Results 1 to 2 of 2
    LAC_STS is offline Cadillac Owners Enthusiast Cadillac(s) I Drive: STS
    Nov 2009
    656
    Gas tank "door" not opening properly. Covered under Major Guard???
    Anyone ever had problems with the gas tank door? The spring in there that clicks when you push it and it is supposed to push the door out so you can open it, doesn't work. Sometimes it opens but 90% of the time it doesn't.
    If I had fatter fingers I would have to use a screwdriver or something to get it to open.
    I did find a TSB on the actual spring.
    Bulletin No.: 07-08-66-001
    Date: January 10, 2007
    INFORMATION
    Subject:
    Information on Fuel Filler Door Spring Assembly Replacement
    Models:
    2006-2007 Buick Lucerne
    2004-2007 Cadillac SRX
    2005-2007 Cadillac STS
    2007 Cadillac DTS, Escalade, Escalade ESV, Escalade EXT
    2007 Chevrolet HHR, Suburban, Tahoe
    2007 GMC Acadia
    2007 Saturn Aura, Outlook
    This bulletin is being issued to inform technicians of additional information regarding replacement of the fuel filler door spring.
    If the spring is being replaced for breakage and it occurred during cold temperatures, it may be due to water intrusion. Water may enter through the seams in the housing and freeze. If the spring is pushed in to open the fuel door, the force will cause the housing to separate.
    A new fuel filler door spring will be available in the near future. In the meantime, to prevent re occurrence, engineering is recommending that prior to installing a replacement spring, to apply a flexible sealer such as 3M(TM) Clear Auto Sealer P/N 08551, or equivalent, to the voids (1) on both sides of the spring housing as shown in the picture.
    No freezing temps down here, not even close.
    I stooped by the dealer later Friday but everyone except one service adviser was gone and she didn't know if it would be covered or not.
    If it is covered I will probably wait until I go in there for some other warranty work. I have a $100 deductible so it would be smart to wait.
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Many
    CadillacSTS42005's Avatar
    CadillacSTS42005 is online now Cadillac Owners Enthusiast Cadillac(s) I Drive: 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Jan 2010
    724
    Re: Gas tank "door" not opening properly. Covered under Major Guard???
    Call gmpp and explain the problem, they can usually tell you if its covered or not without a full dealer diagnostic.
Sponsored Cadillac Advertisements (Supporting Members don't see these ads):
Simply register and/or login to remove these advertisements.
  • You may not post replies
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum | kia forte forum | used car savings
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
