Has anyone hardwired their radar detecter to the mirror on a 2013/2014?
Results 1 to 7 of 7
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Has anyone hardwired their radar detecter to the mirror on a 2013/2014? in Cadillac SRX / XT5 Forums; I was looking at the post behind the mirror and it looked like it was a solid piece. On an ...
    Movinon is offline Cadillac Owners Fanatic
    Automobile(s): 2014 SRX Performance, 2013 CTS-V
    Nov 2013
    449
    QuestionHas anyone hardwired their radar detecter to the mirror on a 2013/2014?
    On an earlier post they were describing sliding the post apart to get to the wires on anolder model SRX. I was hoping that could still be done on the newer models.
    I thought I would order an Invisi cord. Has anyone done this with a 2013/2014 SRX?
    If it proves to be a PITA I'll run a wire down below the dash and hook it up to a fuse location. The one thing I learned was to have enough wire to go around the mirror post once so when the radar detector mount looses suction the detector will hang off the wire, versus falling into the car and possibly damaging some thing on the dash.
    Thanks for any information,
    Tom
    463's Avatar
    463
    463 is offline Cadillac Owners Member
    Automobile(s): 10 SRX AWD 3.0L Premium caribbean blue
    Nov 2013
    Moosomin Sask
    68
    Re: Has anyone hardwired their radar detecter to the mirror on a 2013/2014?
    Here is a link to a good mirror mount for a detector http://rogueradarmount.com/.
    As for a power point you can remove the plastic that holds the power sunroof and map lamps from the head liner and behind it there is a multi wire connector that we placed the detectors hot (+) wire into a 12vdc switched wire in that connector and did the same for the (-) ground. Then ran the wire out to the detector using http://rogueradarmount.com/?product=seamless-cord. Its well worth the time and effort and performs very well.
    Nov 2013
    449
    Thanks for the link.
    The last several vehicles I have owned had the radar detector hard wired to the mirror electronics. I ordered a Stealth Cord that had 2 thin probes at the hookup end, for my G37 and hooked it up myself.
    When I checked out the mirror mount on the SRX, it seemed to me to be more trouble then it was worth, so I ordered a hard wire kit for just $15 and will have a local shop wire it somewhere under the dash. One of the things I learned from using radar detectors over the years is the suction cups come loose fairly often. Now I wrap the hardwire cord once around the mirror mount. When the detector comes loose from the windshield it just hangs suspended by the hard wire cord. This keeps it from falling and possibly damaging something in the car.
    Tom
    TheCaptain's Avatar
    Aug 2009
    Moosomin Saskatchewan
    30
    3,075
    Or rather than use suction cups, use a Blendmount from J28 Industries. Properly tightened, it'll never fall off and it hugs closely to the mirror.
    www. Blendmount.com
    Nov 2013
    449
    Quote Originally Posted by TheCaptain View Post
    www. Blendmount.com
    Do you have a Blendmount attached to your mirror post? I looked up their site and it looks like a quality product, but I was wondering if there was adequate room for it on the SRX with the rain sensor so close to the mirror post.
    I'm having the hard wire kit installed in the morning. It seems like the 2 little suction cup method of attaching the detector breaks loose fairly often. On my other car I ordered the setup with the one large suction cup, but it also comes on-stuck periodically.
    Tom
    TheCaptain's Avatar
    Aug 2009
    30
    3,075
    I do have the blendmount, I used it on my '10 before I got my '13 with no issues on either.
    Nov 2013
    449
    It is helpful to know that the Blendmount will fit the current SRX mirror post. I had my radar detector hardwired and my 2 front door windows tinted this morning. I will start off by using my large single suction cup mount, which should be a lot better then the 2 small suction type mount. As soon as it starts to give me any hassle I will order a Blendmount.
    Thanks,
    Tom
  10. Remove Advertisements
