Fuel Fill Problem
Results 1 to 12 of 12
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Fuel Fill Problem in Cadillac SRX / XT5 Forums; Hi, I think I read of this somewhere else on hear but thought I would bring it to the board ...
    westham is offline Cadillac Owners Fanatic
    Automobile(s): 2010 SRX Luxury
    Jul 2013
    Los Angeles CA
    359
    Fuel Fill Problem
    Hi,
    I think I read of this somewhere else on hear but thought I would bring it to the board to see if anyone has suggestions.
    Since I purchased my 2010 Luxury I have had a very tough time getting fuel into the tank, I've been to several gas stations
    and have had the same problem with the fuel pump handle clicking off as soon as the fuel begins to flow, I end up twisting the handle as far to the left as it will go and holding the trigger, this way also has pressure build up which stops the pump 4 or 5 times during the fill up. Very frustrating.
    kpann's Avatar
    kpann is offline Cadillac Owners Member
    Sep 2013
    Virginia
    46
    This has to do with the fact that the pressure builds up in your gas tank and is not releasing. I just did some work on the Vapor Canister which works with vent solenoid and purge solenoid. That might point you in the right direction. Is your Check Engine Light on?
    Sent from AutoGuide.com Free App
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Re: Fuel Fill Problem
    Quote Originally Posted by westham View Post
    Hi,
    Hello westham,
    I am sorry to hear that you are experiencing an issue with your SRX’s fuel tank when you are trying to fill it up. Have you brought up this concern to your service department at your Cadillac dealership? If not, I would be more than happy to assist you in setting up an appointment and working with the dealership. Please feel free to private message me if you would like my assistance. I hope to hear from you soon.
    Gregory W.
    Cadillac Customer Care
    '12CTSman is offline Cadillac Owners Fanatic
    Automobile(s): '13 SRX AWD Premium
    May 2012
    Indiana
    249
    Hi, I think I read of this somewhere else on hear but thought I would bring it to the board to see if anyone has suggestions. Since I purchased my 2010 Luxury I have had a very tough time getting fuel into the tank, I've been to several gas stations and have had the same problem with the fuel pump handle clicking off as soon as the fuel begins to flow, I end up twisting the handle as far to the left as it will go and holding the trigger, this way also has pressure build up which stops the pump 4 or 5 times during the fill up. Very frustrating.
    . At your own risk, as a temporary measure you can turn the nozzle upside down, but you really need to have it fixed ASAP. Yes, it's a vapor recovery problem. Your canister is probably contaminated from someone trying to get as much gas into the tank as possible.
    stealth97 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 SRX Performance FWD
    Mar 2010
    120
    If it's the same problem my car had, there is a fix for it. I took it to the dealer and they took care of it. When I pumped gas into the car it would flip off as well. Now all is good. Not sure what they did, But they knew what I was talking about when I mentioned it to them.
    300:29:1 is offline Cadillac Owners Enthusiast
    Automobile(s): 2012 SRX Luxury w/NAV
    Oct 2009
    Syracuse, N.Y.
    791
    Quote Originally Posted by '12CTSman
    Can overfilling the fuel tank really cause irreversible damage? I thought that if you overfilled/tried to fill all the way, any problems would eventually resolve themselves. Over the years, and before I knew that this was a bad idea, I've overfilled a few times. I've never been aware of any problems.
    Jul 2013
    Los Angeles CA
    359
    Quote Originally Posted by stealth97 View Post
    Thanks Stealth97 and everyone for your replies, I have made an appointment with the local Cadillac dealer for next week. They also seemed to know what the problem was. Will let you know the outcome.
    retcad is offline Cadillac Owners Fanatic
    Jun 2013
    188
    I'm sure it can be fixed. Although I've never experienced the problem, I generally avoid filling the tank to the brim. When I'm a little below half a tank, I put 7 or 8 gallons in, and this takes me a bit below full.
    Also, if I fill it up completely, I hear and feel a 'thumping' noise, which goes away after burning off a few gallons. I've read there's fix for this, too, but I'm afraid that if a dealer messes with it, it may create issues that I currently don't have.
    Mar 2010
    Detroit, USA
    12,674
    Hello westham,
    I am glad to hear that you have an appointment with your Cadillac dealership next week. Laura and I will be sure to look for your future updates.
    Gregory W.
    Jul 2013
    Los Angeles CA
    359
    Just got a call from the Dealer, all fixed, they replaced the filler pipe, I will test it out when I pick up the car and fill it up, seems there have been a few documents issued by GM on this complaint.
    Mar 2010
    Detroit, USA
    12,674
    Thank you for updating the thread, westham. I am glad your dealer was able to help resolve your concern and replace the filler pipe. If additional concerns or questions arise, don't hesitate to contact us.
    Sincerely,
    Laura M.
    Jul 2013
    Los Angeles CA
    359
    Replacement Fuel filler pipe solved the problem, now Gas pump does not click off until the tank is full. Much better than fighting with it all the way. :-)
  15. Remove Advertisements
