H10 or H11?
Results 1 to 11 of 11
Cadillac SRX Second Generation Forum (2010-2016) Discussion, H10 or H11? in Cadillac SRX / XT5 Forums; I've tried searching here and can't seem to tell which is the correct bulb for the low beam headlights on ...
    300:29:1 is offline Cadillac Owners Enthusiast
    Automobile(s): 2012 SRX Luxury w/NAV
    Oct 2009
    Syracuse, N.Y.
    791
    H10 or H11?
    I've tried searching here and can't seem to tell which is the correct bulb for the low beam headlights on a 2012 Luxury. I'm looking to replace the bulbs with something brighter, but definitely not HID. The manual says H10. Which is it?
    Oct 2009
    Syracuse, N.Y.
    791
    Quote Originally Posted by 300:29:1
    Anyone?
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: H10 or H11?
    low beams are H11
    Oct 2009
    Syracuse, N.Y.
    791
    Quote Originally Posted by RippyPartsDept
    low beams are H11
    Thanks Rippy. The manual clearly states H10. That's not good. With the replacement process being a little involved, I wouldn't want to get the bulb out only to find out I bought the wrong replacement.
    Sep 2007
    Wilmington, NC
    13,986
    Re: H10 or H11?
    https://www.sylvania.com/en-us/appli...s/lrgmain.aspx
    That's a good link to bookmark for future reference (or you can always just google it)
    H10 is basically the same lamp with a different base ... manuals often do have misprints ... the original XTS manuals had the wrong phone number for the CUE hotline
    another possibility is that they initially were going to go with h10 but switched last minute even though the manual was already sent to print
    it's less likely but stuff like that also does happen ... the manuals are finalized way before the cars are and even then the cars can change during production
    Oct 2009
    Syracuse, N.Y.
    791
    While I get your point, I generally use the online manual. That could be updated as needed.
    Sep 2007
    Wilmington, NC
    13,986
    Re: H10 or H11?
    That's the one that had the error in the XTS CUE manual even though the ones being shipped with cars had been corrected already.
    there's definitely some technical issues falling through the cracks on the cadillac.com site ... probably more to do with the separation of the web division from the other divisions and the web division more focused on sales/marketing
    am6948 is offline Cadillac Owners Member
    May 2005
    24
    Re: H10 or H11?
    Another question - I have the 2012 Performance SRX - I would like to replace the fog lights with a brighter bulb - HID or something that can throw a bright beam on the road - any suggestions?
    Sep 2007
    Wilmington, NC
    13,986
    Re: H10 or H11?
    sylvania silver star ultra or the PIAA xtreme white are the best halogen lamps (plug and play)
    converting over to HID is not recommended (and technically not legal)
    there might be a way to mod oem HID lamps but that could get pretty expensive and/or complicated
    (that's if the mod is even possible - which i'm not sure of)
    Oct 2009
    Syracuse, N.Y.
    791
    Re: H10 or H11?
    Thanks Chris!
    Sep 2007
    Wilmington, NC
    13,986
    Re: H10 or H11?
    also note, the more expensive and brighter bulbs have shorter lifespan
    (just like stars, the brighter they burn the quicker they go out)
    the sylvania packages even state so right on the back
  14. Remove Advertisements
