Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac STS Forum - 2005 through 2010
Cadillac STS Forum - 2005 through 2010 Forum for discussions regarding the new Sigma-based STS model.
Not for Cadillac "Seville" discussions (2004 and older).
cadillac-sts
Cadillac Forums: Oil Change Question
  #16 (permalink)
Old 10-10-09, 08:39 PM
EChas3's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
View EChas3's Photo Album
Casino Cash: $4860
Re: Oil Change Question
The N* behavior is well known. Others, less so. I go by the DIC and discount it a bit for occasional dirty conditions. After all, 8 quarts of Mobile 1 should do an outstanding job handling oil's basic four duties:
Lubricate, Clean, Cool & Seal.
I guess I should include 'Pressurize', too. (Modern engines!)
  #17 (permalink)
Old 10-10-09, 11:50 PM
Platinum06's Avatar
Cadillac(s): 06CTS, 07STS-4
View Platinum06's Photo Album
Casino Cash: $1760
I change at 25%...makes me feel im good to it.
  #18 (permalink)
Old 10-12-09, 09:20 AM
Cadillac(s): Cadillac
View porkfarm's Photo Album
Casino Cash: $3092
I am still searching for an oil that the motor will be quiet after 3K miles. M1 0w-30 is the best so far, but I just hate the sound at idle after warmed up, after 4K miles. Tick, Tap clack.
  #19 (permalink)
Old 10-12-09, 09:46 AM
K STS's Avatar
Banned
Cadillac(s): 2006 STS V8, 1999 Seville STS
View K STS's Photo Album
Casino Cash: $3930
try amsoil friend. Ive been using it for a few months now, and that noise you hear (which also drove me crazy) is gone!
  #20 (permalink)
Old 10-12-09, 09:54 AM
Aurora5000's Avatar
Cadillac(s): 2006 STS V8 Blackberry 2004 CTS 3.6 Loaded
View Aurora5000's Photo Album
Casino Cash: $2577
Oil Life Monitor
From bbob on www.bobistheoilguy.com
One thing I can touch on and clear up.....the GM oil life monitor operation and my statement that ZDP (or ZDDP as you tend to call it here...most of the API literature just sticks to ZDP so I tend to use that) depletion is the basis for oil deterioration.
My spelling is poor but ZDP stands for zinc dialkyldithiophosphate which , as it sounds, is an anti-wear compound comprised of zinc and phosphorus.
ZDP is dispersed in the oil so as to be at a potential wear site if a surface asperity happens to break thru the oil film thickness causing the dreaded metal-to-metal contact. A molecule of ZDP must be present at that moment to prevent microwelding at the contact site which will cause material transfer, scuffing, scoring, wear and catostrophic failure. The concentration of ZDP in the oil will determine if there is ZDP present to work it's magic. The greater the concentration...the more likely a molecule of ZDP will be there...and vice versa.
By nature, ZDP is sacrifical. As ZDP is "used up" at a wear site to prevent micorwelding the concentration of ZDP decreases.... So...if you measure the ZDP concentration in engine oil in a running engine it will decrease at linear rate based on engine revolutions. Any given engine has a certain number of high potential wear areas where metal-to-metal contact could occur due to reduced film thickness and/or surface asperities....areas such as rubbing element cam followers, distributor gears, rocker arm pivots, push rod tips, etc...... The more of these areas the more ZDP depletion. The more often these features come in contact the greater the ZDP depletion. That is why, generally speaking, ZDP concentration in the oil, for any given engine, will decrease at a fairly linear rate when plotted versus cummulative engine revolutions. The more times it turns the more contact the more chance for wear the greater the depletion. This is as much of a fact as I could quote ever and is really not speculation or anything. It is proven beyond a shadow of a doubt in many studies. That is why it is ONE of the basis for determining oil life remaining and why it is THE basic premis of the GM oil life algorithm. It is only ONE of the things that determines oil life...but it is the one thing that can be tied to engine operation in a linear fashion and estimated very accurately by accumulating engine revolutions via a counter.
The GM engine oil life monitor counts engine revolutions and accumulates the number for the basis of the oil life calculation. It then adds deterioration factors for operating temperature, start up temperature, soak times, ambient, coolant temperature, etc... There are a LOT of factors that "adjust" or affect the slope of the deterioration but the fundamental deterioration is traced back to the ZDP depletion that is inescapable with engine revolutions. The specific rate of ZDP depletion is readily measurable for any given engine so that is the fundamental item that is first calibrated for the oil life algorithm to tailor it specifically to that engine.
You would obviously like to get the oil out of the engine before the ZDP concentration gets so low that it is ineffective at being at the right place at the right time and preventing engine wear so that becomes the long term limit on oil life for that application.
The other things that determine oil life such a acid build up, oxidation, petane insuluables such as silicon from dust/dirt, carbon or soot build up from the EGR in blowby, water contamination, fuel contamination, etc.... are all modeled by the multipliers or deterioration factors that "adjust" the immediate slope of the line defined by the engine revolution counter as those items can be modeled in other ways and accounted for in the immediate slope of the ZDP depletion line.
The algorithm was developed over the course of many years by several lubrication experts at GM Fuels and Lubes, spearheaded by Doctor Shirley Schwartz who holds the patents (with GM) for the algorithm and the oil life montitor. I had the luck of working directly with Dr. Schwartz when the idea of the oil life monitor first progressed from the theoretical/lab stage to real world testing/development/validation. There were fleets of cars operated under all conditions that deteriorate the oil life for any and every reason and , thru oil sampling and detailed analysis of the oil condition, the algorithm was developed, fine tuned and validated to be the most accurate way invented yet to recommend an oil change interval by. As just one example, I have seen cars driven side-by-side on trips, one towing a trailer and one not, for instance, to prove the effectiveness of the oil life monitor in deteriorating the oil at a faster rate just because of the higher load, higher average RPM, higher temps, etc...and it works flawlessly.
The oil life monitor is so effective because: it is customized for that specific vehicle/engine, it takes everything into account that deteriorates the oil, it is ALWAYS working so as to take into account THAT INDIVIDUALS driving schedule, and it tailors the oil change to that schedule and predicts, on an ongoing basis, the oil life remaining so that that specific individual can plan an oil change accordingly. No other system can do this that effectively.
One thing is that I know personally from years of testing and thousands of oil analysis that the oil life algorithm works. There is simply no argument to the contrary. If you don't believe me, fine, but, trust me, it works. It is accurate because it has been calibrated for each specific engine it is installed on and there is considerable testing and validation of the oil life monitor on that specific application. NOt something that oil companies or Amsoil do. They generalize....the oil life monitor is very specific for that application.
Oil condition sensors in some BMW and Mercedes products are useful, also. They have their limitations, though, as they can be blind to some contaminates and can, themselves, be contaminated by certain markers or constituents of certain engine oils. Oil condition sensors can only react to the specific oil at that moment and they add complexity, cost and another potential item to fail. One other beauty of the GM oil life monitor is that it is all software and does not add any mechanical complexity, mass, wiring or potential failure mechanism.
There is considerable safety factor in the GM oil life monitor. Typically, I would say, there is a 2:1 safety factor in the slope of the ZDP depletion curve....in other words, zero percent oil life per the ZDP depletion is not zero ZDP but twice the concentration of ZDP considered critical for THAT engine to operate under all conditions reliably with no wear. This is always a subject of discussion as to just how low do you want the ZDP to get before the oil is "worn out" if this is the deciding factor for oil life. We would tend to be on the conservative side. If the oil life is counting down on a slope that would recommend a 10K change interval then there is probably 20K oil life before the ZDP is catostrophically depleted....not that you would want to go there...but reason why many people are successful in running those change intervals.
Please...NOT ALL ENGINES ARE THE SAME. The example above is an excellent practical justification of why you would want to add EOS and change the 15W40 Delvac in the muscle car at 3000 miles max and yet can run the Northstar to 12500 easily on conventional oil. You must treat each engine and situation differently and what applies to one does not retroactively apply to others. This is where Amsoil falls short in my book by proposing long change intervals in most everything if you use their oil. It just doesn't work that way. You can run the Amsoil to 12500 with no concerns whatsoever in the late model Northstar because even the oil life monitor tells you that for conventional oil off the shelf. Would I do that to the 502 in my 66 Chevelle...NO WAY. Amsoil says I can though. Wrong.
There are entire SAE papers written on the GM oil life monitor and one could write a book on it so it is hard to touch on all aspects of it in a single post. Hopefully we hit the high spots. Realize that a GREAT deal of time, work and energy went into developing the oil life monitor and it has received acclaim from engineering organizations, petroleum organizations, environmental groups all across the board. It is not some widget invented in a week and tacked onto the car.
The oil life monitor is not under the control of a summer intern at GM Powertrain per an earlier post....LOL Not that a summer intern wasn't compiling calibrations or doing a project on it but is under control of the lube group with a variety of engineers directly responsible that have immediate responsibility for the different engine families and engine groups. The idea that a summer intern was responsible for or handling the oil life monitor is ludicrouS
  #21 (permalink)
Old 10-12-09, 11:52 AM
Cadillac(s): Cadillac 2008 STSV6 RWD
View KARL DAHLEN's Photo Album
Casino Cash: $5365
Thank you for that informed, well written and understandable explanation. I will continue to change my oil yearly at the dealer, since I rarely drive over 10K a year.
  #22 (permalink)
Old 10-12-09, 12:47 PM
DBeaSST's Avatar
Cadillac(s): 2009 STS 1SC
View DBeaSST's Photo Album
Casino Cash: $6555
Great read, thanks for sharing!
  #23 (permalink)
Old 10-13-09, 12:07 AM
Platinum06's Avatar
Casino Cash: $1760
Which amsoil...5-30?
  #24 (permalink)
Old 10-15-09, 01:15 PM
View may727's Photo Album
Casino Cash: $280
MY '05 STS seems to loose enough oil between changes to warrant doing it more frequently. I notice an engine noise and twice it was down at least 2 quarts, so I just had the oil changed. Does anyone else seem to use oil like this?
  #25 (permalink)
Old 10-15-09, 01:26 PM
Cadillac(s): 05 STS
View Greg00coupe's Photo Album
Casino Cash: $775
Funny my 00 N used a quart about every 3,000 miles which seemed the standard. But it used regular oil. My 05 N uses no oil and I change per the manual. My salesman said when I picked it up you know they use a little oil and I said yes. But this one does not. I'd like it to use a little but that may be old fashion thinking.
Interesting how folks will follow the letter of the manual to keep their cars in warranty but won't follow the GM suggestion to change synthetic less frequently. Seems they want to save money to keep within the warranty but not on oil changes.
  #26 (permalink)
Old 10-15-09, 10:53 PM
EChas3's Avatar
Casino Cash: $4860
The N* in our cars is a nice improvement over my wife's previous '98 STS. It always used some oil and the head gasket went around 100k. Neither of our new ones need more than half a quart between oil changes (DIC 10% ~ 10 months).
  #27 (permalink)
Old 10-16-09, 04:05 AM
Cadillac(s): 08 SRX4 V8 AWD, 08 STS V8 RWD
View miked's Photo Album
Casino Cash: $1565
I remember a couple of years ago reading an SAE article written by a couple of ph.D.'s at GM who developed the oil life monitor. It sold me. I just changed my oil for the first time, 12 months. Oil monitor was at 44%, with 7700 miles.
Our old SRX had four oil changes in 50K miles, one a year. No discernable issues.
  #28 (permalink)
Old 10-16-09, 10:09 AM
Aurora5000's Avatar
Casino Cash: $2577
may 727
There have been reported problems with carbon buildup with the Northstar. A top end cleaner would be a good place to start. You can do it or have the dealer do it. Also drive car up to 60 or 70 in 2nd gear, then let it drop to 40,still in 2nd repeat process 10 times. WOT will help . It helps free up your rings. You cannot baby these cars. Read my post on Seafoam...Others chime in...
  #29 (permalink)
Old 10-19-09, 09:21 AM
Aurora5000's Avatar
Casino Cash: $2577
Read this , Chris.
  #30 (permalink)
Old 10-19-09, 10:14 AM
Lifer's Avatar
Cadillac(s): 2006 Cadillac STS 1SG
View Lifer's Photo Album
Casino Cash: $8231
Originally Posted by Aurora5000 View Post
Read this , Chris.
WHAT?
Tags:
change, oil, question
