MO Age: 28 | | | Re: AWD fix finally, for suffering STS4 owners! Much appreciated, Richard! |
03-07-07, 09:41 AM
| | Cadillac Owners Member Cadillac(s): 2006 STS4 V6 | | | | | Re: AWD STS4 transmission software fix Just visited the NHTSA recall site at http://www-odi.nhtsa.dot.gov and did a search on 2006 STS and there are a bunch of recalls, including 4 for the transmission, one of which is a transmission replacement recall!
Ziggy. |
03-09-07, 05:34 PM
| | Cadillac Owners Member Cadillac(s): 2005 Cadillac STS V8 | | | | | Re: AWD STS4 transmission software fix Ok, so my transmission was doing the same thing on my '05 V8. THe bulletin is the same, 06-07-30-030. On the surface it shifts SOOO MUCH better than before.
However, I found an odd quirk with the software update.
When going downhill, at about 38-40 mph, with the foot off the gas pedal, the car shifts back and forth constantly from *I think* 4th to 5th gears. It is like it thinks it is going too fast, so it shifts to 4th to slow down, then when it slows down less than 1 mph, it thinks it needs to 5th gear to retain speed. VERY ANNOYING. To trick it, I put it into manual shift mode to make it stay in one gear going downhill. Otherwise, it shifts every second.
Anyone else having this problem with the software update? |
03-09-07, 05:42 PM
|  | Cadillac Owners Fanatic Cadillac(s): None | | | | | Re: AWD STS4 transmission software fix Quote:
Originally Posted by uiwchris Ok, so my transmission was doing the same thing on my '05 V8. THe bulletin is the same, 06-07-30-030. On the surface it shifts SOOO MUCH better than before.
Anyone else having this problem with the software update? | I have been experiencing the same thing after the reprogram. However, I have a problem with it hard shifting and I thought this reprogram would help with that too, but it didn't. So, I will need to take it back in and address this problem now.  |
03-12-07, 03:59 PM
| | Cadillac Owners Member Cadillac(s): 2005 Cadillac STS V8 | | | | | Re: AWD STS4 transmission software fix Mine still hard shifts into 4th gear |
03-20-07, 07:18 PM
|  | Cadillac Owners Member Cadillac(s): 2008 STS 1-SG, traded in 2005 STS4 1-SG | | Join Date: Mar 2005 Location: Atlanta | | | Re: AWD STS4 transmission software fix I took my 2005 STS4 N* in for warranty service just as I hit the 50k mark. I printed this thread and gave it to the service writer who left it on the seat for the tech. I got it back a couple of days later and what a difference!
This car now shifts the way they described it in the original marketing materials, taking complete advantage of the PAL program (Performance Algorithm Liftfoot shifting). The car accelerates seamlessly with no more stumble accelerating from 10-15 mph. The shifts are extremely smooth but very direct. Cruising at 40-50 mph on a surface street in sD you realize you are in 4th instead of 5th OD, just as it's supposed to be. It will hold in gear (3rd or 4th) as you coast down a hill providing compression braking. Even using manual mode seems better. I hardly ever touch the brakes. This car drives more closely to the feel of a stick shift when in sD with all the convenience of an automatic.
The invoice had the following information: 50015 UPDATED TCM PROGRAM AVAILABLE K5364.7 REPROGRAM TCM TO LATEST CALIBRATION REPAIRS PER DOC 1866746 OLD CAL ID - 24232176 NEW CAL ID - 24238943 WARRANTY CLAIM CODE 18903 PROGRAM WAS NOT AVAILABLE WHEN T.CONV REPLACED I hope this info helps sommeone else out there. |
04-21-07, 12:00 AM
| | Cadillac Owners Fanatic | | | | | Re: AWD STS4 transmission software fix I was not experiencing the same degree of trouble as others but felt the car did not shift nearly as smooth as other caddis i had did. Took the car in for the re program and noticed a big difference, it is much smoother now and downshifts when going down hill to assist with braking. |
06-02-07, 07:57 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: AWD STS4 transmission software fix Had my 05 1sg pkg done today and what a huge difference, my wife even noticed right away. I took a printout of this string as well. Thanks for the info! | | Cadillac Discussion Tools | | |
Censor is ON | | | |
