Cadillac STS Forum - 2005 through 2010 Forum for discussions regarding the new Sigma-based STS model. Not for Cadillac "Seville" discussions (2004 and older).
 | Cadillac Forums: STS4 "grinding" when turning and/or accelerating at low speeds
12-13-07, 03:11 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 78 Eldo,78 Toronado XS,06 STS4,06 STS-V,07 GMC Sierra SLT | | Join Date: Mar 2005 Location: Cary, NC Age: 38 | | | STS4 "grinding" when turning and/or accelerating at low speeds We just bought a used STS4. So far, I'm pretty happy with the car, but we have noticed a type of "grinding" that I cannot determine whether it is a problem or just a characteristic of the AWD system.
When turning and/or accelerating at low speeds (traffic, parking log, driveway, etc.) one gets the sensation of grinding or vibration from the front end. I have particularly noticed it through my left foot when it is resting on the foot rest, but it is detectable otherwise too. It is accompanied by a subtle grinding noise also from the front end. It's not the power steering pump because I checked that, and it will do it even when not turning but rather just accelerating from very slow or a dead stop.
I have an STS-V as well and it does not do this, but that is a completely different set up than the STS4.
Do any of you STS4 owners notice something similar? Before I take it to be serviced, I want to see if this is simply characteristic of all wheel drive or whether it is an actual problem. |
12-13-07, 06:24 PM
|  | Cadillac Owners Member Cadillac(s): 2006 STS 1SC V6 | | | | | Re: STS4 "grinding" when turning and/or accelerating at low speeds I've had a groaning/squeaking problem with the steering for some time now....
but my noise is coming from the steering column not the front end...dealer hasn't been able to fix it and I'm about to lemon law it which is a shame...  |
12-13-07, 10:46 PM
|  | Cadillac Owners Member Cadillac(s): 89 Seville ~ 99 Seville STS,vogues ~ 06 STS4 V8 Blk/Blk,tint | | Join Date: Jul 2007 Location: Cleveland | | | Re: STS4 "grinding" when turning and/or accelerating at low speeds I have an 06 STS4 V8 and i noticed the same thing. I'm glad i'm not the only one. While turning in reverse it's most noticeable like the tire is rubbing against something. |
12-14-07, 12:09 AM
|  | Cold Soaked Cadillac(s): 2006 STS AWD, '95 Ford Ranger | | Join Date: Jul 2004 Location: Fairbanks, Ak Age: 70 | | | Re: STS4 "grinding" when turning and/or accelerating at low speeds My '06 AWD STS V8 is quiet as a little mouse.
__________________ Don't mess with Binky Bear! |
12-14-07, 10:03 AM
|  | Cadillac Owners Fanatic Cadillac(s): 2006 Cadillac STS 1SG | | Join Date: Apr 2007 Location: Coppell, TX | | | Re: STS4 "grinding" when turning and/or accelerating at low speeds Quote:
Originally Posted by dkozloski My '06 AWD STS V8 is quiet as a little mouse. | Probably becuase its frozen over. |
12-14-07, 10:55 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: STS4 "grinding" when turning and/or accelerating at low speeds I would have them check the wheel bearings in front end. Also check your tires to see if Alignment is off and if your tires are worn on the inside or outside that will cause noise |
12-14-07, 11:54 AM
| | Cadillac Owners Fanatic Cadillac(s): 1962 Series 62 Convertible, 1937 LaSalle, 1955 Olds Super 88 | | | | | Re: STS4 "grinding" when turning and/or accelerating at low speeds I visit the Bonneville user's site and what you are describing is very similar to a problem with the "intermediate steering shaft" on the Bonneville. I'm not very technical so you have to take what I write in this post "with a grain of salt". Here is a link to this site. The second "sticky" down discusses the "intermediate shaft". Also, if you do a search, there are numerous posts addressing this issue. Good luck. http://www.bonnevilleclub.com/forum/viewforum.php?f=8 |
12-14-07, 01:11 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: STS4 "grinding" when turning and/or accelerating at low speeds My 06 V6 STS AWD is very quiet . Only had it a few months , but no complaints . Very happy with it .
I will need to get the driver seat fixed whenever i bring it in , and the recirc door lubed , but all that will be
warranty work. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
