Maintain power system
Results 1 to 7 of 7
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Maintain power system in Cadillac SRX / XT5 Forums; How to keep your battery or power system in good condition during your vacation if you want to keep your ...
    seeniim is offline Cadillac Owners Member
    Jan 2013
    3
    How to keep your battery or power system in good condition during your vacation if you want to keep your SRX 2013 not running stored in garage for 40 days?
    TheCaptain's Avatar
    Aug 2009
    Moosomin Saskatchewan
    30
    3,075
    Re: Maintain power system
    40 days shouldn't quite be long enough to kill a vehicle in normal weather conditions.
    If you are worried, pick up a trickle charger from your local auto stop.
    Jan 2013
    3
    Thank you for the answer. But when I used to have the CTS I used to disconnect the battery can I do the same for srx 2013 and if yes how can I can disconnect the positive line.
    Thx
  5. #4
    GEORGEC is offline Cadillac Owners Fanatic
    Automobile(s): 2013 Ice While SRX Performance, 2005 DeVille DHS For Sale
    Sep 2005
    FLORIDA PANHANDLE
    210
    I would not disconnect the battery unless necessary. I am not real familiar with systems that would be effected, but I am sure you would have some resets when you reconnected. I do not think 40 days is long enough to be a problem. However, if you are concerned get, as suggested, a trickle charger.
  6. #5
    TheCaptain's Avatar
    Aug 2009
    30
    3,075
    Don't worry about disconnecting the battery, but the SRX has five positive terminals that need to be released (if memory serves me correctly) in order to release the main positive (or four and one... whatever, lots).
  7. #6
    Huey Driver is online now Cadillac Owners Fanatic
    Automobile(s): 2014 ELR
    Sep 2011
    Fairfax, VA
    53
    303
    I believe, if you have to disconnect, always disconnect negative (ground) first, then positive (hot). When reconnecting, reconnect hot, then ground. For one, ground is further from the battery (less gasses) and second, its supposed to reduce the chances of a surge/spark when connecting. If you gotta disconnect, disconnect the ground and leave it at that...
  8. #7
    MJDART's Avatar
    MJDART is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 ATS Performance 2013 SRX Premium
    Dec 2005
    Broward Co. South Florida
    62
    1,045
    Trickle Charger is a great investment for prolonging batteries on vehicles which are not frequently used. I use one on my Indian Motorcycle and my John Deere Tractor, they always start due to the float charging maintianing the battery in a fully charged condition. A Deltran Battery Tender Jr. for under $25 will work perfectly. They come with a small cable that attaches to battery posts at terminal connections and the other end has a plug. When ever you need to use it just plug in the tender to a 110V outlet and connect its cable to the one on the vehicle very simple.
    Here's an example: http://www.amazon.com/Battery-Tender.../dp/B000CITK8S
  9. Remove Advertisements
