cadillac parts
Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac STS Forum - 2005 through 2010
FAQ Donate Calendar Mark All Cadillac Forums Read
Cadillac STS Forum - 2005 through 2010 Forum for discussions regarding the new Sigma-based STS model.
Not for Cadillac "Seville" discussions (2004 and older).
cadillac-sts
Cadillac Forums: Rim Bolt Pattern Question???
Old 05-15-08, 03:46 PM
STS2002 STS2002 is offline
Cadillac(s): 2005 STS 1SF V8
Casino Cash: $2900
I have an 05 STS 1SF that I bought used and came with the 08 STS 18 in rims (dealer thought it would give it a fresh look). Anyway....I have been battling with a vibration issue that seems to be an rim issue. I have ruled out a tire problem, because I have replaced the tires and it is still there. There is one thing i noticed about the rims and was wondering if anyone knew if this would create a big issue. The 05-07 18in rims have a a bolt pattern of 5x115 and the 08 18in rim that I have on my 05 has a bolt pattern of 5x4.5. Could this difference in bolt pattern cause a vibration???
Thank you in advance for you help.
Phil
  #2 (permalink)
Old 05-15-08, 06:30 PM
MOINEX MOINEX is offline
Cadillac(s): Cadillac
Casino Cash: $1280
Re: Rim Bolt Pattern Question???
Could it be a tire balance problem? Per dealer, the tires should be Road Force Balanced. Had it done on mine. It makes a big difference.
  #3 (permalink)
Old 05-15-08, 06:54 PM
Casino Cash: $2900
Yeah...had that done like 3 times. I am at my whits end. The vibrations were coming through the front floorboard and the front seats and always between the speeds of 50-54, 60-64, and 70-74. The vibrations also have a rythym.....the vibration would come for 5 seconds and then go away for like 4 seconds and starts the cycle over and over. I have one tire and rim combination that is just terrible and creating this horrible vibration.
I took the rim to a guy who makes rims round (this rim was out of round by .0050 of an inch and they got it down to .0010 of an inch and cadillac says that the rim should be no more than .0020 out of round) and after he did that all the vibrations went away.
Then after a while they started to back a little and I took it back to the dealer to have them road forced. They couldn't get it down past 24lbs of radial force and Cadillac says it should be no more than 18lbs. So.....assuming that the rim is now perfectly round (since the rim guy took care of it) it must be a bad tire to be making this vibration.
Then I noticed the bolt patterns are different and it aroused my curiosity. In any case....the dealer is pretty much telling me that this is the way the car drives and basically there is nothing more to do. I get soooooo frustrated because I am the one driving it everyday and it happens infrequently at different temperatures, mornings, nights, so when I take it to them, they think i'm crazy. I didn't buy this car to enjoy vibrations and I don't believe that I have to settle with this.
I could just screem when I think about all the time, money and effort in trying to get this to go away. If anyone has any suggestions or went through something similar, your input would be much appreciated. I think my next step is to either take the rim back to the guy who fixed it and tell him that now the tire won't road force and the ride is bad or I attempt to spend $240 on a new tire.
Phil
  #4 (permalink)
Old 05-16-08, 11:08 PM
sapien sapien is offline
Cadillac(s): 2005 STS V8
Casino Cash: $3235
Tire Rack and Discount Tire both list 05-07 and 08 STS as 5x115mm bolt pattern...
I was told by a wheel/tire tech that if 5x4.5" (5x114.3mm) wheels were used on a 5x115mm hub, that they would eventually fall off because the lugs won't seat perfectly.
  #5 (permalink)
Old 05-18-08, 12:49 AM
z06bigbird z06bigbird is offline
Cadillac(s): Sedan de Ville, CTS
Casino Cash: $2284
Printed technical materials agree on the idea that the 114.3 wheels will eventually fall off.
  #6 (permalink)
Old 05-18-08, 06:34 AM
C&C C&C is offline
Cadillac(s): Cadillac STS (2006)
C&C's Avatar
Casino Cash: $3980
0.7 mm is approximately 27.5 thousandths of an inch (this is significant). A piece of paper is approximately 3 thousandths of an inch thick, so to get an idea how far off the lugs would be setting from a correct fit, put 8 or 9 pieces of paper stacked together to see just how far off it would be.
  #7 (permalink)
Old 05-18-08, 07:40 PM
Casino Cash: $2900
z06bigbird.....wow, i never would have thought that such a small difference would make such a bad outcome. Do you have a copy of that printed material....or a place where I could find that??
Thank you everyone for your input...if has been insightful!!
Phil
Tags: , , ,
vB code is On
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
earn
vacation travel
golf store
silver, gold, diamonds
Powered by vBulletin® Version 3.6.10
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
