Results 1 to 7 of 7
Thread: Wind noise 2011 srx
    Aggieinohio is offline Cadillac Owners Member
    Automobile(s): 2011 Cadillac SRX
    Apr 2013
    30
    3
    Wind noise 2011 srx
    Just bought a 2011 Cadillac srx and one thing I noticed is that there seems to be high wind noise coming from the front of the cabin, like near the top of windshield or start of sunroof. Happens at even low speeds around 30 but gets louder with higher speeds. Is this normal or should I hear no noise?
    davedogcaddy's Avatar
    davedogcaddy is offline Cadillac Owners Fanatic
    Automobile(s): 2010 SRX Premium (3.0L, FWD), 2008 CTS (3.6L DI, AWD)
    Jan 2006
    GA
    287
    Re: Wind noise 2011 srx
    no noticeable noise on my 2010......in fact this is the quietest car I've ever owned.
    try doing an express open/close of the sunroof....i know on my wife's cts this seems to 'reseal' the seal and quiet things down.
    sube5186's Avatar
    sube5186 is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 SRX Premium, 3.0L AWD
    Oct 2007
    NC
    1,817
    No, this is NOT normal. If it's coming from the top of the windshield, more than likely that's a replacement windshield. I only say this because a poorly fitted windshield is more probable if done aftermarket. Do you know the history of the car? If not, ask the dealer if the windshield has ever been replaced. If it's the sunroof, it has built-in adjustments that can fix this. I think way back in the day you were pretty much stuck with an ill fitted sunroof. They've since learned from this and most (including ours) have adjustment screws to correct alignment issues. One of the glass panels on mine was ever so slightly raised right where the two panels meet. Most people would never have noticed it. There were no wind or water leaks. I just didn't like the way it looked and I knew it was supposed to be even. They adjusted it and now they're both perfectly even.
    Either way, if you're getting wind noise "inside" the cabin, that's an opportunity for water intrusion, which is never a good thing. I would tend to this ASAP, before you get caught in the rain.
    Sube
  5. #4
    22velocity is offline Cadillac Owners Member
    Automobile(s): 2017 xt5 luxury adriatic blue
    Jan 2011
    Brookfield Wi
    75
    49
    A way that I use to pinpoint leaks is to take a strip of masking tape and put it across the front seam of the sunroof. If that stops the wind noise then you know the source. the same thing goes for the windshield, take a strip of tape and run it across the windshield header. I learned this trick years ago when they had Fisher Body reps for GM. Frank
  6. #5
    ginjack is offline Cadillac Owners Member
    Automobile(s): 2012 SRX
    Mar 2012
    21
    I had wind noise on brand new 2012. I could silence the noise by putting masking tape over joint between roof and liftgate. Even with this clue dealer could not fix. Its worse on windy days, especially with a headwind.
  7. #6
    Apr 2013
    30
    3
    Thank you all for the ideas. I will do some experimenting myself, then when I have my oil changed talk to the dealership about the issue.
  8. #7
    Mar 2010
    Detroit, USA
    12,711
    Aggieinohio,
    Hopefully your experiments yield some good data for you so that this wind noise concern can get resolved. Be sure to keep us updated on how your visit to the dealership goes, and if you should need anything in the meantime we're available to you. Please don't hesitate to contact us via private message with more information (including the last 8 digits of you VIN) so we can better assist.
    Sarah G. (Assisting Laura)
    Cadillac Customer Care
  • You may not post replies
