2011 3.0 Transmission fluid recommended change interval?
Results 1 to 8 of 8
Cadillac SRX Second Generation Forum (2010-2016) Discussion, 2011 3.0 Transmission fluid recommended change interval? in Cadillac SRX / XT5 Forums; Two questions: 1. What is the recommended transmission fluid change interval for a '11 3.0 XWD? 2. Why does the ...
    packardv8 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 Saab 9-4X Premium XWD
    Apr 2012
    217
    Two questions:
    2. Why does the owner's manual say the 2.8 doesn't need trans fluid changes?
    jack vines
    TheCaptain's Avatar
    Aug 2009
    Moosomin Saskatchewan
    30
    3,075
    Re: 2011 3.0 Transmission fluid recommended change interval?
    The GMCanada Cadillac page suggests 80 000Kms / 50 000miles for severe service use.
    Suggested 160 000Kms / 100 000miles for normal service use.
    (2011 3.0 AWD)
    Apr 2012
    217
    Thanks.
    Any idea why the 2.8 turbo tranny does not have a recommended change? What's the diff?
    jack vines
    79666 Guest
    All I know that it is a different transmission also a different mfg
    pineseed is offline Cadillac Owners Member
    Automobile(s): 2011 srx
    Feb 2014
    59
    3
    Is a "transmission fluid change" something I can do myself? Is it simply draining the pan and refilling? Thanks.
    79666 Guest
    Quote Originally Posted by pineseed View Post
    You have to remove the pan. There isn't a drain plug. Any way you should change the filter also.
    Likely is offline Cadillac Owners Fanatic
    Automobile(s): 2013 SRX Premium Collection FWD
    Feb 2010
    Bullhead City, AZ
    81
    360
    Unless you have driven it real hard or have been towing something alot, 75 to 100,000 miles would be my suggestion to change. If you have a hoist or floor jacks, jack stands and drain pans you can drain and remove the trans pan without to much trouble. Removing the pan you will some spillage for sure. Add the correct amount of fluid back in. The owners manual should say how much. Don't forget the trans filter!!!! Good luck....
    Nice Ride is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 ESV Platinum / 2013 SRX Premium
    Jan 2012
    1,259
    I was able to change out 95% of the fluid with a Suction Pump I Picked up on Amazon http://www.amazon.com/gp/product/B00...ilpage_o04_s00
  11. Remove Advertisements
