Cadillac STS Forum - 2005 through 2010 Forum for discussions regarding the new Sigma-based STS model. Not for Cadillac "Seville" discussions (2004 and older).
 | Cadillac Forums: HELP! Nav screen no touch response
02-15-08, 07:34 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | HELP! Nav screen no touch response please help me , my nav screen docent seem to response to my touch, but when i press the hard keys on the dash the screen changes but i still can't get any touch response from the screen , i tried restarting the car many times and turning the unit on and off but still nothing, is there a way i can hard reset the system i have a feeling this is only a software problem if there is away i can reset the system using the hard keys please help help help.  |
02-15-08, 09:42 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: HELP! Nav screen no touch response You can try to reset the logic in the radio by disconnecting the battery, wait for 5 or 10 minutes, then reconnect it.
If that does not restore screen operation you'll have to take it in for repair. I have had units do this before.
Pretty rare, takes a new radio. You're still under warranty right?
__________________ Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group. |
02-15-08, 09:57 PM
|  | Cold Soaked Cadillac(s): 2006 STS AWD, '95 Ford Ranger | | Join Date: Jul 2004 Location: Fairbanks, Ak Age: 70 | | | Re: HELP! Nav screen no touch response Mind did the same thing when I was fooling around with it one day. Disconnect and reconnecting the battery fixed it.
__________________ Don't mess with Binky Bear! |
02-16-08, 09:14 AM
|  | Cadillac Owners Fanatic Cadillac(s): 07 EXT, 06 STS-V, 06 C6, YAM R1 | | Join Date: Mar 2006 Location: NC | | | Re: HELP! Nav screen no touch response Quote:
Originally Posted by dkozloski Mind did the same thing when I was fooling around with it one day. Disconnect and reconnecting the battery fixed it. | mine too. scared...but dq'd for 15min.
i also, with nav hack, had mine lock in aux mode if the aux button is accidently pressed while you have vss switched off...couldn't get back to bluetooth...same reset fixed. |
02-16-08, 11:01 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: HELP! Nav screen no touch response thanks guys, it is under warranty but i can reset it at home if easy, is there a way i can disconnect the battery without using any mechanical tools , like disconnecting an easy clip cable or something? |
02-16-08, 11:28 AM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: HELP! Nav screen no touch response Best way is to use an 8mm or 5/16" to unhook the ground cable from the battery.
No quick disconnect, only nuts and fuses. |
02-16-08, 06:52 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: HELP! Nav screen no touch response Quote:
Originally Posted by ewill3rd Best way is to use an 8mm or 5/16" to unhook the ground cable from the battery.
No quick disconnect, only nuts and fuses. | if i remove only the head unit fuse will that have the same effect as disconnecting the battery cable? if so i think that would be a lot easier than disconnecting the battery, if that is the case please tell me where is the location of the fuse box and which one is the head unit fuse. thanks in advance. |
02-16-08, 07:53 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: HELP! Nav screen no touch response The underhood fuse block has the major fuses that feed sub circuits and the rear fuse blocks.
GM doesn't use a single "main" fuse, but several larger fuses in place of what used to be "fuse links".
In recent years they have gone to using maxi fuses or small square fuses with colored housings.
Those are usually the main fuses but I can't guarantee pulling them all will do the job, although it could.
I'd have to find radio schematics and search the power distribution schematics to really tell you the best way to be sure... without disconnecting the battery.
You talked me into looking....
There are two 60 Amp fuses in the underhood fuse block labeled "L Rear" Try pulling those out for a few minutes. Then put them back in.
If that doesn't work the next step would be a battery disconnect, if that fails, it is a trip to the dealer. |
02-16-08, 10:02 PM
Originally Posted by ewill3rd The underhood fuse block has the major fuses that feed sub circuits and the rear fuse blocks.
If that doesn't work the next step would be a battery disconnect, if that fails, it is a trip to the dealer. | ok i opened up the fuse box but i couldn't find the fuses labeled L Rear, i really stink at this mechanical stuff  i had a hard time removing that big cover thingy under the hood and i couldn't even find the right fuse , i think i didn't even close the fuse cover right  i think it was suppose to click and i didn't hear any click, anyways thanks for the help if you could confirm that the fuse removal thing works in reseting the unit it would be really helpful since i will try removing all fuses and see, other wise i will go to a near by mechanic and tell him to disconnect the battery for a few minutes and connecting it back and see if it gets fixed. |
02-17-08, 09:40 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: HELP! Nav screen no touch response Let me see if this will work.
Over on the left side you can see the small square fuses labeled L REAR
Pull those out. Don't break them.
They are hard to get out. |
02-18-08, 07:04 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: HELP! Nav screen no touch response thanks ewill3rd ,i remembered that i didn't do my 50.000 service yesterday so i took it to the dealer today to do it and asked them about this problem and they told me it's a software problem, they said updating the software would fix that problem for good ,removing the battery is temp solution and the problem will come back , so they told me to bring it tomorrow to do the software update , it's a 2005 so do you think updating the software will fix this problem for good? |
02-18-08, 07:08 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: HELP! Nav screen no touch response i took it to the dealer today and they told me to bring it in tomorrow to have the software update which will fix the problem for good, the told me that disconnecting the battery is a temp solution only, what do you think will the software update fix this problem for good? |
02-19-08, 06:40 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: HELP! Nav screen no touch response you wont believe this BUT my car has different fuse box map then the one you have!, i live in Kuwait and i took it to the dealer today and they told me i have to update the software in order to avoid that problem for good, one thing I'm worried about is that in here they don't have XM radio so instead the xm radio bottom is replaced with TV , they equip the STS here with TV tuners instead of XM so I'm kinda worried if they updated the software for me i would lose the TV feature and get xm radio which is not available here, i hope GM did an updated version of the new software for countries outside the US also so they don't lose the TV feature if they updated, what do you think should i update? because i don't think they know the answer in the dealership, i think they wanna try on me and see! |
02-19-08, 09:44 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: HELP! Nav screen no touch response Hmmm... so this was built for export? Do you know the original country of sale?
I am not sure I can answer those questions for you to be honest. I have never dealt with an export car.
I know the exports get a TV tuner setup and no XM but I don't know how that will affect the software update.
They probably have bulletins for that stuff that deals with export hardware.
I think maybe you just lost me  |
02-19-08, 09:47 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: HELP! Nav screen no touch response .... although I did just find this: Quote: |
#06-08-44-029: New Route Cannot Be Calculated When Using 2007 Model Year Map DVD, Voice Recognition System Performs Poorly, Noisy Map Drive When Updating Traffic Message Channel (Update Audio/Navigation Software) - (Sep 13, 2006)
| Quote:
Subject: New Route Cannot Be Calculated When Using 2007 Model Year Map DVD, Voice Recognition System Performs Poorly, Noisy Map Drive When Updating Traffic Message Channel, Memory Seat Function Operation Complicated (Update Audio And Navigation System Software)
Models: 2005-2006 Cadillac STS (European Export Vehicles Only)
Condition
Some customers may comment of any or all of the following conditions:
• They cannot calculate a route in their vehicle's navigation system when using the updated 2007 model year map disc, P/N 15924193.
• Poor performance of the voice recognition system.
• The map drive makes too much noise when updating the Traffic Message Channel (TMC) information.
• The memory seat function operation is complicated.
Cause
This condition may be caused by the navigation system software. The format of the European map DVD, starting in the 2007 model year, is different than in previous year's and the navigation system software will require an update.
Correction
| | | Cadillac Discussion Tools | | |
Censor is ON | | | |
