Noise not sure if it's related to needing new brakes..
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By JohnnyBzSRX
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Noise not sure if it's related to needing new brakes.. in Cadillac SRX / XT5 Forums; ...
    cadigirlchicago2 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 SRX Luxury
    Sep 2010
    248
    Hi Everyone!
    I know this is a total shot in the dark but I figured I’d post anyways. So my 2010 has just over 81,000 miles. I replaced the tires in the fall but they told me brakes still were okay. Last time I took the car in for a tire rotation they told me next rotation I will definitely need new brakes. This past week I have noticed a ton of road noise. It sounds like a low sound noise, similar to the sound when you are at the airport on those grooved pieces of cement and the car makes that weird sound when you go over them, it’s sorta like that. I just had all of the spark plugs replaced about 2 months ago. Could it be a transmission issue? You’d think the light would come on if it was. The sound is constant when I’m on the gas or brake, makes no difference. I tried looking on line, it said it could be related to the brakes or possibly something else in that area, maybe a cracked rotor? Anyone have any ideas? I know, it could be anything, just hoping maybe someone had something similar around the time you needed new brakes.
    JohnnyBzSRX's Avatar
    JohnnyBzSRX is offline Cadillac Owners Fanatic
    Automobile(s): 2013 SRX FWD Performance - Xenon Blue / Shale-Brownstone
    Sep 2013
    Ft. Wayne, IN
    296
    Re: Noise not sure if it's related to needing new brakes..
    When exactly does this "low sound noise" occur? Only when the vehicle is in motion (but not accelerating / decelerating)? Only when applying brakes? Only when accelerating? Some combination? All the time? Does the frequency of this noise go up and down w/ vehicle speed (or engine RPM)?
    If it really occurs all the time, regardless if your are accelerating, braking or just cruising along at speed, I'd suspect it may be wheel bearings or something else in the driveline (half-shafts, maybe?). If it occurs only when braking, then I'd suspect the brakes are grinding on the rotors, new pads and rotors are probably needed. If it occurs only when accelerating, I'd suspect something in the driveline (half-shafts, transmission). 81,000 miles is pretty long for the original brakes, and its not unheard of for wheel bearings to go bad by then. Half-shafts usually are good for 100,000 miles unless the rubber boots have been damaged and the lube has leaked out.
    Sep 2010
    248
    Hi!
    It's all the time. Are bearings covered under the warranty or no?
    Nice Ride is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 ESV Platinum / 2013 SRX Premium
    Jan 2012
    1,277
    To help you the most, I think JohnnyBz needs all the answers to a l l the questions for him and anyone else to really assist you better. Vague on the answers will get you the worst results. It may take a few back and fourth Q & A, but the people on the forum are great!
    Sep 2013
    Ft. Wayne, IN
    296
    Quote Originally Posted by cadigirlchicago2 View Post
    Hi!
    OK, are you sure its not the new tires? Are they a different type/brand that the previous set of tires? You'd have to ask your dealer if your warranty (still) covers the bearings, but to be sure before you cross that bridge, need to rule out tires. Some are noisier rolling down the road than others. Might also consider getting an opinion from an independant mechanic before taking it to the dealer.
    TheCaptain likes this.
    Sep 2010
    248
    Got the tires in the fall and this noise just started happening within the past 7 days. It's pretty consistent, on the gas, off the gas, brake, no brake it's the same. No different on a left or right turn. I guess I'll just see what they say on Saturday when we take it in for the brakes. I'm taking it to NTB, they did the tires and we were pleased, hopefully they do a nice job on the brakes.
  9. Remove Advertisements
