EBC Rotor and Pad Upgrade (Bonus SS Lines with Motful RBC 660)
Results 1 to 13 of 13
Cadillac SRX Second Generation Forum (2010-2016) Discussion, EBC Rotor and Pad Upgrade (Bonus SS Lines with Motful RBC 660) in Cadillac SRX / XT5 Forums; Front Rotor (355mm) Fronts Assembled Rears Very Peculiar thing I noticed about the stock pad, the braking surface is cut ...
    kanundrum is offline Cadillac Owners Member
    Automobile(s): None
    Oct 2012
    33
    97
    Front Rotor (355mm)
    Fronts Assembled
    Rears
    Very Peculiar thing I noticed about the stock pad, the braking surface is cut by about 20 to 30% because for some odd reason who ever designed the pad decided to put grooves/valleys on the sides. This design makes no sense to me and if anything reduces the amount of the contact surface for the pad and the rotor. Also tricks the owner into thinking they have more pad left when in reality you have to get a new pad when your indicator starts hitting the valleys and not the backing plate of the pad.
    Getting Stainless Steel Lines Installed on Thursday with a Motful RBF 660 Flush (Fluid dirty despite it being changed 15k miles ago).
    TheCaptain's Avatar
    Aug 2009
    Moosomin Saskatchewan
    30
    3,075
    Re: EBC Rotor and Pad Upgrade (Bonus SS Lines with Motful RBC 660)
    Sweet. I like the vented rotors!
    Automobile(s): None
    Oct 2012
    33
    97
    Custom SS Teflon Lines if anyone is interested. The car Stops so much better now its at least a good 30% to 40% Braking Improvement.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    I have Ultimax rotors on my Seville, with RedStuff pads. Nice brakes.
    The point of the slots in brake pads is the same as the slots in the rotors: To allow gasses and dust to escape from between the pad and rotor.
    Chamfers are there mostly for noise reduction, and there are thermal reasons with performance pads as well.
    30-40%??? You've reduced your braking distance by almost half?
    Automobile(s): None
    Oct 2012
    33
    97
    I have 100% road tested it but Initial Feel is severely drastic, especially after SS Lines and Fluid. Car comes to a stop on a dime, the chamfer information is quite interesting how ever I can't think the pads were still not the best for brake/stopping force.
    Automobile(s): None
    Oct 2012
    33
    97
    Update greenstuff was causing grinding going to redstuff soon.
    Automobile(s): None
    Oct 2012
    33
    97
    Redstuff swapped in and its even better than the greenstuff. Greenstuff seems like it was bad as I tooke dit out only after 2 or 3k miles and it has cracks in the actual pads.
    Automobile(s): None
    Oct 2012
    33
    97
    Update Redstuff feels like its fading under heavy braking. I am looking into big brake kit options soon but finding it very difficult due to the bolt pattern
    njacobsen is offline Cadillac Owners Enthusiast
    Automobile(s): 2017 XT5, Platinum, Dark Granite Metallic, 20" Ultra-Bright
    Dec 2012
    WI
    506
    Perhaps you should return to stock.
    Thank you for sharing the results you had with the product. That is one of the values of these forums...sharing experience, good or bad, helps all of us.
    SFVetteman's Avatar
    SFVetteman is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 CTS 3.6 Premium, 1999 Corvette,370 RWHP & other mods
    Jul 2011
    San Francisco
    1,116
    Redstuff are ceramic pads. They produce less dust that you can see but at a price of more brake fade. If you want a true performance brake pad then check out Hawk HPS, Hawk HPS Plus or EBC Yellowstuff.
    Bill
    Sep 2010
    East Boston MA.
    29
    26,325
    Ceramics are less probe to fade, not more prone.
    SFVetteman's Avatar
    Jul 2011
    San Francisco
    1,116
    If you want to believe that then go ahead, but I speak from real track experience of myself and others.
    Bill
    Automobile(s): None
    Oct 2012
    33
    97
    Unfortunately long term tests results are very weird. I will be switching to a different brand of rotors and pads as initial feel was quite great but long term tests result in lots of wear and braking improvement reduction. Most likely I will be going with stoptech rotors and akebono setup. No other manufacturer makes aggressive fronts and rears like Hawk HPS or Stoptech street series.
  16. Remove Advertisements
