  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac STS Forum - 2005 through 2010
Cadillac STS Forum - 2005 through 2010 Forum for discussions regarding the new Sigma-based STS model.
Not for Cadillac "Seville" discussions (2004 and older).
cadillac-sts
Cadillac Forums: STS navigation
Closed Thread
  #151 (permalink)
Old 11-27-06, 03:43 PM
BMBSALES's Avatar
Cadillac(s): 07 EXT, 06 STS-V, 06 C6, YAM R1
View BMBSALES's Photo Album
Casino Cash: $2860
Re: STS navigation
Originally Posted by gm_geek View Post
congrats!
told you was not that difficult.
by the way, if some one owns Lexus SUV, it's the same fix
geek...
i'm sure you already knew this, but there is a secondary trigger that disables the above 6mph functions!! in other words, that hack works fine for about 30sec, then it gets a signal from somewhere else, and disables those functions again. what is it?
also, what is process to reset radio?
THOSE OF YOU WHO HAVE NOT TRIED THIS, MAY WANT TO HOLD OFF UNTIL I FIGURE OUT THE REST. GEEK?????
  #152 (permalink)
Old 11-30-06, 08:01 AM
View BucShot's Photo Album
Casino Cash: $350
Re: STS navigation
geek,
I contacted the guys in mexico at mobiletech.com.mx. They said they will have a US supplier in 2 weeks but they did not indicate what the cost of the module will be. I have attached a picture of the module.
I am curious to know if anyon else has contacted them or already has this module and if it really works.
  #153 (permalink)
Old 11-30-06, 09:56 AM
Cadillac(s): Cadillac
View KURT's Photo Album
Casino Cash: $250
Re: STS navigation
Originally Posted by BucShot View Post
geek,
PLEASE KEEP US INFORMED AND JUST WHAT DOES THIS DO?
ALMOST DID THE PREVIOUS GET-AROUND BUT AT LAST MOMENT FOUND OUT IN ONLY LAST SECONDS, WHAT GOOD IS THAT? GLAD I WAITED.
THANKS. KURT
  #154 (permalink)
Old 11-30-06, 05:32 PM
BMBSALES's Avatar
Casino Cash: $2860
Re: STS navigation
that's alot of box for under that dash...for those of you who have had it apart...you know what i mean.
  #155 (permalink)
Old 12-01-06, 05:27 AM
Casino Cash: $250
Re: STS navigation
WE ARE ALL ROBO'S HERE.WHY NOT TELL US A FIX ONLY WORKS SHORTLY. WHY BE ASHAMED,WHY MAKE US DO YOUR SAME MISTAKES. GIVE US THE LOWDOWN AND WE CAN PUT YOUR MISTAKES WITH OWERS AND FEEL MUCH BETTER IN A SHORTER TIMEFRAME. WE ALL UNDERSTAND THAT THEIR HAS TO BE AN EASY SOLUTIOIN TO THIS, NOT SOME QUICK 30 SECOND VAPOR SLIGHT OF HAND. BE RESPCTFUL OF US FOLK.
  #156 (permalink)
Old 12-01-06, 08:11 AM
Casino Cash: $350
Re: STS navigation
THANKS. KURT
Here is the scoop, directly quoted from the an email from Mobiletec.com
========== Begin Quote=============================
The unit will override the following Features
1) DVD DVD Movies Override
2) Map Address input Override
3) Bluetooth screen override
4) XM Category Screen Override
The unit has the ability to do automatic DVD override with out pushing any buttons and it also has manual override in case you want to turn it on and off,
For the map override you need to push the window lock 4xxxxtimes that will activate the map input address while the car in motion
The box is not big it looks big on the picture but is been tested and fit it in the car.....
Retail price for this item is $320.00 USD Interface with installation for about 400 dollars
============End Quote================================
Sounds promising!
  #157 (permalink)
Old 12-02-06, 08:07 AM
BMBSALES's Avatar
Casino Cash: $2860
Re: STS navigation
yes...geek has gotten back to me, and informed me that there is a secondary trigger that slipped his mind. he did say he would look into it for us, but we'll see.
i believe that the other signal comes in the grey plug for those who are inclined.
but for now...i have a switch that i can trip if i need to do something one time...set destination, etc.
  #158 (permalink)
Old 12-10-06, 07:35 PM
yourgmsolutions's Avatar
View yourgmsolutions's Photo Album
Casino Cash: $6192
Re: STS navigation
guys. something interesting hit my brain. After BMB tried to cut VSS wire and that worked only for one time, I'm 100% positive that system does have a gyro built in.
here is something interesting. I was installing one of the newer pioneer nav radio, and customer asked me to by pass e_brake wire, sure, why not, and I grounded, then we went for a test drive and I saw the error message on the screen telling me that vehicle must be in park.
WTF
so I called my body and asked him what's the deal. and he told me that new pioneer nav radio have a gyro sensor built in. so, there is nothing I can do then. few days later I was on one of the Pioneer Nav forum, and the guy there posted a thread on how to fix this issue. and it was crazy simple. on the pioneer harness was an empty pin, and if you insert wire into that pin and ground it, it overide the Gyro sensor.
I hope you guys understand where I'm going with that.
on the connectors behined of STS Radio, are several empty pins.
anyway, I'm out of radio right now,blew up mine (long story)
once I get my radio back I defenately going to try it. for some reason I've got feeling that this is it.
  #159 (permalink)
Old 12-10-06, 08:16 PM
Onalaska's Avatar
Cadillac(s): 2005 STS 1SF, 1990 Allante, 2006 XLR-V
View Onalaska's Photo Album
Casino Cash: $8294
Re: STS navigation
I am looking at the factory service manual. The GPS antenna goes directly into the radio/nav/DVD system. They are using both VSS and GPS to detect movement. You would have to kill your GPS input as well as the VSS signal to trick the system into thinking you were stationary. You can disconnect the GPS antenna or for a test the GPS antenna is located in the dash so to test the theory cut the VSS wire and cover the center of the dash with something metallic like aluminum foil (make sure the nav display is showing GPS with a slash through it) and see if it works then. If it does then the GPS antenna input will have to be switched off with the VSS signal also.
  #160 (permalink)
Old 12-10-06, 09:43 PM
BMBSALES's Avatar
Casino Cash: $2860
Re: STS navigation
i honestly don't think there is a "gyro"
  #161 (permalink)
Old 12-10-06, 10:17 PM
Casino Cash: $6192
Re: STS navigation
read previus posts, it's beed tested already, when I played around with to watch movies in motion, now it's about overide bluetooth and nav in motion.
we need to find STS owner with Nav Radio from Europe or Japan. If they can confirm that they can operate Nav in Motion or blue tooth while in motion. then it's good news for us, coz we can ask them to take their radio out, and take a pic of radio plugs, then I can compare wiring with our plugs, and see the pins,
  #162 (permalink)
Old 12-11-06, 10:06 AM
Casino Cash: $250
Cool Re: STS navigation
Go Ge'm Geek !
Talk About A "work/around"
This Is "around" For Sure.
Kurt
  #163 (permalink)
Old 12-15-06, 04:44 AM
View superoli's Photo Album
Casino Cash: $495
Re: STS navigation
Hello,
I am located and Germany and I have a 2005 STS (Eurpean Version).
Sadly neither the NAV nor bluetooth are working in motion.
BTW: Is there a guide how to dismount the radio?
Best regards,
Oliver
  #164 (permalink)
Old 12-23-06, 09:30 PM
ssstealth's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 06 STS-V, 94 Fleetwood TS
View ssstealth's Photo Album
Casino Cash: $6102
Re: STS navigation
I just saw today that Coastaletech will soon be offering a module for the STS.
http://www.coastaletech.com/GMLOCKPICK.htm
They even have it set up to accept rear view camera input...
Bill Sadler
94 Fleetwood Touring Sedan
06 STS-V Triple Black (2009 SSHS Champion)
09 Charger
www.stealthhotrod.com
  #165 (permalink)
Old 12-24-06, 07:09 AM
View dieguy's Photo Album
Casino Cash: $300
Smile Re: STS navigation
Anyone try one of these yet? Would be interested in hearing how it performs.
Closed Thread
Tags: ,
navigation, sts
attach your bluetooth cell phone to onstar
flash wax for your cadillac
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum
