Results 1 to 6 of 6
Thread: Shift Indicator
    hwilliams555 is offline Cadillac Owners Member
    Automobile(s): SRX
    Jan 2013
    13
    Shift Indicator
    2010 Cadillac SRX Shift Indicator says Shift To Park after car has been shifted to park.
    Any one had that problem? What was the fix.
    GMFAN is offline Cadillac Owners Fanatic
    Automobile(s): 2014 SRX Premium w/20" chrome
    Mar 2009
    TN.
    481
    Re: Shift Indicator
    Quote Originally Posted by hwilliams555 View Post
    Had this happen on my CTS Wagon a couple times. As soon as the message showed up on the DIC, I shut the car off, waited 15-30 seconds and restarted. It worked, then I received the message again later. I did the same thing and it finally corrected itself. I believe there's a shift position sensor that can cause the error. If your message doesn't correct itself you may want to try a reboot...disconnect the battery and reconnect. Personally, If the engine restart doesn't work I'd bring it in. I don't like messin' with the battery unless absolutely necessary. Good Luck.
    Mar 2010
    Detroit, USA
    12,711
    Re: Shift Indicator
    Hello hwilliams555,
    I am sorry to hear that your SRX is telling you to shift out of park when you are already in park. Have you brought this concern to your Cadillac dealership’s attention? If you would like any assistance setting up an appointment, I would be more than happy to. Please feel free to private message me if you would like my assistance. I will be sure be on the lookout for your future messages.
    Gregory W.
    Cadillac Customer Care
  5. #4
    463's Avatar
    463 is offline Cadillac Owners Member
    Automobile(s): 10 SRX AWD 3.0L Premium caribbean blue
    Nov 2013
    Moosomin Sask
    68
    Re: Shift Indicator
    I just had the dealer fix this on my 2010 srx, This condition may be caused by the shift linkage adjustment, a slow Brake Transmission Shift Interlock (BTSI) mechanism or a Park Confirmation micro-switch that is not closed.
    Correction:
    Requires the dealer to adjust the automatic shift control linkage per the instructions, if that still doesn't do it, it says that the transmission shift control may need to be replaced.
    http://www.cadillacforums.com/forums...hift-park.html
  6. #5
    westham is offline Cadillac Owners Fanatic
    Automobile(s): 2010 SRX Luxury
    Jul 2013
    Los Angeles CA
    367
    Re: Shift Indicator
    I had the self same problem, the dealer fixed it under warranty by replacing the electronic transmission linkage sensor unit under the vehicle.
    Best of luck.
  7. #6
    463's Avatar
    Nov 2013
    Moosomin Sask
    68
    Re: Shift Indicator
    Please note if you have this fix at the dealer please make sure that ALL the switches work in the console are working as normal.
    As for myself I took me two months to notice that the rear park assist button is not working. I think the tech may have forgot to plug in the switch.
    Thanks to The Captian who found this problem.
  • You may not post replies
