Originally Posted by ssstealth Perform the demonstration mode under daylight conditins only.
Ignition must be OFF.
Hold the Intellibeam button down for about 8 seconds WHILE the ignition is turned ON.
The high beam indicator will turn ON.
Demonstration mode will run about 45 seconds. During this time you will be able to see the headlight fading and be able to test the mirror sensor with a dark cloth. The green light on the mirror will verify status on/off. |
Wow! I didn't know this....Thanks a lot!
Its daylight here and I just tried what you recommended above. I seemed to get the Demo running...The headlights faded..and the blue indicator on the DIC (for high beam) came on and went-off thrice.
However, when I tried putting a dark cloth in front of the mirror sensor (to test it), I didnt seem to get a response.
Now, if I am able to view the demonstration, why doesnt Intellibeam bring on the High Beam automatically at night when it is completely dark. At night, I ensure that:
1. My speed is above 32 Kmph
2. Fog lights are switched off
3. Lights are in Auto mode
4. Intellibeam on rear view mirror is switched ON
5. High Beam stalk is in neutral position (i.e. on Low Beam)
Still, I dont see, High Beams being brought on automatically. Could I do anything else?
