| Re: Added nav to non nav sts! 100% confirmed vid and pics. Thank you polarbear05!!! I had my NAV replaced by the dealer twice and both times it took a while to find the GPS signal. Before it found the signal it thought I was in a different state, I guess where the NAV was tested before being sent to the dealer.
Another thing you can try is to reset the location so it knows where to look for you. This may make it find you faster.
I forget right now but I think to calibrate the position is under calibrate when you push menu from the gps screen. If not its under config, then gps settings. |
