Bluetooth Audio
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By dmurphy
Cadillac SRX Second Generation Forum (2010-2016) Discussion, Bluetooth Audio in Cadillac SRX / XT5 Forums; Unfortunately, I'm not writing to say that I've figured how to make it work (I didn't), but I installed a ...
    erdoc48 is offline Cadillac Owners Fanatic
    Automobile(s): 2012 SRX Performance FWD, Platinum Ice
    Dec 2005
    Westampton, NJ
    218
    Bluetooth Audio
    Unfortunately, I'm not writing to say that I've figured how to make it work (I didn't), but I installed a Miccus Mini Jack RX with a constant power supply (via a plug in Griffin Powerjolt USB power port). It works very well and it's nice to have the phone connected via Bluetooth. I'd like the factory radio to allow itself to be configured correctly, but no dice. By the way, the Miccus and the USB power port were $38 from Amazon.com. Ive tried everything to make this work (factory BT streaming), but I just can't bring up the BT audio menu, no matter what I do.
    htron is offline Cadillac Owners Member
    Aug 2013
    Canton, Mi
    25
    Re: Bluetooth Audio
    Has anyone else used this miccus device? is it true that I need it to stream music from my phone to the cts-v's audio system? (taking delivery on a 2014 next week)
    Thanks!
    Ron
    Dec 2005
    Westampton, NJ
    218
    Re: Bluetooth Audio
    Quote Originally Posted by htron View Post
    Thanks!
    Ron
    Hopefully the 2014's will have streaming BT audio like every other car made today
    quantex is offline Cadillac Owners Member
    Automobile(s): Own two 2012 SRX-4 w/o Nav
    Jul 2012
    48
    63
    Re: Bluetooth Audio
    If you have non-nav, then you have GMCONNECT.
    stevec5375's Avatar
    stevec5375 is offline Cadillac Owners Connoisseur
    Automobile(s): Formerly owned: 2010 SRX/3.0L Premium/FWD/Platinum Ice/Shale
    Jan 2010
    Austin, TX, USA
    60
    1,865
    Re: Bluetooth Audio
    I have a 2010 SRX with the Nav/Radio unit. Needless to say there is not built in BT streaming which I found very DUMB on GM's part. My old 3rd party radio in my Infiniti had that. However, I bought the Micus device and it worked great. Then I figured out how much compression BT does to the audio and decided to stop using it. Instead, I now use a retractable jack to the Aux In port. I use the streaming music service MOG.com and connect my Android phone via a jack. There is no compression, unlike BT, and the sound is MUCH better. The Miccus is more of a convenience than anything. I prefer the Aux-In higher fidelity.
    However, I have to say that overall the sound system in the 2010 SRX sucks compared to other vehicle I've owned. But I have stereo speakers that cost $40K so what do you expect. This sound system in the SRX is not audiophile quality.
    Aug 2013
    Canton, Mi
    25
    Re: Bluetooth Audio
    Quote Originally Posted by erdoc48 View Post
    You would think so, wouldn't you?
    But as far as I can tell, the 2014's are identical to the 2013's! Surprised me!
    Huey Driver is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ELR
    Sep 2011
    Fairfax, VA
    54
    303
    Re: Bluetooth Audio
    I'm not going to say definitively, but I am going to argue that these systems ARE capable of streaming audio. I've done it. The problem is trying to use the same device for phone and audio. But if you have a GPS and a phone, separate, you can set them up just fine. If you want to stream audio from your Ipad and use your Iphone, no problem.
    I set up my previous phone (HTC Evo) to do both audio streaming and phone. The problem was with both the car audio AND the phone on switching between the two functions. If I got a call, sometimes the car wouldnt pick up the call. The phone would ring, but not pass it through the audio system. Then when I hung up, the audio wouldnt restart.
    I'd like to have the BT, maybe for something like IHeartRadio, but as Steve says, BT is the worst way to transfer high dynamic range audio. For all the convenience it would be to just automatically connect, the terrible sound quality means it just makes more sense to use the cable.
    Aug 2013
    Canton, Mi
    25
    Re: Bluetooth Audio
    Well, if it does work like this, that's a bit shameful if you ask me...my 2010 flex handles all this just fine, switching between phone and listening to a podcast on the iphone! In fact, with the app I use, as soon as I start the flex, if it's already set to the BT input, the podcast on the phone starts playing automatically, I don't even have to touch the phone...and the pause/fast forward/etc functions on the car system control the audio on the phone.
    stevec5375's Avatar
    Jan 2010
    Austin, TX, USA
    60
    1,865
    Re: Bluetooth Audio
    I am convinced that the technology is often there but the vendor just holds back on releasing it until a later model year. That is one more way they have of getting people to "upgrade" and buy a new car. But in Cadillac's case, it *is* shameful because it's supposed to be a top tier vehicle with all the bells and whistles. NOT!
    dmurphy is offline Cadillac Owners Fanatic
    Automobile(s): '17 XT5 Platinum (Crystal White/Maple Sugar)
    Sep 2013
    112
    Re: Bluetooth Audio
    I'm not sure what issues others are having, but I've had zero issue streaming audio from my iPhone via Bluetooth to my '13 SRX.
    It works and even displays track info. I've also used other apps and streamed their audio as well. Not sure why the struggle?
    stevec5375's Avatar
    Jan 2010
    Austin, TX, USA
    60
    1,865
    Re: Bluetooth Audio
    Quote Originally Posted by dmurphy View Post
    Those of us with a 2010 and Nav unit don't have the ability to both stream BT audio and connect the phone at the same time.
    Sep 2013
    112
    Re: Bluetooth Audio
    Quote Originally Posted by stevec5375 View Post
    Understood, but htron's comment:
    implies that the 2013's do not do BT audio streaming. This is in fact not the case.
    TheCaptain likes this.
  15. Remove Advertisements
