  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac STS Forum - 2005 through 2010
Cadillac STS Forum - 2005 through 2010 Forum for discussions regarding the new Sigma-based STS model.
Not for Cadillac "Seville" discussions (2004 and older).
cadillac-sts
Cadillac Forums: Tire Pressure Sensor is Misreading
Old 11-14-09, 10:40 PM
Cadillac(s): 2006 Cadillac STS
View kschwed's Photo Album
Casino Cash: $1055
Once today and once yesterday my 06 sts is reporting that the psi has dropped to 14 psi in the right front tire. Of course the PSI hasnt dropped, but it is telling me that it has. If i continue to drive it will go away after a while and report 32 or 33. Any idea why this is happening and how to fix it?
  #2 (permalink)
Old 11-14-09, 11:00 PM
dkozloski's Avatar
Cold Soaked
Cadillac(s): 2006 STS AWD, '95 Ford Ranger
View dkozloski's Photo Album
Casino Cash: $14852
Re: Tire Pressure Sensor is Misreading
I'd say that the sensor is haywire and needs to be replaced. It's covered under warranty.
Don't mess with Binky Bear!
  #3 (permalink)
Old 11-14-09, 11:39 PM
Cadillac(s): 2010 DI CTS silver, titanium interior
View rchern's Photo Album
Casino Cash: $4005
When you get your tires rotated you have to get the tire pressure monitors reset. If you don't, if for instance you rotated the front right to the right rear if the right front is low it's going to show that the right rear is low and you'll check it with a tire gauge and it will show normal and you'll think the system is bad.
  #4 (permalink)
Old 11-15-09, 12:34 AM
Casino Cash: $1055
Ok, I'm taking it in soon anyways. I'll have them replace it. Thanks
  #5 (permalink)
Old 11-17-09, 11:56 AM
Cadillac(s): sts
View JackG's Photo Album
Casino Cash: $2625
I dont have any valve caps on my tires. Will that cause inacurate readings?
  #6 (permalink)
Old 11-17-09, 12:34 PM
dkozloski's Avatar
Cold Soaked
Casino Cash: $14852
It won't affect accuracy but the TPMS sensors will be subject to contamination and there might be slight leakage. When replacing the caps be sure to get the right ones. There have been reports of the wrong caps corroding and becoming unremovable.
  #7 (permalink)
Old 11-17-09, 02:32 PM
Cadillac(s): sts
Casino Cash: $2625
Are the right ones from Cadillac dealer? or can you link me to some on ebay?
  #8 (permalink)
Old 11-17-09, 06:10 PM
Cadillac(s): Cadillac 07 STS w/1SG Pkg
View pjbizjak's Photo Album
Casino Cash: $2858
Any time you remove a wheel from it's hub and then move it to another hub the TPMS must be reset. Follow instructions in the manual. One hint, befor you reset the TPMS, make sure you have driven the car over 20 mph for a short period. When I do mine I inflate the tires to 35lbs
then proceed with the reset instructions. As I start with the left front tire I let out air until the horn beeps telling me that that sensor is set and do the same procedure with the other 3. When finished check tire pressure and reset to recommended tire pressure.
  #9 (permalink)
Old 11-18-09, 12:27 PM
Cadillac(s): 05 STS
View Greg00coupe's Photo Album
Casino Cash: $1135
Dumb question........... Do the sensors need retrained when you get new tires assuming the same wheels go to the same corner of the car? In other words when a new tire is mounted to a rim and inflated will the sensor work as before or need retrained????
  #10 (permalink)
Old 11-18-09, 03:36 PM
Cadillac(s): 2005 STS 1SF RWD... sexy silver
View fps_dean's Photo Album
Casino Cash: $740
There was a recall for this I believe -- did you have it done
  #11 (permalink)
Old 11-18-09, 10:29 PM
EChas3's Avatar
Cadillac(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
View EChas3's Photo Album
Casino Cash: $5675
Originally Posted by greg00coupe View Post
dumb question........... Do the sensors need retrained when you get new tires assuming the same wheels go to the same corner of the car? In other words when a new tire is mounted to a rim and inflated will the sensor work as before or need retrained????
s/b ok
misreading, pressure, sensor, tire
attach your bluetooth cell phone to onstar
flash wax for your cadillac
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum
