Results 1 to 5 of 5
Thread: 2011 SRX Battery & Charging System Issues
    148EMERALD is offline Cadillac Owners Member
    Automobile(s): 2011 SRX
    Aug 2014
    29
    3
    Hello all. I cruised the forums but could not find anything on the specific problem I am having. Here it is:
    2011 SRX found dead in the parking lot Monday night. It was throwing up some weird messages on the DIC like service stabilitrac, windshield wipers would cycle when I hit the ignition button etc. Had roadside come out and the battery was down around 10V. We charged it and I got it home to have the battery die again. I just replaced it and the car now has enough juice to recognize the remote and turn on DIC but no luck getting the engine to start. Battery voltage is reading 12V and the message service battery charging system along with sundry other random (roll up window) error messages in DIC. Any ideas on what could be the root cause?
    Maximumkk is offline Cadillac Owners Fanatic
    Automobile(s): 2014 SRX Premium AWD - Silver Coast w/ Shale-Brownstone
    Oct 2011
    Winnipeg Manitoba
    462
    Re: 2011 SRX Battery & Charging System Issues
    Failed battery.
    Max
    Aug 2014
    29
    3
    Hey Max. Thank you for the info. The battery currently in the vehicle is new from a local Autozone. It's possible it was just a lemon and I need another but I looked it up online and the rated voltage for the new battery is 12 volts. The DIC reads 12.2 when I look at battery volts so it's at its rated output. I could be wrong but I thought the truck ran at 14 volts. I couldn't locate specs for the old battery online but it is discontinued and info is hard to come by. Am I crazy to think it could be the battery is just wrong for the car? It is behaving as it did when the old battery was low on juice.
    My current plan is this: Replace the new battery with the old, get a jump, read the idling voltage, take it to another shop and have them replace it to save myself the trouble of coming home with another battery to not have the truck turn over.
  5. #4
    Lilracr is offline Cadillac Owners Member
    Automobile(s): SRX
    Jul 2014
    10
    If the battery is bad and will not charge, the vehicle charging system may recognize the battery at full charge and the regulator reduces amperage and voltage.
    You can run a pull down test on the old battery to test it. If it passes then I would think it is a vehicle charging issue.
  6. #5
    Aug 2014
    29
    3
    Lilracr, thank you for the input. Do you mean that the new battery is bad? I am pretty sure the old one was in fact dead (still have and will test), but I can't figure out why the new one is being rejected. Tried cleaning terminals and cables, replacing positive cable, and giving it a jump today. No luck, still charging system message. I also read online that if you hear the solenoid give only a single click it could be a starter/solenoid issue. Thoughts? Thanks again for input everybody.
  • You may not post replies
