Results 1 to 8 of 8
    HexWarrior5 is offline Cadillac Owners Member Cadillac(s) I Drive: 2005 STS 4.6V8
    Dec 2008
    24
    41
    Bass Vibration Rattling
    Hey Guys,
    Depending on the kind of music and how the tracks/CD are recorded, some high bass levels sound good and others tend to make a vibration/rattling sound coming from the rear windshield dash (or whatever you call it) where the subwoofer is mounted. Could this possibly be due to a loose speaker/subwoofer covering or something similar? Any help/insight would be great...also, please share if you are having similar problems.
    P.S. I have an 05 STS V8 with the stock BOSE audio (not the 15 speaker).
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    2010
    Many
    Slee_Stack is offline Cadillac Owners Fanatic Cadillac(s) I Drive: 2005 STS 1SG
    Jan 2010
    GA
    151
    Re: Bass Vibration Rattling
    Quote Originally Posted by HexWarrior5 View Post
    Hey Guys,
    Depending on the kind of music and how the tracks/CD are recorded, some high bass levels sound good and others tend to make a vibration/rattling sound coming from the rear windshield dash (or whatever you call it).
    Rear deck.
    Could be a loose subwoofer or it could be a frequency the woofer doesn't like or can't handle well (distortion).
    It also could be any other loose item that is able to vibrate (panels, glass, headrest, foreign object, etc.)
    I haven't experienced that sort of problem, although I haven't explored the highest volumes of the stereo either.
    char1iebrown's Avatar
    char1iebrown is offline Cadillac Owners Fanatic Cadillac(s) I Drive: STS V8 '07 Z06
    Jan 2010
    20
    223
    Its probably as tight as it can be, and it is the metal grille where the sub is mounted, the vibration is normal, and might be able to deaden the rattling with dynamat. Also remember the cars are tested at optimal or moderate to low volume, not blasting. But if the rattling is occurring with medium volume then something might be loose, but if its rattling while volume is all the way up, then that's normal.
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads):
    bobby_05sts is offline Cadillac Owners Member Cadillac(s) I Drive: 2005 sts v8
    Sep 2009
    Pittsburgh
    23
    44
    I get a lil bit of rattling when bass/volume is high on the window and mirror controls on the driver door, if I hold the controls it stops...is there anyway of tightening this?
    BJD210 is offline Cadillac Owners Fanatic Cadillac(s) I Drive: 05 STS V8
    May 2009
    Midwest
    29
    99
    The overhead consoles seen to be the worst when it comes to rattling. The rear console is worse than the front. The rear deck doesnt seem to be very prone to rattles even though common sense would say different. Get some Dynamat and put it on aything that makes noise IMO
    imaphaetonguy is offline Cadillac Owners Member Cadillac(s) I Drive: 2008 STS 3.6L
    Nov 2009
    NW Houston
    20
    My '08 STS (also with the standard Bose system) does this too. You don't even have to be 'blasting' the music to get the vibration. Happens at normal listening volumes.
    I've purchased a better quality sub, and hope to swap that out with tbe OE woofer soon.
    Joe Pagano's Avatar
    Joe Pagano is offline Cadillac Owners Fanatic Cadillac(s) I Drive: 2010 CTS4 & 2005 STS4
    Feb 2007
    New Jersey
    172
    Try this. Get a piece of cloth about 14 or so inches wide and about 20 inches long, roll it tight and then tuck it where the rear window meets the package tray. Finish off by using something like a wooden ruler to push and bury the cloth deep into the edge, just until you cannot see it.
    I say this because if you go back there and slap down on the tray, in most cases, you will replicate the rattle, with the sound system off.
    I have this issue, but so far I do not have it rattle while driving or blasting my audio.
    Hey, give it a shot, it's free with no down side. Let us know.................................... Joe P
    TimmyC is offline Cadillac Owners Fanatic Cadillac(s) I Drive: 99 SLS and 06 STS4 v8
    Feb 2009
    31
    195
    My window controls rattle too, as well as some other unidentified rattles from both front door panels. My 99 has twice the miles on it and it doesn't rattle like this at all.
Simply register and/or login to remove these advertisements.
  • You may not post replies
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum | kia forte forum | used car savings
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
