So my SRX has the vertical LED tubes that light up when the lights are on. They look nice but are very dim. I also have a Cadillac ATS with the insanely bright vertical LED lights. Has anyone tried to modify the SRX to make these lights as bright as an ATS or XTS?
I'll probably do a google search for LED conversions but was hoping someone had already done it.
Both sellers have the same images with the same "brand" watermarks on the images....have you purchased either of these products? I would love to know your experience if you have.....so many questions....
Yes, matter of fact I did as if you check the earlier tread posted. I have seen them physically and the (L shape) LEDs are not in line. Also, the quote might be for single unit, so you need to double check on that again. Besides, the color of the LEDs also vary, when I purchase mine, I tested the lights and finally got it the second time around as the first unit color differs from each other (left was slightly yellow than the right which is white).
So you have a set on your SRX right now? Could you post some high res photos of yours installed? How has the chromed-plastic held up so far? Any chipping? How long have you had them installed?
Thanks!
Edit: I just found your post/pic.....you have the ones with the straight line of LEDs at the top that several here have installed, not the 'L' shaped ones....now I'm confused...
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
