I found it and another one in the caters forum.
This is the CTS one.
From the looks of it, all it will take is one piece of wire that is about 12 inches long. The relays for the high, low and fog lights are under the hood. Just look for the high and fog. I would personally would grab the output terminal of the fog light to re-energize the high beam relay. That is if the computer puts out a positive output to energize the relay.*
If the computer puts out a ground instead of a positive, then I would buy another relay, common 12volt from a radio install shop would be fine. Hook that up to the fog light output side of the relay. Connect 85 to ground, 86 to the fog light out put. Then 30 to high beam output which will by pass the factory's relay. 87 you should put a 20amp fuse, or whatever the high beams currently use for a fuse and connect that to power.*
And this is the Catera one.
I got it working! thanks to DaveSmed and WarrenJ for there help. all you have to do is connect pin 87A to pin 30 on the High Beam RH relay. works like a charm.
http://todd.bluesubmarine.org/Cadillac/DSCN8764.JPG http://todd.bluesubmarine.org/Cadillac/DSCN8767.JPG http://todd.bluesubmarine.org/Cadillac/DSCN8769.JPG
Does anyone know if this or something similar will work on the STS?
