Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac STS Forum - 2005 through 2010
Cadillac STS Forum - 2005 through 2010 Forum for discussions regarding the new Sigma-based STS model.
Not for Cadillac "Seville" discussions (2004 and older).
cadillac-sts
Cadillac Forums: Make fogs stay on with high-heam?
  #16 (permalink)
Old 09-08-09, 09:30 AM
STE_6000's Avatar
Cadillac(s): Cadillac STS 2005
View STE_6000's Photo Album
Casino Cash: $4200
Re: Make fogs stay on with high-heam?
dear god ur old K, here i thought u were 22.
  #17 (permalink)
Old 09-08-09, 10:00 AM
K STS's Avatar
Banned
Cadillac(s): 2006 STS V8, 1999 Seville STS
View K STS's Photo Album
Casino Cash: $3930
was ;-)
  #18 (permalink)
Old 09-08-09, 11:16 AM
STE_6000's Avatar
Casino Cash: $4200
ur an old fart.
  #19 (permalink)
Old 09-08-09, 12:10 PM
K STS's Avatar
Banned
Casino Cash: $3930
ill consider myself old when i hit the big ol 30.
  #20 (permalink)
Old 09-08-09, 12:41 PM
EChas3's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
View EChas3's Photo Album
Casino Cash: $4860
I'm betting you'll revise your definition.
  #21 (permalink)
Old 09-08-09, 12:46 PM
Banned
Cadillac(s): 2005 STS
View snum1fan's Photo Album
Casino Cash: $3105
Look at this. It is from Alldata.
FRONT FOG LAMPS
With the ignition switch in the ON or START position, the front fog lamps will illuminate when the driver toggles the front fog lamp switch to the ON position. The front fog lamp switch is a momentary switch that requires the driver to briefly place the front fog lamp switch to the ON position and release it. The instrument panel module (IPM) controls the front fog lamp relay coil. When the driver toggles the front fog lamp switch to the ON position, the switch supplies ground to the front fog lamp switch signal circuit of the IPM. In response to this input, the IPM supplies ground to the front fog lamp relay control circuit. The underhood fuse block supplies battery positive voltage to the switch circuit of the front fog lamp relay. Ignition voltage is available to the front fog lamp relay coil when the key is in the RUN or CRANK positions. When the IPM grounds the front fog lamp relay control circuit the relay coil energizes, closing the switch contacts. Current then flows from the fog lamp fuse through the front fog lamp relay switch to both front fog lamps. Both front fog lamps are permanently grounded at G104. The front fog lamps will default to the OFF position upon a key cycle.
The IPM will turn the park lamps ON when the front fog lamps are ON and send a message via GMLAN serial data to the instrument panel cluster (IPC) to enable the front fog lamp indicator. The front fog lamps will deactivate when either the flash-to-pass or the high beam headlamps are turned ON. For vehicles exported to Japan or any European Country except Norway or Sweden, the front fog lamps will remain illuminated with the operation of the high beam headlamps or flash-to-pass.
  #22 (permalink)
Old 09-08-09, 12:50 PM
Banned
Casino Cash: $3105
So If I test the fog lamp relay when I turn them on, and write down all the values (ground, power). Then turn on the high beams and test the same relay I should be able to see what the difference is (loss of ground?) and then recreate that from whichever pin the high beam has the same of (ground to ground)?
I dunno, I've been reading too much Alldata too early in the morning.
  #23 (permalink)
Old 09-08-09, 01:18 PM
STE_6000's Avatar
Casino Cash: $4200
why not just get a wiring diagram for the STS? sure helms has it.
  #24 (permalink)
Old 09-08-09, 01:24 PM
Banned
Casino Cash: $3105
I have all of the wiring diagram for the STS from Alldata. There is so many pages. I have been looking at it all morning, but what is a PITA is comparing different diagrams to figure out how they relate to each other. If there was one big diagram it would be easier. There is about 15 or so just on the headlights, not including the foglights.
I will post some of them. If we can figure out the best approach I will be the guinea pig, and try it out.
  #25 (permalink)
Old 09-08-09, 01:40 PM
Banned
Casino Cash: $3105
OK here it goes.
  #26 (permalink)
Old 09-08-09, 04:37 PM
View staynumz's Photo Album
Casino Cash: $1370
The youngest guy has to figure it out first. I dont make the rules, I just live by them.
  #27 (permalink)
Old 09-08-09, 05:55 PM
STE_6000's Avatar
Casino Cash: $4200
after u get that done, make a bomb out of gum and a paper clip hehe
  #28 (permalink)
Old 09-10-09, 09:30 AM
K STS's Avatar
Banned
Casino Cash: $3930
what kind of mcgyver shit is this
  #29 (permalink)
Old 09-10-09, 11:14 AM
STE_6000's Avatar
Casino Cash: $4200
diagram reminds me of shoot and ladder.
  #30 (permalink)
Old 09-10-09, 12:04 PM
Cadillac(s): 08 Cadillac STS AWD Platinum Edition
View SwissSTS's Photo Album
Casino Cash: $4826
Originally Posted by snum1fan View Post
For vehicles exported to Japan or any European Country except Norway or Sweden, the front fog lamps will remain illuminated with the operation of the high beam headlamps or flash-to-pass.[/color]
A dealer with a Tech2 can activate that in the BCM. I had this done and the fog lamps now stay on with high-beam.
Tags: , , ,
fogs, highheam, make, stay
