How to change dead battery
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Like Tree13Likes
Cadillac SRX Second Generation Forum (2010-2016) Discussion, How to change dead battery in Cadillac SRX / XT5 Forums; Battery in 2010 SRX is dead, is it simple to change it myself or will I cause other issues? Are ...
    10SRXAWD is offline Cadillac Owners Member
    Automobile(s): 2010 SRX AWD Premium Platinum
    Jan 2014
    Wentzville, MO
    1
    Battery in 2010 SRX is dead, is it simple to change it myself or will I cause other issues? Are there specific instructions? Nothing in the manual and not having much luck searching online.
    Thank you,
    Darla
    Nice Ride is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 ESV Platinum / 2013 SRX Premium
    Jan 2012
    1,259
    Re: How to change dead battery
    See my other post. Crazy Battery offer Amazon..
    Swap out was a 15 min process.
    -You will need small Ratchet with an extension.
    -You will need a 13mm and a 10mm socket
    1. Remove cover over battery by unclipping 4 clips on side of box ( 2 each side )
    2. Lift cover, flip over and let rest on front of vehicle with all cables attached, it will stay.
    3. you will find 2 additional metal clips holding top harness on top of battery, positive side, remove entire clip and note which slot it came out of ( trust me )
    4. Use 10mm to loosen positive cable off battery, move cable out of way.
    5. Use 10mm to loosen negative cable off battery, move cable out of way.
    6. Remove block harness off of top of battery, push out of way.
    7. use 13mm to remove battery hold down clip. (make note of position and 2 parts to make it work)
    8. Lift battery out of car.
    Install new Battery and reverse procedure.
    Warning, car alarm may go off when you re-connect the battery, so don't jump when you connect it.
    NOTE: Once installation is complete, you will see a message on the DIC telling you to Open and Close the Driver window. Then, it will tell you to Open and Close the Passenger window.
    You may need to also reset some features in Config. for the Radio etc.
    That's it, a $280- battery for $106- DIY. Dealer will charge you over $350-
    glenpointe is offline Cadillac Owners Member
    Automobile(s): 2012 SRX Performance
    May 2014
    24
    I'd reverse steps 4 and 5. Because ---> When you loosen up the positive cable and if your rachet happens to touch any metal part, it will spark. If you loosen up the the negative first (then get cable out of the way), then you don't have to worry about sparking. You can get the battery replaced just in few minutes.
    Note: take the battery to any parts store and they will check it for you. The cause may not be the battery.
    Nice Ride and 407driver like this.
    SRXyz is offline Cadillac Owners Fanatic
    Automobile(s): SRX
    May 2013
    139
    Quote Originally Posted by glenpointe View Post
    This is critical, especially when you're reversing the steps during installation of a new battery.
    Nice Ride likes this.
    Likely is offline Cadillac Owners Fanatic
    Automobile(s): 2013 SRX Premium Collection FWD
    Feb 2010
    Bullhead City, AZ
    81
    360
    Yep, reverse steps 4 & 5 for sure!!!!!
    Jan 2012
    1,259
    Thanks guys, you are correct! Nothing like a spark at over 100Ah's
    How do I post photos, I took step by step pictures of the process while doing it. I did disconnect the + first, screwed up the directions....
    Jan 2012
    1,259
    Figured out the photo sizing issue I had, Here ya go...
    1.JPG Remove this cover, 4 clips ( 2 each side )
    2.JPG Flip over on its side with all cables attached..
    3.JPG 4.JPGRemove these 2 spring clips. Note location they come from, there are several holes that they will fit in when you put them back... 5.JPG
    7.JPG Remove - and + cables.
    Indy_Mike and SRXyz like this.
    Jan 2012
    1,259
    Continued...
    Attachment 241914 Unclip next harness attached to top of battery and move to side.
    Attachment 241922 Remove bolt and Battery hold down at bottom front of battery. ( Note position and 2 parts along with the screw orientation so you put them back the same way)
    Attachment 241930 Hold down removed.
    Attachment 241938 Remove old battery ( Dispose of properly if you purchased the AGM replacement from Amazon since you cannot return the core. Some autoparts stores may give you a store credit for returning the old battery to them anyway )
    Attachment 241946 Drop in new battery oriented just the way you see it..
    Attachment 241954 Optional ( Clean battery terminals with wire brush and coat the terminals and cables with "CRC Battery Terminal Protectant" )
    Reverse procedure above and put it all back...... N O T E !!! ALARM MAY GO OFF WHEN YOU RECONNECT BATTERY POSITIVE CABLE, be prepared...
    Attachment 241962 Double check everything.... Start car and Follow instructions on DIC about the 2 front windows....
    Now go out and have a nice dinner on all the money you saved...... See post on Amazon AGM Battery for additional photos and CRAZY Battery pricing delivered to your door.
    Indy_Mike likes this.
    db91conv is offline Cadillac Owners Member
    Automobile(s): 13 SRX 88 Seville
    Jul 2016
    5
    Want to replace the battery in my 2013 SRX, this 2010 procedure looks like it applies to my car also.
    My question is, what if you would plug in a source of 12V inside the car to hold voltage while you are
    changing the battery, to avoid any resets etc. I used to have a 9V battery plug in to cigarette lighter tool.
    Now I have a jump pack that has a cigarette lighter plug I could do this with. Or is it no big deal. I have heard
    stories about bad things like now your seat doesn't work, key fobs, alarm going off, etc. Just want to avoid having to take it to a dealer at all because now something doesn't work. I want that AGM Amazon Delco battery.
    gary41 is offline Cadillac Owners Member
    Automobile(s): 2014 SRX....Previously owned 1995 ElDorado, 2000 STS, 2005 CTS and 2006 SRX
    Nov 2016
    Huntsville, AL
    18
    You will want to open and leave front door open so the "retain power accessory" program times out. Otherwise the lithium battery for the ONSTAR system will discharge when the battery is disconnected.....and it costs $$$ for the dealer to replace it. That battery IS NOT rechargeable, it is only used in case of an accident that has compromised the vehicle's electrical system so that the ONSTAR can still communicate. This info was from Caddy service manual.
    And, most definitely, remove the negative cable from battery FIRST and re-connect LAST.
    GEORGEC is offline Cadillac Owners Fanatic
    Automobile(s): 2013 SRX PERFORMANCE, ICE WHITE
    Sep 2005
    FLORIDA PANHANDLE
    249
    If I had a dead battery I would just jump start the vehicle and drive down to SAMS Club and have them put in a new one. No charge for installation and they keep power on the system so that nothing is lost.
    George
    79666 likes this.
    Jul 2016
    5
    My battery isn't dead, but is almost 5 yrs old, and I am looking to replace it before next fall.
    That is what I'd like to know, can I retain the power and just swap in the new one without going thru
    any resets, on the car or with the fobs. And, if the alarm goes off when connecting the new battery,
    do you shut it off with the fob or what.
    Jan 2012
    1,259
    Same procedure, Alarm can be turned off with Fob. DIC will tell you to hold the window button to reset them... that's about it. Takes all of 15 to 30 min.
    I would recommend an AGM battery as a replacement. Amazon will ship direct to your door...
  16. #14
    Jul 2016
    5
    Quote Originally Posted by gary41 View Post
    You will want to open and leave front door open so the "retain power accessory" program times out. Otherwise the lithium battery for the ONSTAR system will discharge when the battery is disconnected.....and it costs $$$ for the dealer to replace it. That battery IS NOT rechargeable, it is only used in case of an accident that has compromised the vehicle's electrical system so that the ONSTAR can still communicate. This info was from Caddy service manual And, most definitely, remove the negative cable from battery FIRST and re-connect LAST.
    Huh? Leave the front door open...for how long? Until interior lights go out? Doesn't say that in original post
    of this procedure. Can this lithium battery die in 20 minutes?
    This is why I ask if power should be retained to the vehicle via a 12V port, backfeeding 12 volts to the
    system, to prevent any unknowns resulted from a hard disconnect. Sounds like Sams Club must do something
    like this, but I am not sure, I am leary about experimenting with my caddy.
  17. #15
    Nov 2016
    Huntsville, AL
    18
    Quote Originally Posted by db91conv View Post
    Yes, according to the info/service bulletins from GM and ALLDATA.com, to which I have a subscription for my 2014 SRX. In addition, it also mentions that ignition is to be in the deactivated state.
  18. Remove Advertisements
